Displacement
Displacement
hi guys
I have problem in my project also I don't have time , because I just have two months then I should submit my report my problem is (I’m working on an incremental sheet forming process which needs a rigid tool to move on a complicated tool path, i.e., something like helical path. I have defined this path correctly using AMPLITUDE but it is only work at small number of turn (distance between turn 1 mm) . Otherwise, if I reduce the distance between turns i.e. 0.5 mm I got a very strange tool path not as the same as the one that has been defined using AMPLITUDE. Consequently, the tool moves in arbitrary motion like sliding in random motion.)
If you have any suggestion it will be highly appreciated
RE: Displacement
I think your problem is in amp. You have to have attention that the first column in amp is your step time and the 2end column is your step increment. If 2end be 1 the step will finish in time that you write in first column. For example full time of one step is 3s and you want to do all of this step linearly in 3s your amp have to be:
time Amp
0 0
3 1
RE: Displacement
thank you very much for your replay
I use huge values in my amplitude may sometime reach to 60 thousands depend on the model, also I have three amplitudes because my tool move in three dimension at the same time (x,y,z).I will put my coordinate with amplitude in input file can you check them please and tell me if there is any error.
regards
alalani
time x y z
0 0 0 0
0.0061 -0.13997 -0.13997 -0.00694
0.01221 -0.54487 -0.54487 -0.01389
0.01831 -1.21151 -1.21151 -0.02083
0.02441 -2.13474 -2.13474 -0.02777
0.03051 -3.30742 -3.30742 -0.03471
0.03661 -4.72055 -4.72055 -0.04166
0.0427 -6.36328 -6.36328 -0.0486
0.0488 -8.22304 -8.22304 -0.05554
0.05489 -10.2856 -10.2856 -0.06248
0.06099 -12.5352 -12.5352 -0.06943
0.06708 -14.9547 -14.9547 -0.07637
0.07317 -17.5256 -17.5256 -0.08331
0.07926 -20.2283 -20.2283 -0.09025
0.08535 -23.0422 -23.0422 -0.0972
0.09144 -25.9459 -25.9459 -0.10414
0.09752 -28.9173 -28.9173 -0.11108
0.10361 -31.9337 -31.9337 -0.11802
0.10969 -34.9722 -34.9722 -0.12497
0.11577 -38.0098 -38.0098 -0.13191
0.12185 -41.0232 -41.0232 -0.13885
0.12793 -43.9896 -43.9896 -0.14579
0.13401 -46.8866 -46.8866 -0.15274
0.14009 -49.692 -49.692 -0.15968
0.14617 -52.3847 -52.3847 -0.16662
0.15224 -54.9441 -54.9441 -0.17356
0.15832 -57.3508 -57.3508 -0.18051
0.16439 -59.5868 -59.5868 -0.18745
0.17046 -61.6349 -61.6349 -0.19439
0.17653 -63.4798 -63.4798 -0.20133
0.1826 -65.1074 -65.1074 -0.20828
0.18867 -66.5055 -66.5055 -0.21522
0.19473 -67.6636 -67.6636 -0.22216
0.2008 -68.5729 -68.5729 -0.2291
0.20686 -69.2267 -69.2267 -0.23605
0.21293 -69.62 -69.62 -0.24299
0.21899 -69.75 -69.75 -0.24993
0.22505 -69.6158 -69.6158 -0.25687
0.23111 -69.2186 -69.2186 -0.26382
0.23717 -68.5613 -68.5613 -0.27076
0.24322 -67.6492 -67.6492 -0.2777
0.24928 -66.4894 -66.4894 -0.28464
0.25534 -65.0906 -65.0906 -0.29159
0.26139 -63.4636 -63.4636 -0.29853
0.26744 -61.6209 -61.6209 -0.30547
0.27349 -59.5766 -59.5766 -0.31241
0.27954 -57.3463 -57.3463 -0.31936
0.28559 -54.947 -54.947 -0.3263
0.29164 -52.3971 -52.3971 -0.33324
0.29768 -49.7159 -49.7159 -0.34018
0.30373 -46.924 -46.924 -0.34713
0.30977 -44.0425 -44.0425 -0.35407
0.31581 -41.0935 -41.0935 -0.36101
0.32186 -38.0993 -38.0993 -0.36795
0.3279 -35.0827 -35.0827 -0.3749
0.33394 -32.0667 -32.0667 -0.38184
0.33997 -29.0743 -29.0743 -0.38878
0.34601 -26.1281 -26.1281 -0.39572
0.35204 -23.2505 -23.2505 -0.40267
0.35808 -20.4633 -20.4633 -0.40961
0.36411 -17.7878 -17.7878 -0.41655
0.37014 -15.2442 -15.2442 -0.42349
0.37617 -12.8518 -12.8518 -0.43044
0.3822 -10.6288 -10.6288 -0.43738
0.38823 -8.59181 -8.59181 -0.44432
0.39426 -6.75643 -6.75643 -0.45126
0.40028 -5.13649 -5.13649 -0.45821
0.40631 -3.74419 -3.74419 -0.46515
0.41233 -2.59005 -2.59005 -0.47209
0.41835 -1.68274 -1.68274 -0.47903
0.42437 -1.02904 -1.02904 -0.48598
0.43039 -0.63384 -0.63384 -0.49292
0.43641 -0.50004 -0.50004 -0.49986
0.44243 -0.62853 -0.62853 -0.5068
0.44844 -1.01825 -1.01825 -0.51375
0.45446 -1.66612 -1.66612 -0.52069
0.46047 -2.56711 -2.56711 -0.52763
0.46648 -3.71428 -3.71428 -0.53457
0.4725 -5.0988 -5.0988 -0.54152
0.4785 -6.71006 -6.71006 -0.54846
0.48451 -8.53571 -8.53571 -0.5554
0.49052 -10.5618 -10.5618 -0.56234
0.49653 -12.7728 -12.7728 -0.56929
0.50253 -15.1519 -15.1519 -0.57623
0.50854 -17.6809 -17.6809 -0.58317
0.51454 -20.3406 -20.3406 -0.59011
0.52054 -23.1106 -23.1106 -0.59706
0.52654 -25.9699 -25.9699 -0.604
0.53254 -28.8966 -28.8966 -0.61094
0.53854 -31.8686 -31.8686 -0.61788
0.54453 -34.8631 -34.8631 -0.62483
0.55053 -37.8575 -37.8575 -0.63177
0.55652 -40.829 -40.829 -0.63871
0.56252 -43.755 -43.755 -0.64565
0.56851 -46.6132 -46.6132 -0.6526
0.5745 -49.382 -49.382 -0.65954
0.58049 -52.0403 -52.0403 -0.66648
0.58647 -54.5681 -54.5681 -0.67342
0.59246 -56.946 -56.946 -0.68037
0.59845 -59.1562 -59.1562 -0.68731
0.60443 -61.1819 -61.1819 -0.69425
