amada turbo run time,and chiller temp?
we had are turbo replaced about a year ago or so by fanuc i failed to log the hours off of the machine i was wondering if the run time in the system menu is the correct time to judge for oil life and etc. also what is the temperature ranges for the chiller im assuming if it gets to hot i will get a alarm. Is there a max temp i don't want to run? the machine is a amada 2415 a ii 2000 kw the chiller is a koolant koolers c class. thanks for this great site and all the info.
RE: amada turbo run time,and chiller temp?
"I am stuck on Band-Aid brand, 'cause they are stuck on me"
