Single zone VAV (SZVAV )
RE: Single zone VAV (SZVAV )
you seemingly do need control, but if control is settled at ahu, you would need constant pressure controller upstream of supply grilles.
in any case, you need to study your ahu setup, general references are just first step in scrutiny.
There are many ways to design a system. It all depends on what is more important to the client. Tight control? first cost? energy effieicncy? Then you select the system that meets their expectations.
knowledge is power