0.61041 -63.0078 -63.0078 -0.70119
0.6164 -64.62 -64.62 -0.70814
0.62238 -66.0063 -66.0063 -0.71508
0.62836 -67.1565 -67.1565 -0.72202
0.63434 -68.0617 -68.0617 -0.72896
0.64031 -68.7153 -68.7153 -0.73591
0.64629 -69.1123 -69.1123 -0.74285
0.65226 -69.2498 -69.2498 -0.74979
0.65824 -69.1269 -69.1269 -0.75673
0.66421 -68.7447 -68.7447 -0.76368
0.67018 -68.1062 -68.1062 -0.77062
0.67615 -67.2162 -67.2162 -0.77756
0.68212 -66.0817 -66.0817 -0.7845
0.68809 -64.7114 -64.7114 -0.79145
0.69405 -63.1158 -63.1158 -0.79839
0.70002 -61.3071 -61.3071 -0.80533
0.70598 -59.2992 -59.2992 -0.81227
0.71194 -57.1074 -57.1074 -0.81922
0.71791 -54.7484 -54.7484 -0.82616
0.72387 -52.2403 -52.2403 -0.8331
0.72982 -49.6021 -49.6021 -0.84004
0.73578 -46.8541 -46.8541 -0.84699
0.74174 -44.017 -44.017 -0.85393
0.74769 -41.1125 -41.1125 -0.86087
0.75365 -38.1628 -38.1628 -0.86781
0.7596 -35.1902 -35.1902 -0.87476
0.76555 -32.2174 -32.2174 -0.8817
0.7715 -29.267 -29.267 -0.88864
0.77745 -26.3613 -26.3613 -0.89558
0.7834 -23.5224 -23.5224 -0.90253
0.78935 -20.772 -20.772 -0.90947
0.79529 -18.1309 -18.1309 -0.91641
0.80124 -15.619 -15.619 -0.92335
0.80718 -13.2555 -13.2555 -0.9303
0.81312 -11.0583 -11.0583 -0.93724
0.81906 -9.04391 -9.04391 -0.94418
0.825 -7.22767 -7.22767 -0.95112
0.83094 -5.62329 -5.62329 -0.95807
0.83688 -4.24286 -4.24286 -0.96501
0.84281 -3.09679 -3.09679 -0.97195
0.84875 -2.1937 -2.1937 -0.97889
0.85468 -1.54035 -1.54035 -0.98584
0.86062 -1.14162 -1.14162 -0.99278
0.86655 -1.00041 -1.00041 -0.99972
0.87248 -1.11771 -1.11771 -1.00666
0.87841 -1.49252 -1.49252 -1.01361
0.88433 -2.12187 -2.12187 -1.02055
0.89026 -3.00089 -3.00089 -1.02749
0.89618 -4.12279 -4.12279 -1.03443
0.90211 -5.47894 -5.47894 -1.04138
0.90803 -7.05894 -7.05894 -1.04832
0.91395 -8.85069 -8.85069 -1.05526
0.91987 -10.8405 -10.8405 -1.0622
0.92579 -13.0131 -13.0131 -1.06915
0.93171 -15.352 -15.352 -1.07609
0.93763 -17.8392 -17.8392 -1.08303
0.94354 -20.4559 -20.4559 -1.08998
0.94946 -23.1821 -23.1821 -1.09692
0.95537 -25.9969 -25.9969 -1.10386
0.96128 -28.8791 -28.8791 -1.1108
0.96719 -31.8066 -31.8066 -1.11775
0.9731 -34.7572 -34.7572 -1.12469
0.97901 -37.7084 -37.7084 -1.13163
0.98491 -40.6379 -40.6379 -1.13857
0.99082 -43.5232 -43.5232 -1.14552
0.99673 -46.3426 -46.3426 -1.15246
1.00263 -49.0747 -49.0747 -1.1594
1.00853 -51.6986 -51.6986 -1.16634
1.01443 -54.1945 -54.1945 -1.17329
1.02033 -56.5435 -56.5435 -1.18023
1.02623 -58.7277 -58.7277 -1.18717
1.03213 -60.7307 -60.7307 -1.19411
1.03802 -62.5373 -62.5373 -1.20106
1.04392 -64.1338 -64.1338 -1.208
1.04981 -65.5082 -65.5082 -1.21494
1.0557 -66.6501 -66.6501 -1.22188
1.06159 -67.551 -67.551 -1.22883
1.06748 -68.2041 -68.2041 -1.23577
1.07337 -68.6045 -68.6045 -1.24271
1.07926 -68.7493 -68.7493 -1.24965
1.08515 -68.6375 -68.6375 -1.2566
1.09103 -68.27 -68.27 -1.26354
1.09692 -67.6498 -67.6498 -1.27048
1.1028 -66.7817 -66.7817 -1.27742
1.10868 -65.6723 -65.6723 -1.28437
1.11456 -64.3303 -64.3303 -1.29131
1.12044 -62.7658 -62.7658 -1.29825
1.12632 -60.991 -60.991 -1.30519
1.13219 -59.0193 -59.0193 -1.31214
1.13807 -56.8658 -56.8658 -1.31908
1.14394 -54.547 -54.547 -1.32602
1.14982 -52.0806 -52.0806 -1.33296
1.15569 -49.4853 -49.4853 -1.33991
1.16156 -46.781 -46.781 -1.34685
1.16743 -43.9883 -43.9883 -1.35379
1.1733 -41.1284 -41.1284 -1.36073
1.17916 -38.2231 -38.2231 -1.36768
1.18503 -35.2945 -35.2945 -1.37462
1.19089 -32.3649 -32.3649 -1.38156
1.19676 -29.4565 -29.4565 -1.3885
1.20262 -26.5915 -26.5915 -1.39545
1.20848 -23.7915 -23.7915 -1.40239
1.21434 -21.078 -21.078 -1.40933
1.2202 -18.4713 -18.4713 -1.41627
1.22606 -15.9914 -15.9914 -1.42322
1.23191 -13.657 -13.657 -1.43016
1.23777 -11.4858 -11.4858 -1.4371
1.24362 -9.49421 -9.49421 -1.44404
1.24947 -7.69735 -7.69735 -1.45099
1.25532 -6.10878 -6.10878 -1.45793
1.26117 -4.74047 -4.74047 -1.46487
1.26702 -3.60275 -3.60275 -1.47181
1.27287 -2.70416 -2.70416 -1.47876
1.27872 -2.05143 -2.05143 -1.4857
1.28456 -1.64943 -1.64943 -1.49264
1.29041 -1.50111 -1.50111 -1.49958
1.29625 -1.60749 -1.60749 -1.50653
1.30209 -1.96766 -1.96766 -1.51347
1.30793 -2.57877 -2.57877 -1.52041
1.31377 -3.43607 -3.43607 -1.52735
1.31961 -4.53294 -4.53294 -1.5343
1.32544 -5.86096 -5.86096 -1.54124
1.33128 -7.40992 -7.40992 -1.54818
1.33711 -9.16796 -9.16796 -1.55512
1.34295 -11.1216 -11.1216 -1.56207
1.34878 -13.256 -13.256 -1.56901
1.35461 -15.5548 -15.5548 -1.57595
1.36044 -18.0004 -18.0004 -1.58289
1.36627 -20.5742 -20.5742 -1.58984
1.37209 -23.2566 -23.2566 -1.59678
1.37792 -26.0272 -26.0272 -1.60372
1.38374 -28.8648 -28.8648 -1.61066
1.38957 -31.7479 -31.7479 -1.61761
1.39539 -34.6545 -34.6545 -1.62455
1.40121 -37.5625 -37.5625 -1.63149
1.40703 -40.4498 -40.4498 -1.63843
1.41285 -43.2945 -43.2945 -1.64538
1.41867 -46.075 -46.075 -1.65232
1.42448 -48.7701 -48.7701 -1.65926
1.4303 -51.3595 -51.3595 -1.6662
1.43611 -53.8233 -53.8233 -1.67315
1.44192 -56.1431 -56.1431 -1.68009
1.44774 -58.3012 -58.3012 -1.68703
1.45355 -60.2813 -60.2813 -1.69397
