Snipping Strands of Stranded Conductors
I have always thought that the Code (CEC and/or NEC) inhibited the snipping off of some strands of conductors - say for example - to make a larger conductor fit into a smaller lug. I thought that the correct way to do it would be to crimp on a reducer (for example if you use #10 or #8 for voltage drop to an outlet that has terminals for #12).
However, I can not find a specific code item for this. Perhaps it is just good practice?
RE: Snipping Strands of Stranded Conductors
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
"Will work for (the memory of) salami"
There is also 110.12 - "Electrical Equipment shall be installed in a neat and workmanlike manner."
Our specs generally reference NECA standards as well.
