environmental variable and customization problems
Hello, I'm having a go at setting environmental variables and start up scripts to set the templates on a server.
So I created a templates folder on the server, created the templates and changed the .pax files to suit.
Then I copy pasted the ugii_env.dat file to the server and added this line:
UGII_TEMPLATE_DIR= path to the templates folder
Then created a small script to launch NX that I will give to everyone using NX:
@echo off
set UGII_ENV_FILE=path to the ugii_env.dat on the server
start "" "C:\Program Files\Siemens\NX 9.0\UGII\ugraf.exe"
Now my question is, If anyone for some reason doesn't have access to the server because they are off site or working offline they can't access any of this things.
Can I write an IF statement on the launch script that if the ugii_env.dat is not found to use the standard NX setting in the root directory?
How do I do this?
Is there also a environmental variable to change the welcome screen to a different one?
I found this one: UGII_BACKGROUND_URL, but if the welcome help page is turned off it will not work
is there an environmental variable to turn that help welcome screen back on again?
Thanks so much
best regards
Francisco
@echo off
How do I do this?
Thanks so much
best regards
Francisco
RE: environmental variable and customization problems
if EXIST "blah" (
set ...
) ELSE (
set ...
Mark Rief
NX CAM Customer Success
Siemens PLM Software
Another approach that may be more robust is to set UGII_ENV_FILE to a local file that performs the test of the networked file and if the network location is available uses the contents of the network file.
This insures that the variables will be used for NX from the shortcut and by all NX command line utilities and NX sessions launched by means other than the batch file/shortcut (e.g. windows explorer double click, etc.).
It gives the opportunity to have some variables set even if the network share is unavailable.
The local UGII_ENV_FILE would look something like this. (NX 9 implicitly processes the $UGII_BASE_DIR\ugii\ugii_env.dat file after the UGII_ENV_FILE (but there is no harm in explicitly adding that to the end of the local file to help depict the logic for the order of the files used))))
CODE -->
#if FILE server\share\file.ext #include server\share\file.ext #endif ## Other env vars if needed ... #include ${UGII_BASE_DIR}\ugii\ugii_env.datHTH,
Joe