1.45935 -62.0684 -62.0684 -1.70092
1.46516 -63.649 -63.649 -1.70786
1.47097 -65.0111 -65.0111 -1.7148
1.47677 -66.1446 -66.1446 -1.72174
1.48258 -67.0408 -67.0408 -1.72869
1.48838 -67.6931 -67.6931 -1.73563
1.49418 -68.0966 -68.0966 -1.74257
1.49998 -68.2484 -68.2484 -1.74951
1.50578 -68.1474 -68.1474 -1.75646
1.51158 -67.7944 -67.7944 -1.7634
1.51738 -67.1924 -67.1924 -1.77034
1.52317 -66.3458 -66.3458 -1.77728
1.52897 -65.2614 -65.2614 -1.78423
1.53476 -63.9473 -63.9473 -1.79117
1.54055 -62.4138 -62.4138 -1.79811
1.54634 -60.6726 -60.6726 -1.80505
1.55213 -58.7369 -58.7369 -1.812
1.55792 -56.6216 -56.6216 -1.81894
1.56371 -54.3428 -54.3428 -1.82588
1.56949 -51.9179 -51.9179 -1.83282
1.57528 -49.3655 -49.3655 -1.83977
1.58106 -46.7049 -46.7049 -1.84671
1.58684 -43.9565 -43.9565 -1.85365
1.59262 -41.1411 -41.1411 -1.86059
1.5984 -38.2803 -38.2803 -1.86754
1.60418 -35.3957 -35.3957 -1.87448
1.60996 -32.5093 -32.5093 -1.88142
1.61574 -29.643 -29.643 -1.88836
1.62151 -26.8187 -26.8187 -1.89531
1.62728 -24.0577 -24.0577 -1.90225
1.63306 -21.3811 -21.3811 -1.90919
1.63883 -18.8091 -18.8091 -1.91613
1.6446 -16.3613 -16.3613 -1.92308
1.65037 -14.0562 -14.0562 -1.93002
1.65613 -11.9112 -11.9112 -1.93696
1.6619 -9.9427 -9.9427 -1.9439
1.66767 -8.16546 -8.16546 -1.95085
1.67343 -6.59294 -6.59294 -1.95779
1.67919 -5.23702 -5.23702 -1.96473
1.68495 -4.1079 -4.1079 -1.97167
1.69072 -3.21409 -3.21409 -1.97862
1.69647 -2.56226 -2.56226 -1.98556
1.70223 -2.15728 -2.15728 -1.9925
1.70799 -2.00212 -2.00212 -1.99944
1.71374 -2.09786 -2.09786 -2.00639
1.7195 -2.44366 -2.44366 -2.01333
1.72525 -3.03678 -3.03678 -2.02027
1.731 -3.87262 -3.87262 -2.02721
1.73676 -4.94472 -4.94472 -2.03416
1.7425 -6.24483 -6.24483 -2.0411
1.74825 -7.76297 -7.76297 -2.04804
1.754 -9.48751 -9.48751 -2.05498
1.75975 -11.4053 -11.4053 -2.06193
1.76549 -13.5016 -13.5016 -2.06887
1.77123 -15.7604 -15.7604 -2.07581
1.77698 -18.1645 -18.1645 -2.08275
1.78272 -20.6956 -20.6956 -2.0897
1.78846 -23.3343 -23.3343 -2.09664
1.7942 -26.0606 -26.0606 -2.10358
1.79993 -28.8537 -28.8537 -2.11052
1.80567 -31.6924 -31.6924 -2.11747
1.8114 -34.555 -34.555 -2.12441
1.81714 -37.4197 -37.4197 -2.13135
1.82287 -40.2649 -40.2649 -2.13829
1.8286 -43.0688 -43.0688 -2.14524
1.83433 -45.8103 -45.8103 -2.15218
1.84006 -48.4683 -48.4683 -2.15912
1.84579 -51.0229 -51.0229 -2.16606
1.85152 -53.4546 -53.4546 -2.17301
1.85724 -55.745 -55.745 -2.17995
1.86296 -57.8768 -57.8768 -2.18689
1.86869 -59.8337 -59.8337 -2.19384
1.87441 -61.6011 -61.6011 -2.20078
1.88013 -63.1655 -63.1655 -2.20772
1.88585 -64.5151 -64.5151 -2.21466
1.89157 -65.6398 -65.6398 -2.22161
1.89728 -66.5311 -66.5311 -2.22855
1.903 -67.1824 -67.1824 -2.23549
1.90871 -67.5888 -67.5888 -2.24243
1.91443 -67.7473 -67.7473 -2.24938
1.92014 -67.6567 -67.6567 -2.25632
1.92585 -67.318 -67.318 -2.26326
1.93156 -66.7338 -66.7338 -2.2702
1.93727 -65.9086 -65.9086 -2.27715
1.94298 -64.8488 -64.8488 -2.28409
1.94868 -63.5625 -63.5625 -2.29103
1.95439 -62.0597 -62.0597 -2.29797
1.96009 -60.3518 -60.3518 -2.30492
1.96579 -58.452 -58.452 -2.31186
1.97149 -56.3747 -56.3747 -2.3188
1.97719 -54.1358 -54.1358 -2.32574
1.98289 -51.7524 -51.7524 -2.33269
1.98859 -49.2426 -49.2426 -2.33963
1.99429 -46.6257 -46.6257 -2.34657
1.99998 -43.9215 -43.9215 -2.35351
2.00567 -41.1506 -41.1506 -2.36046
2.01137 -38.3342 -38.3342 -2.3674
2.01706 -35.4936 -35.4936 -2.37434
2.02275 -32.6505 -32.6505 -2.38128
2.02844 -29.8264 -29.8264 -2.38823
2.03413 -27.0429 -27.0429 -2.39517
2.03981 -24.321 -24.321 -2.40211
2.0455 -21.6815 -21.6815 -2.40905
2.05118 -19.1443 -19.1443 -2.416
2.05686 -16.7288 -16.7288 -2.42294
2.06255 -14.4532 -14.4532 -2.42988
2.06823 -12.3347 -12.3347 -2.43682
2.07391 -10.3894 -10.3894 -2.44377
2.07958 -8.63198 -8.63198 -2.45071
2.08526 -7.07577 -7.07577 -2.45765
2.09094 -5.73248 -5.73248 -2.46459
2.09661 -4.61225 -4.61225 -2.47154
2.10228 -3.72347 -3.72347 -2.47848
2.10796 -3.07283 -3.07283 -2.48542
2.11363 -2.66515 -2.66515 -2.49236
2.1193 -2.50343 -2.50343 -2.49931
2.12496 -2.5888 -2.5888 -2.50625
2.13063 -2.9205 -2.9205 -2.51319
2.1363 -3.49591 -3.49591 -2.52013
2.14196 -4.31055 -4.31055 -2.52708
2.14763 -5.35812 -5.35812 -2.53402
2.15329 -6.63056 -6.63056 -2.54096
2.15895 -8.1181 -8.1181 -2.5479
2.16461 -9.80934 -9.80934 -2.55485
2.17027 -11.6914 -11.6914 -2.56179
2.17593 -13.7497 -13.7497 -2.56873
2.18158 -15.9688 -15.9688 -2.57567
2.18724 -18.3315 -18.3315 -2.58262
2.19289 -20.8199 -20.8199 -2.58956
2.19854 -23.4151 -23.4151 -2.5965
2.2042 -26.0972 -26.0972 -2.60344
2.20985 -28.8458 -28.8458 -2.61039
2.21549 -31.64 -31.64 -2.61733
2.22114 -34.4586 -34.4586 -2.62427
2.22679 -37.2801 -37.2801 -2.63121
2.23243 -40.083 -40.083 -2.63816
2.23808 -42.8461 -42.8461 -2.6451
2.24372 -45.5484 -45.5484 -2.65204
2.24936 -48.1693 -48.1693 -2.65898
2.255 -50.689 -50.689 -2.66593
2.26064 -53.0884 -53.0884 -2.67287
2.26628 -55.3492 -55.3492 -2.67981
2.27192 -57.4544 -57.4544 -2.68675
2.27755 -59.388 -59.388 -2.6937
