I learned how to import external expression from excel CSV file to NX!!!! BUT have some questions
nx 8.5
first, thanks to NXjournaling.com. I spent whole day reading codes......seriously..
here is my code:
Option Strict Off
Imports System
Imports NXOpen
Imports System.Text.RegularExpressions
Imports System.Collections.Generic
Imports System.IO
Imports System.Windows.Forms
Module Module1
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
'get number of expressions in the part
'Dim NXexp() As Expression
'NXexp = workPart.Expressions.ToArray
'Dim noOfNXExp As Integer = NXexp.Length
Dim xlsData() As String
Using xlsFile As New Microsoft.VisualBasic.FileIO.TextFieldParser("E:\book.csv")
xlsFile.SetDelimiters(",")
xlsFile.TextFieldType = FileIO.FieldType.Delimited
xlsFile.HasFieldsEnclosedInQuotes = True
While Not xlsFile.EndOfData
xlsData = xlsFile.ReadFields()
For Each NXexp As Expression In workPart.Expressions
If NXexp.Name = xlsData(0) Then
NXexp.RightHandSide = xlsData(1)
Exit For
End If
Next
End While
End Using
End Sub
End Module
the excel book.csv looks like this:
a, 1
diameter, "if a<1 then 10else 15"
the main thing i did is to use TextFieldParser which can detect comma and quotation mark
interresting thing is after this line of code
i tried to use lw.writeline(xlsData) to see what happen, BUT the result is:
System. String[]
which i dont understand
i suspect that did VS divide xlsdata into two strings because the original lne is seperated by a comma
then i try
lw.writeline(xlsData (0))
it return a.
then, i keeping trying
lw.writeline(xlsData (1))
it returns 1
As you see, the code is EXTREMELY INEFFICIENT as it has to go through all expressions in NX, but it works....
question:
1) any better way to improve the code? I saw IsMatch sort of NX built in function but really dont know how to use it
2) to succeed, i use
because initially i use
for i as integer = 0 to 999
If NXexp.
after i type If NXexp.
the VS inteliSense doesnt show up the name....
i still dont know how the expressions work exactly internally
here is my code:
Option Strict Off
Imports System
Imports NXOpen
Imports System.IO
Module Module1
Sub Main()
Exit For
End If
Next
End While
End Using
End Sub
End Module
a, 1
System. String[]
then i try
it return a.
it returns 1
question:
If NXexp.
RE: I learned how to import external expression from excel CSV file to NX!!!! BUT have some questions
However, if you plan to write more journals in the future, working through a problem such as this is a good way to learn more about NX and the API.
Your variable xlsData is a string array, the .writeline method only accepts single strings as input (not arrays).
Intellisense should work in this case, there may be an error in your code or VS/NX setup.
You can use .FindObject to see if the expression exists in the part file rather than iterating through the entire collection each time. Be aware though, the help file specifically states that .FindObject should not be used in hand written code; but it seems to work fine with expressions in NX 8.5, you will need to test this with future NX versions if/when you upgrade.
The code below illustrates the use of .FindObject:
CODE
Option Strict Off Imports System Imports NXOpen Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() If IsNothing(theSession.Parts.Work) Then 'active part required Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Dim expToFind As String = "NomWallThk" Try Dim myExp As Expression myExp = workPart.Expressions.FindObject(expToFind) lw.WriteLine(myExp.Name) lw.WriteLine(myExp.RightHandSide) Catch ex As NXException 'MsgBox(ex.Message) If ex.ErrorCode = 3520016 Then 'no object found with this name 'code to handle this error lw.WriteLine("expression not found with name: " & expToFind) Else 'code to handle other errors lw.WriteLine(ex.ErrorCode & ": " & ex.Message) End If Finally lw.WriteLine("done processing") lw.WriteLine("") End Try lw.Close() End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination '----Other unload options------- 'Unloads the image immediately after execution within NX 'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately 'Unloads the image explicitly, via an unload dialog 'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly '------------------------------- End Function End Modulewww.nxjournaling.com
Oh, I never notice you are the author of the nxjournaling website...thanks again, a wondersul learning resource!!
I will go through the FindObject this weekend :)
i tried your method by using FindObject
using this method , i can eliminate the for loop :0
NXexp = workPart.Expressions.FindObject(xlsData(0))
question is NXexp has lots of perperties like Nxexp.Name, Nxexp.righthandside, etc, etc
how does NX figure out I am trying to find the NAME of the expression BUT not anything else? after the name of the expression matches with xleData(0), then the code proceed to assign expression to it