2.28319 -61.1354 -61.1354 -2.70064
2.28882 -62.6833 -62.6833 -2.70758
2.29445 -64.0202 -64.0202 -2.71452
2.30008 -65.1359 -65.1359 -2.72147
2.30571 -66.022 -66.022 -2.72841
2.31134 -66.672 -66.672 -2.73535
2.31697 -67.0809 -67.0809 -2.74229
2.3226 -67.2458 -67.2458 -2.74924
2.32822 -67.1655 -67.1655 -2.75618
2.33384 -66.8408 -66.8408 -2.76312
2.33947 -66.2741 -66.2741 -2.77006
2.34509 -65.47 -65.47 -2.77701
2.35071 -64.4346 -64.4346 -2.78395
2.35633 -63.1759 -63.1759 -2.79089
2.36194 -61.7036 -61.7036 -2.79783
2.36756 -60.0289 -60.0289 -2.80478
2.37318 -58.1647 -58.1647 -2.81172
2.37879 -56.1252 -56.1252 -2.81866
2.3844 -53.926 -53.926 -2.8256
2.39001 -51.5839 -51.5839 -2.83255
2.39562 -49.1168 -49.1168 -2.83949
2.40123 -46.5434 -46.5434 -2.84643
2.40684 -43.8834 -43.8834 -2.85337
2.41245 -41.157 -41.157 -2.86032
2.41805 -38.3849 -38.3849 -2.86726
2.42366 -35.5884 -35.5884 -2.8742
2.42926 -32.7886 -32.7886 -2.88114
2.43486 -30.0068 -30.0068 -2.88809
2.44046 -27.2641 -27.2641 -2.89503
2.44606 -24.5815 -24.5815 -2.90197
2.45166 -21.9792 -21.9792 -2.90891
2.45726 -19.4769 -19.4769 -2.91586
2.46285 -17.0938 -17.0938 -2.9228
2.46845 -14.8479 -14.8479 -2.92974
2.47404 -12.756 -12.756 -2.93668
2.47963 -10.8342 -10.8342 -2.94363
2.48522 -9.0969 -9.0969 -2.95057
2.49081 -7.55724 -7.55724 -2.95751
2.4964 -6.22686 -6.22686 -2.96445
2.50199 -5.11576 -5.11576 -2.9714
2.50758 -4.23231 -4.23231 -2.97834
2.51316 -3.58311 -3.58311 -2.98528
2.51874 -3.17301 -3.17301 -2.99222
2.52433 -3.00501 -3.00501 -2.99917
2.52991 -3.08029 -3.08029 -3.00611
2.53549 -3.39817 -3.39817 -3.01305
2.54107 -3.95613 -3.95613 -3.01999
2.54664 -4.74982 -4.74982 -3.02694
2.55222 -5.77311 -5.77311 -3.03388
2.5578 -7.01811 -7.01811 -3.04082
2.56337 -8.47528 -8.47528 -3.04776
2.56894 -10.1334 -10.1334 -3.05471
2.57451 -11.9799 -11.9799 -3.06165
2.58009 -14.0005 -14.0005 -3.06859
2.58565 -16.1799 -16.1799 -3.07553
2.59122 -18.5014 -18.5014 -3.08248
2.59679 -20.9473 -20.9473 -3.08942
2.60235 -23.4989 -23.4989 -3.09636
2.60792 -26.1369 -26.1369 -3.1033
2.61348 -28.8411 -28.8411 -3.11025
2.61904 -31.5909 -31.5909 -3.11719
2.6246 -34.3655 -34.3655 -3.12413
2.63016 -37.1436 -37.1436 -3.13107
2.63572 -39.9043 -39.9043 -3.13802
2.64128 -42.6264 -42.6264 -3.14496
2.64683 -45.2894 -45.2894 -3.1519
2.65239 -47.8731 -47.8731 -3.15884
2.65794 -50.3577 -50.3577 -3.16579
2.66349 -52.7246 -52.7246 -3.17273
2.66905 -54.9556 -54.9556 -3.17967
2.6746 -57.0341 -57.0341 -3.18661
2.68014 -58.9441 -58.9441 -3.19356
2.68569 -60.6712 -60.6712 -3.2005
2.69124 -62.2025 -62.2025 -3.20744
2.69678 -63.5264 -63.5264 -3.21438
2.70233 -64.6328 -64.6328 -3.22133
2.70787 -65.5135 -65.5135 -3.22827
2.71341 -66.1619 -66.1619 -3.23521
2.71895 -66.5731 -66.5731 -3.24215
2.72449 -66.7441 -66.7441 -3.2491
2.73003 -66.6738 -66.6738 -3.25604
2.73556 -66.3627 -66.3627 -3.26298
2.7411 -65.8134 -65.8134 -3.26993
2.74663 -65.03 -65.03 -3.27687
2.75217 -64.0188 -64.0188 -3.28381
2.7577 -62.7874 -62.7874 -3.29075
2.76323 -61.3454 -61.3454 -3.2977
2.76876 -59.7037 -59.7037 -3.30464
2.77428 -57.8749 -57.8749 -3.31158
2.77981 -55.8731 -55.8731 -3.31852
2.78534 -53.7135 -53.7135 -3.32547
2.79086 -51.4126 -51.4126 -3.33241
2.79638 -48.9879 -48.9879 -3.33935
2.80191 -46.458 -46.458 -3.34629
2.80743 -43.8421 -43.8421 -3.35324
2.81295 -41.1601 -41.1601 -3.36018
2.81846 -38.4325 -38.4325 -3.36712
2.82398 -35.6799 -35.6799 -3.37406
2.8295 -32.9235 -32.9235 -3.38101
2.83501 -30.184 -30.184 -3.38795
2.84053 -27.4823 -27.4823 -3.39489
2.84604 -24.839 -24.839 -3.40183
2.85155 -22.274 -22.274 -3.40878
2.85706 -19.8069 -19.8069 -3.41572
2.86257 -17.4564 -17.4564 -3.42266
2.86807 -15.2403 -15.2403 -3.4296
2.87358 -13.1753 -13.1753 -3.43655
2.87909 -11.2772 -11.2772 -3.44349
2.88459 -9.56021 -9.56021 -3.45043
2.89009 -8.03735 -8.03735 -3.45737
2.89559 -6.72012 -6.72012 -3.46432
2.90109 -5.61843 -5.61843 -3.47126
2.90659 -4.74057 -4.74057 -3.4782
2.91209 -4.0931 -4.0931 -3.48514
2.91759 -3.68086 -3.68086 -3.49209
2.92308 -3.50686 -3.50686 -3.49903
2.92858 -3.57233 -3.57233 -3.50597
2.93407 -3.87665 -3.87665 -3.51291
2.93956 -4.41743 -4.41743 -3.51986
2.94505 -5.19043 -5.19043 -3.5268
2.95054 -6.18969 -6.18969 -3.53374
2.95603 -7.4075 -7.4075 -3.54068
2.96151 -8.83451 -8.83451 -3.54763
2.967 -10.4598 -10.4598 -3.55457
2.97248 -12.2709 -12.2709 -3.56151
2.97797 -14.2539 -14.2539 -3.56845
2.98345 -16.3938 -16.3938 -3.5754
2.98893 -18.6742 -18.6742 -3.58234
2.99441 -21.0777 -21.0777 -3.58928
2.99989 -23.5859 -23.5859 -3.59622
3.00537 -26.1798 -26.1798 -3.60317
3.01084 -28.8395 -28.8395 -3.61011
3.01632 -31.545 -31.545 -3.61705
3.02179 -34.2755 -34.2755 -3.62399
3.02726 -37.0103 -37.0103 -3.63094
3.03273 -39.7286 -39.7286 -3.63788
3.0382 -42.4098 -42.4098 -3.64482
3.04367 -45.0334 -45.0334 -3.65176
3.04914 -47.5796 -47.5796 -3.65871
3.05461 -50.0291 -50.0291 -3.66565
3.06007 -52.3632 -52.3632 -3.67259
3.06553 -54.5644 -54.5644 -3.67953
3.071 -56.6158 -56.6158 -3.68648
3.07646 -58.502 -58.502 -3.69342
3.08192 -60.2088 -60.2088 -3.70036
3.08738 -61.7231 -61.7231 -3.7073
3.09283 -63.0337 -63.0337 -3.71425
3.09829 -64.1305 -64.1305 -3.72119
3.10375 -65.0055 -65.0055 -3.72813
3.1092 -65.652 -65.652 -3.73507
3.11465 -66.0652 -66.0652 -3.74202
3.12011 -66.2421 -66.2421 -3.74896
3.12556 -66.1815 -66.1815 -3.7559
3.13101 -65.8838 -65.8838 -3.76284
3.13645 -65.3515 -65.3515 -3.76979
3.1419 -64.5888 -64.5888 -3.77673
3.14735 -63.6014 -63.6014 -3.78367
3.15279 -62.3971 -62.3971 -3.79061
3.15823 -60.9851 -60.9851 -3.79756
3.16368 -59.3762 -59.3762 -3.8045
3.16912 -57.5827 -57.5827 -3.81144
3.17456 -55.6184 -55.6184 -3.81838
3.17999 -53.4982 -53.4982 -3.82533
3.18543 -51.2383 -51.2383 -3.83227
3.19087 -48.856 -48.856 -3.83921
3.1963 -46.3695 -46.3695 -3.84615
3.20174 -43.7976 -43.7976 -3.8531
3.20717 -41.16 -41.16 -3.86004
3.2126 -38.4768 -38.4768 -3.86698
3.21803 -35.7683 -35.7683 -3.87392
3.22346 -33.0552 -33.0552 -3.88087
3.22889 -30.3581 -30.3581 -3.88781
3.23431 -27.6975 -27.6975 -3.89475
3.23974 -25.0935 -25.0935 -3.90169
3.24516 -22.5661 -22.5661 -3.90864
3.25058 -20.1343 -20.1343 -3.91558
3.256 -17.8165 -17.8165 -3.92252
3.26142 -15.6304 -15.6304 -3.92946
3.26684 -13.5926 -13.5926 -3.93641
3.27226 -11.7183 -11.7183 -3.94335
3.27768 -10.0219 -10.0219 -3.95029
3.28309 -8.51608 -8.51608 -3.95723
3.28851 -7.21226 -7.21226 -3.96418
3.29392 -6.12025 -6.12025 -3.97112
3.29933 -5.24825 -5.24825 -3.97806
3.30474 -4.60279 -4.60279 -3.985
3.31015 -4.18868 -4.18868 -3.99195
3.31556 -4.00895 -4.00895 -3.99889
3.32097 -4.06488 -4.06488 -4.00583
3.32637 -4.35594 -4.35594 -4.01277
3.33178 -4.87979 -4.87979 -4.01972
3.33718 -5.63237 -5.63237 -4.02666
3.34258 -6.60784 -6.60784 -4.0336
3.34798 -7.79869 -7.79869 -4.04054
3.35338 -9.19577 -9.19577 -4.04749
3.35878 -10.7884 -10.7884 -4.05443
3.36418 -12.5643 -12.5643 -4.06137
3.36957 -14.51 -14.51 -4.06831
3.37497 -16.6105 -16.6105 -4.07526
3.38036 -18.8499 -18.8499 -4.0822
3.38576 -21.211 -21.211 -4.08914
3.39115 -23.6759 -23.6759 -4.09608
3.39654 -26.2258 -26.2258 -4.10303
3.40193 -28.8412 -28.8412 -4.10997
3.40731 -31.5023 -31.5023 -4.11691
3.4127 -34.1887 -34.1887 -4.12385
3.41808 -36.8801 -36.8801 -4.1308
3.42347 -39.556 -39.556 -4.13774
3.42885 -42.1961 -42.1961 -4.14468
3.43423 -44.7803 -44.7803 -4.15162
3.43961 -47.2889 -47.2889 -4.15857
3.44499 -49.7031 -49.7031 -4.16551
3.45037 -52.0044 -52.0044 -4.17245
3.45575 -54.1754 -54.1754 -4.17939
3.46112 -56.1996 -56.1996 -4.18634
3.4665 -58.0618 -58.0618 -4.19328
3.47187 -59.7479 -59.7479 -4.20022
3.47724 -61.2451 -61.2451 -4.20716
3.48261 -62.5421 -62.5421 -4.21411
3.48798 -63.6292 -63.6292 -4.22105
3.49335 -64.4981 -64.4981 -4.22799
3.49872 -65.1425 -65.1425 -4.23493
3.50408 -65.5574 -65.5574 -4.24188
3.50945 -65.7399 -65.7399 -4.24882
3.51481 -65.6886 -65.6886 -4.25576
3.52017 -65.4041 -65.4041 -4.2627
3.52553 -64.8886 -64.8886 -4.26965
3.53089 -64.1462 -64.1462 -4.27659
3.53625 -63.1825 -63.1825 -4.28353
3.54161 -62.005 -62.005 -4.29047
3.54696 -60.6229 -60.6229 -4.29742
3.55232 -59.0465 -59.0465 -4.30436
3.55767 -57.2881 -57.2881 -4.3113
3.56302 -55.3611 -55.3611 -4.31824
3.56838 -53.2801 -53.2801 -4.32519
3.57373 -51.0612 -51.0612 -4.33213
3.57907 -48.7212 -48.7212 -4.33907
3.58442 -46.2779 -46.2779 -4.34601
3.58977 -43.75 -43.75 -4.35296
3.59511 -41.1568 -41.1568 -4.3599
3.60046 -38.5179 -38.5179 -4.36684
3.6058 -35.8535 -35.8535 -4.37379
3.61114 -33.1838 -33.1838 -4.38073
3.61648 -30.5291 -30.5291 -4.38767
3.62182 -27.9096 -27.9096 -4.39461
3.62716 -25.3452 -25.3452 -4.40156
3.6325 -22.8554 -22.8554 -4.4085
3.63783 -20.4589 -20.4589 -4.41544
3.64317 -18.1741 -18.1741 -4.42238
3.6485 -16.0183 -16.0183 -4.42933
3.65383 -14.0077 -14.0077 -4.43627
3.65916 -12.1576 -12.1576 -4.44321
3.66449 -10.4819 -10.4819 -4.45015
3.66982 -8.99342 -8.99342 -4.4571
3.67515 -7.70327 -7.70327 -4.46404
3.68047 -6.6212 -6.6212 -4.47098
3.6858 -5.75533 -5.75533 -4.47792
3.69112 -5.11215 -5.11215 -4.48487
3.69644 -4.69645 -4.69645 -4.49181
3.70176 -4.51128 -4.51128 -4.49875
3.70708 -4.55795 -4.55795 -4.50569
3.7124 -4.836 -4.836 -4.51264
3.71772 -5.34321 -5.34321 -4.51958
3.72303 -6.07561 -6.07561 -4.52652
3.72835 -7.02755 -7.02755 -4.53346
3.73366 -8.19167 -8.19167 -4.54041
3.73898 -9.55904 -9.55904 -4.54735
3.74429 -11.1192 -11.1192 -4.55429
3.7496 -12.8601 -12.8601 -4.56123
3.75491 -14.7686 -14.7686 -4.56818
3.76021 -16.8299 -16.8299 -4.57512
3.76552 -19.0284 -19.0284 -4.58206
3.77082 -21.3474 -21.3474 -4.589
3.77613 -23.769 -23.769 -4.59595
3.78143 -26.275 -26.275 -4.60289
3.78673 -28.846 -28.846 -4.60983
3.79203 -31.4627 -31.4627 -4.61677
3.79733 -34.1051 -34.1051 -4.62372
3.80263 -36.7531 -36.7531 -4.63066
3.80793 -39.3866 -39.3866 -4.6376
3.81322 -41.9854 -41.9854 -4.64454
3.81852 -44.5301 -44.5301 -4.65149
3.82381 -47.0011 -47.0011 -4.65843
3.8291 -49.3797 -49.3797 -4.66537
3.83439 -51.648 -51.648 -4.67231
3.83968 -53.7886 -53.7886 -4.67926
3.84497 -55.7855 -55.7855 -4.6862
3.85026 -57.6235 -57.6235 -4.69314
3.85554 -59.2887 -59.2887 -4.70008
3.86083 -60.7684 -60.7684 -4.70703
3.86611 -62.0517 -62.0517 -4.71397
3.87139 -63.1287 -63.1287 -4.72091
3.87667 -63.9914 -63.9914 -4.72785
3.88195 -64.6333 -64.6333 -4.7348
3.88723 -65.0497 -65.0497 -4.74174
3.89251 -65.2375 -65.2375 -4.74868
3.89779 -65.1953 -65.1953 -4.75562
3.90306 -64.9237 -64.9237 -4.76257
3.90833 -64.4247 -64.4247 -4.76951
3.91361 -63.7023 -63.7023 -4.77645
3.91888 -62.762 -62.762 -4.78339
3.92415 -61.6112 -61.6112 -4.79034
3.92942 -60.2586 -60.2586 -4.79728
3.93469 -58.7146 -58.7146 -4.80422
3.93995 -56.9911 -56.9911 -4.81116
3.94522 -55.1012 -55.1012 -4.81811
3.95048 -53.0593 -53.0593 -4.82505
3.95574 -50.8812 -50.8812 -4.83199
3.96101 -48.5833 -48.5833 -4.83893
3.96627 -46.1833 -46.1833 -4.84588
3.97152 -43.6993 -43.6993 -4.85282
3.97678 -41.1504 -41.1504 -4.85976
3.98204 -38.5558 -38.5558 -4.8667
3.9873 -35.9355 -35.9355 -4.87365
3.99255 -33.3092 -33.3092 -4.88059
3.9978 -30.697 -30.697 -4.88753
4.00305 -28.1187 -28.1187 -4.89447
4.00831 -25.594 -25.594 -4.90142
4.01355 -23.1418 -23.1418 -4.90836
4.0188 -20.781 -20.781 -4.9153
4.02405 -18.5293 -18.5293 -4.92224
4.0293 -16.4038 -16.4038 -4.92919
4.03454 -14.4207 -14.4207 -4.93613
4.03978 -12.595 -12.595 -4.94307
4.04503 -10.9403 -10.9403 -4.95001
4.05027 -9.46936 -9.46936 -4.95696
4.05551 -8.19313 -8.19313 -4.9639
4.06075 -7.12125 -7.12125 -4.97084
4.06598 -6.26179 -6.26179 -4.97778
4.07122 -5.62117 -5.62117 -4.98473
4.07645 -5.20416 -5.20416 -4.99167
4.08169 -5.01383 -5.01383 -4.99861
4.08692 -5.05152 -5.05152 -5.00555
4.09215 -5.31684 -5.31684 -5.0125
4.09738 -5.80766 -5.80766 -5.01944
4.10261 -6.52016 -6.52016 -5.02638
4.10784 -7.4488 -7.4488 -5.03332
4.11307 -8.58644 -8.58644 -5.04027
4.11829 -9.92433 -9.92433 -5.04721
4.12351 -11.4522 -11.4522 -5.05415
4.12874 -13.1584 -13.1584 -5.06109
4.13396 -15.0298 -15.0298 -5.06804
4.13918 -17.0521 -17.0521 -5.07498
4.1444 -19.2099 -19.2099 -5.08192
4.14962 -21.4867 -21.4867 -5.08886
4.15483 -23.8652 -23.8652 -5.09581
4.16005 -26.3272 -26.3272 -5.10275
4.16526 -28.8541 -28.8541 -5.10969
4.17048 -31.4264 -31.4264 -5.11663
4.17569 -34.0247 -34.0247 -5.12358
4.1809 -36.6292 -36.6292 -5.13052
4.18611 -39.2202 -39.2202 -5.13746
4.19132 -41.7778 -41.7778 -5.1444
4.19652 -44.2828 -44.2828 -5.15135
4.20173 -46.716 -46.716 -5.15829
4.20694 -49.059 -49.059 -5.16523
4.21214 -51.2941 -51.2941 -5.17217
4.21734 -53.4043 -53.4043 -5.17912
4.22254 -55.3736 -55.3736 -5.18606
4.22774 -57.1871 -57.1871 -5.193
4.23294 -58.8311 -58.8311 -5.19994
4.23814 -60.2932 -60.2932 -5.20689
4.24333 -61.5624 -61.5624 -5.21383
4.24853 -62.629 -62.629 -5.22077
4.25372 -63.4852 -63.4852 -5.22771
4.25892 -64.1244 -64.1244 -5.23466
4.26411 -64.542 -64.542 -5.2416
4.2693 -64.7348 -64.7348 -5.24854
4.27449 -64.7015 -64.7015 -5.25548
4.27967 -64.4425 -64.4425 -5.26243
4.28486 -63.9597 -63.9597 -5.26937
4.29005 -63.2571 -63.2571 -5.27631
4.29523 -62.34 -62.34 -5.28325
4.30041 -61.2155 -61.2155 -5.2902
4.3056 -59.8923 -59.8923 -5.29714
4.31078 -58.3805 -58.3805 -5.30408
4.31595 -56.6916 -56.6916 -5.31102
4.32113 -54.8387 -54.8387 -5.31797
4.32631 -52.8358 -52.8358 -5.32491
4.33149 -50.6983 -50.6983 -5.33185
4.33666 -48.4425 -48.4425 -5.33879
4.34183 -46.0855 -46.0855 -5.34574
4.34701 -43.6454 -43.6454 -5.35268
4.35218 -41.1407 -41.1407 -5.35962
4.35735 -38.5906 -38.5906 -5.36656
4.36251 -36.0143 -36.0143 -5.37351
4.36768 -33.4315 -33.4315 -5.38045
4.37285 -30.8618 -30.8618 -5.38739
4.37801 -28.3248 -28.3248 -5.39433
4.38318 -25.8398 -25.8398 -5.40128
4.38834 -23.4255 -23.4255 -5.40822
4.3935 -21.1003 -21.1003 -5.41516
4.39866 -18.8819 -18.8819 -5.4221
4.40382 -16.7871 -16.7871 -5.42905
4.40898 -14.8316 -14.8316 -5.43599
4.41413 -13.0304 -13.0304 -5.44293
4.41929 -11.3971 -11.3971 -5.44988
4.42444 -9.94387 -9.94387 -5.45682
4.42959 -8.68182 -8.68182 -5.46376
4.43474 -7.62041 -7.62041 -5.4707
4.43989 -6.76762 -6.76762 -5.47765
4.44504 -6.12984 -6.12984 -5.48459
4.45019 -5.7118 -5.7118 -5.49153
4.45534 -5.51658 -5.51658 -5.49847
4.46048 -5.54557 -5.54557 -5.50542
4.46563 -5.79843 -5.79843 -5.51236
4.47077 -6.27314 -6.27314 -5.5193
4.47591 -6.96598 -6.96598 -5.52624
4.48105 -7.87159 -7.87159 -5.53319
4.48619 -8.98298 -8.98298 -5.54013
4.49133 -10.2916 -10.2916 -5.54707
4.49647 -11.7874 -11.7874 -5.55401
4.5016 -13.459 -13.459 -5.56096
4.50674 -15.2935 -15.2935 -5.5679
4.51187 -17.277 -17.277 -5.57484
4.517 -19.3942 -19.3942 -5.58178
4.52213 -21.629 -21.629 -5.58873
4.52726 -23.9645 -23.9645 -5.59567
4.53239 -26.3827 -26.3827 -5.60261
4.53752 -28.8653 -28.8653 -5.60955
4.54264 -31.3933 -31.3933 -5.6165
4.54777 -33.9475 -33.9475 -5.62344
4.55289 -36.5086 -36.5086 -5.63038
4.55802 -39.0569 -39.0569 -5.63732
4.56314 -41.5733 -41.5733 -5.64427
4.56826 -44.0384 -44.0384 -5.65121
4.57338 -46.4337 -46.4337 -5.65815
4.57849 -48.741 -48.741 -5.66509
4.58361 -50.9427 -50.9427 -5.67204
4.58872 -53.0222 -53.0222 -5.67898
4.59384 -54.9637 -54.9637 -5.68592
4.59895 -56.7525 -56.7525 -5.69286
4.60406 -58.3752 -58.3752 -5.69981
4.60917 -59.8194 -59.8194 -5.70675
4.61428 -61.0743 -61.0743 -5.71369
4.61939 -62.1304 -62.1304 -5.72063
4.6245 -62.9797 -62.9797 -5.72758
4.6296 -63.616 -63.616 -5.73452
4.63471 -64.0344 -64.0344 -5.74146
4.63981 -64.232 -64.232 -5.7484
4.64491 -64.2072 -64.2072 -5.75535
4.65001 -63.9605 -63.9605 -5.76229
4.65511 -63.4937 -63.4937 -5.76923
4.66021 -62.8106 -62.8106 -5.77617
4.66531 -61.9164 -61.9164 -5.78312
4.6704 -60.8181 -60.8181 -5.79006
4.6755 -59.524 -59.524 -5.797
4.68059 -58.0441 -58.0441 -5.80394
4.68568 -56.3898 -56.3898 -5.81089
4.69077 -54.5736 -54.5736 -5.81783
4.69586 -52.6096 -52.6096 -5.82477
4.70095 -50.5126 -50.5126 -5.83171
4.70604 -48.2987 -48.2987 -5.83866
4.71112 -45.9848 -45.9848 -5.8456
4.71621 -43.5884 -43.5884 -5.85254
4.72129 -41.128 -41.128 -5.85948
4.72638 -38.6221 -38.6221 -5.86643
4.73146 -36.0899 -36.0899 -5.87337
4.73654 -33.5506 -33.5506 -5.88031
4.74162 -31.0235 -31.0235 -5.88725
4.74669 -28.5279 -28.5279 -5.8942
4.75177 -26.0827 -26.0827 -5.90114
4.75684 -23.7064 -23.7064 -5.90808
4.76192 -21.417 -21.417 -5.91502
4.76699 -19.2321 -19.2321 -5.92197
4.77206 -17.168 -17.168 -5.92891
4.77713 -15.2404 -15.2404 -5.93585
4.7822 -13.464 -13.464 -5.94279
4.78727 -11.8521 -11.8521 -5.94974
4.79234 -10.417 -10.417 -5.95668
4.7974 -9.16933 -9.16933 -5.96362
4.80247 -8.11866 -8.11866 -5.97056
4.80753 -7.27281 -7.27281 -5.97751
4.81259 -6.63813 -6.63813 -5.98445
4.81765 -6.21934 -6.21934 -5.99139
4.82271 -6.01952 -6.01952 -5.99833
4.82777 -6.04008 -6.04008 -6.00528
4.83283 -6.28075 -6.28075 -6.01222
4.83788 -6.73962 -6.73962 -6.01916
4.84294 -7.41307 -7.41307 -6.0261
4.84799 -8.2959 -8.2959 -6.03305
4.85304 -9.38128 -9.38128 -6.03999
4.85809 -10.6609 -10.6609 -6.04693
4.86314 -12.1249 -12.1249 -6.05387
4.86819 -13.762 -13.762 -6.06082
4.87324 -15.5599 -15.5599 -6.06776
4.87829 -17.5046 -17.5046 -6.0747
4.88333 -19.5814 -19.5814 -6.08164
4.88837 -21.7743 -21.7743 -6.08859
4.89342 -24.0668 -24.0668 -6.09553
4.89846 -26.4412 -26.4412 -6.10247
4.9035 -28.8796 -28.8796 -6.10941
4.90854 -31.3633 -31.3633 -6.11636
4.91357 -33.8735 -33.8735 -6.1233
4.91861 -36.3911 -36.3911 -6.13024
4.92365 -38.8968 -38.8968 -6.13718
4.92868 -41.3717 -41.3717 -6.14413
4.93371 -43.797 -43.797 -6.15107
4.93874 -46.1543 -46.1543 -6.15801
4.94377 -48.4256 -48.4256 -6.16495
4.9488 -50.5938 -50.5938 -6.1719
4.95383 -52.6424 -52.6424 -6.17884
4.95886 -54.556 -54.556 -6.18578
4.96388 -56.3199 -56.3199 -6.19272
4.96891 -57.921 -57.921 -6.19967
4.97393 -59.3471 -59.3471 -6.20661
4.97895 -60.5874 -60.5874 -6.21355
4.98397 -61.6326 -61.6326 -6.22049
4.98899 -62.4748 -62.4748 -6.22744
4.99401 -63.1079 -63.1079 -6.23438
4.99903 -63.5269 -63.5269 -6.24132
5.00404 -63.7289 -63.7289 -6.24826
5.00906 -63.7125 -63.7125 -6.25521
5.01407 -63.4778 -63.4778 -6.26215
5.01908 -63.0268 -63.0268 -6.26909
5.0241 -62.3629 -62.3629 -6.27603
5.02911 -61.4914 -61.4914 -6.28298
5.03411 -60.4189 -60.4189 -6.28992
5.03912 -59.1537 -59.1537 -6.29686
5.04413 -57.7056 -57.7056 -6.3038
5.04913 -56.0855 -56.0855 -6.31075
5.05414 -54.306 -54.306 -6.31769
5.05914 -52.3806 -52.3806 -6.32463
5.06414 -50.324 -50.324 -6.33157
5.06914 -48.1519 -48.1519 -6.33852
5.07414 -45.8809 -45.8809 -6.34546
5.07914 -43.5283 -43.5283 -6.3524
5.08413 -41.112 -41.112 -6.35934
5.08913 -38.6504 -38.6504 -6.36629
5.09412 -36.1623 -36.1623 -6.37323
5.09912 -33.6665 -33.6665 -6.38017
5.10411 -31.1821 -31.1821 -6.38711
5.1091 -28.7279 -28.7279 -6.39406
5.11409 -26.3226 -26.3226 -6.401
5.11907 -23.9844 -23.9844 -6.40794
5.12406 -21.7311 -21.7311 -6.41488
5.12905 -19.5797 -19.5797 -6.42183
5.13403 -17.5466 -17.5466 -6.42877
5.13901 -15.6471 -15.6471 -6.43571
5.144 -13.8957 -13.8957 -6.44265
5.14898 -12.3055 -12.3055 -6.4496
5.15396 -10.8886 -10.8886 -6.45654
5.15894 -9.65565 -9.65565 -6.46348
5.16391 -8.61597 -8.61597 -6.47042
5.16889 -7.77734 -7.77734 -6.47737
5.17386 -7.14605 -7.14605 -6.48431
5.17884 -6.72678 -6.72678 -6.49125
5.18381 -6.52263 -6.52263 -6.49819
5.18878 -6.53504 -6.53504 -6.50514
5.19375 -6.7638 -6.7638 -6.51208
5.19872 -7.20709 -7.20709 -6.51902
5.20369 -7.86142 -7.86142 -6.52597
5.20865 -8.72171 -8.72171 -6.53291
5.21362 -9.78133 -9.78133 -6.53985
5.21858 -11.0321 -11.0321 -6.54679
5.22354 -12.4645 -12.4645 -6.55374
5.2285 -14.0674 -14.0674 -6.56068
5.23346 -15.8287 -15.8287 -6.56762
5.23842 -17.7349 -17.7349 -6.57456
5.24338 -19.7714 -19.7714 -6.58151
5.24834 -21.9226 -21.9226 -6.58845
5.25329 -24.1722 -24.1722 -6.59539
5.25825 -26.5029 -26.5029 -6.60233
5.2632 -28.8972 -28.8972 -6.60928
5.26815 -31.3366 -31.3366 -6.61622
5.2731 -33.8027 -33.8027 -6.62316
5.27805 -36.2767 -36.2767 -6.6301
5.283 -38.7398 -38.7398 -6.63705
5.28795 -41.1732 -41.1732 -6.64399
5.29289 -43.5585 -43.5585 -6.65093
5.29784 -45.8777 -45.8777 -6.65787
5.30278 -48.1129 -48.1129 -6.66482
5.30772 -50.2475 -50.2475 -6.67176
5.31266 -52.265 -52.265 -6.6787
5.3176 -54.1504 -54.1504 -6.68564
5.32254 -55.8892 -55.8892 -6.69259
5.32748 -57.4685 -57.4685 -6.69953
5.33241 -58.8762 -58.8762 -6.70647
5.33735 -60.1016 -60.1016 -6.71341
5.34228 -61.1357 -61.1357 -6.72036
5.34721 -61.9706 -61.9706 -6.7273
5.35215 -62.6001 -62.6001 -6.73424
5.35708 -63.0196 -63.0196 -6.74118
5.362 -63.2258 -63.2258 -6.74813
5.36693 -63.2173 -63.2173 -6.75507
5.37186 -62.9944 -62.9944 -6.76201
5.37678 -62.5588 -62.5588 -6.76895
5.38171 -61.914 -61.914 -6.7759
5.38663 -61.0648 -61.0648 -6.78284
5.39155 -60.018 -60.018 -6.78978
5.39647 -58.7815 -58.7815 -6.79672
5.40139 -57.3649 -57.3649 -6.80367
5.40631 -55.779 -55.779 -6.81061
5.41122 -54.0359 -54.0359 -6.81755
5.41614 -52.1489 -52.1489 -6.82449
5.42105 -50.1326 -50.1326 -6.83144
5.42597 -48.0022 -48.0022 -6.83838
5.43088 -45.774 -45.774 -6.84532
5.43579 -43.465 -43.465 -6.85226
5.4407 -41.0929 -41.0929 -6.85921
5.44561 -38.6756 -38.6756 -6.86615
5.45051 -36.2315 -36.2315 -6.87309
5.45542 -33.7793 -33.7793 -6.88003
5.46032 -31.3376 -31.3376 -6.88698
5.46523 -28.9249 -28.9249 -6.89392
5.47013 -26.5596 -26.5596 -6.90086
5.47503 -24.2596 -24.2596 -6.9078
5.47993 -22.0424 -22.0424 -6.91475
5.48483 -19.9248 -19.9248 -6.92169
5.48972 -17.9228 -17.9228 -6.92863
5.49462 -16.0516 -16.0516 -6.93557
5.49952 -14.3254 -14.3254 -6.94252
5.50441 -12.7571 -12.7571 -6.94946
5.5093 -11.3588 -11.3588 -6.9564
5.51419 -10.1408 -10.1408 -6.96334
5.51908 -9.11234 -9.11234 -6.97029
5.52397 -8.2812 -8.2812 -6.97723
5.52886 -7.65356 -7.65356 -6.98417
5.53374 -7.2341 -7.2341 -6.99111
5.53863 -7.02589 -7.02589 -6.99806
5.54351 -7.03043 -7.03043 -7.005
5.5484 -7.24756 -7.24756 -7.01194
5.55328 -7.67554 -7.67554 -7.01888
5.55816 -8.311 -8.311 -7.02583
5.56304 -9.14901 -9.14901 -7.03277
5.56791 -10.1831 -10.1831 -7.03971
5.57279 -11.4053 -11.4053 -7.04665
5.57767 -12.8063 -12.8063 -7.0536
5.58254 -14.3752 -14.3752 -7.06054
5.58741 -16.1002 -16.1002 -7.06748
5.59229 -17.9679 -17.9679 -7.07442
5.59716 -19.9642 -19.9642 -7.08137
5.60203 -22.0738 -22.0738 -7.08831
5.60689 -24.2806 -24.2806 -7.09525
5.61176 -26.5678 -26.5678 -7.10219
5.61663 -28.9179 -28.9179 -7.10914
5.62149 -31.3131 -31.3131 -7.11608
5.62635 -33.7351 -33.7351 -7.12302
5.63122 -36.1655 -36.1655 -7.12996
5.63608 -38.5859 -38.5859 -7.13691
5.64094 -40.9778 -40.9778 -7.14385
5.6458 -43.323 -43.323 -7.15079
5.65065 -45.6039 -45.6039 -7.15773
5.65551 -47.803 -47.803 -7.16468
5.66036 -49.9036 -49.9036 -7.17162
5.66522 -51.89 -51.89 -7.17856
5.67007 -53.7469 -53.7469 -7.1855
5.67492 -55.4605 -55.4605 -7.19245
5.67977 -57.0177 -57.0177 -7.19939
5.68462 -58.4067 -58.4067 -7.20633
5.68947 -59.6171 -59.6171 -7.21327
5.69431 -60.6398 -60.6398 -7.22022
5.69916 -61.4671 -61.4671 -7.22716
5.704 -62.0928 -62.0928 -7.2341
5.70885 -62.5123 -62.5123 -7.24104
5.71369 -62.7224 -62.7224 -7.24799
5.71853 -62.7217 -62.7217 -7.25493
5.72337 -62.5103 -62.5103 -7.26187
5.7282 -62.0899 -62.0899 -7.26881
5.73304 -61.4637 -61.4637 -7.27576
5.73788 -60.6368 -60.6368 -7.2827
5.74271 -59.6154 -59.6154 -7.28964
5.74754 -58.4074 -58.4074 -7.29658
5.75238 -57.022 -57.022 -7.30353
5.75721 -55.47 -55.47 -7.31047
5.76204 -53.7632 -53.7632 -7.31741
5.76686 -51.9145 -51.9145 -7.32435
5.77169 -49.9383 -49.9383 -7.3313
5.77652 -47.8495 -47.8495 -7.33824
5.78134 -45.6641 -45.6641 -7.34518
5.78616 -43.3987 -43.3987 -7.35212
5.79099 -41.0706 -41.0706 -7.35907
5.79581 -38.6975 -38.6975 -7.36601
5.80063 -36.2975 -36.2975 -7.37295
5.80545 -33.8889 -33.8889 -7.37989
5.81026 -31.4899 -31.4899 -7.38684
5.81508 -29.1188 -29.1188 -7.39378
5.81989 -26.7936 -26.7936 -7.40072
5.82471 -24.532 -24.532 -7.40766
5.82952 -22.351 -22.351 -7.41461
5.83433 -20.2673 -20.2673 -7.42155
5.83914 -18.2967 -18.2967 -7.42849
5.84395 -16.4539 -16.4539 -7.43543
5.84876 -14.7531 -14.7531 -7.44238
5.85356 -13.2071 -13.2071 -7.44932
5.85837 -11.8275 -11.8275 -7.45626
5.86317 -10.6247 -10.6247 -7.4632
5.86798 -9.60775 -9.60775 -7.47015
5.87278 -8.78436 -8.78436 -7.47709
5.87758 -8.16066 -8.16066 -7.48403
5.88238 -7.74128 -7.74128 -7.49097
5.88717 -7.5293 -7.5293 -7.49792
5.89197 -7.52624 -7.52624 -7.50486
5.89677 -7.73202 -7.73202 -7.5118
5.90156 -8.14495 -8.14495 -7.51874
5.90635 -8.76181 -8.76181 -7.52569
5.91115 -9.57779 -9.57779 -7.53263
5.91594 -10.5866 -10.5866 -7.53957
5.92073 -11.7805 -11.7805 -7.54651
5.92551 -13.1502 -13.1502 -7.55346
5.9303 -14.6854 -14.6854 -7.5604
5.93509 -16.3742 -16.3742 -7.56734
5.93987 -18.2037 -18.2037 -7.57428
5.94466 -20.1599 -20.1599 -7.58123
5.94944 -22.228 -22.228 -7.58817
5.95422 -24.3921 -24.3921 -7.59511
5.959 -26.6357 -26.6357 -7.60205
5.96378 -28.9418 -28.9418 -7.609
5.96855 -31.2927 -31.2927 -7.61594
5.97333 -33.6707 -33.6707 -7.62288
5.97811 -36.0575 -36.0575 -7.62983
5.98288 -38.4351 -38.4351 -7.63677
5.98765 -40.7854 -40.7854 -7.64371
5.99242 -43.0905 -43.0905 -7.65065
5.99719 -45.3329 -45.3329 -7.6576
6.00196 -47.4957 -47.4957 -7.66454
6.00673 -49.5623 -49.5623 -7.67148
6.0115 -51.5173 -51.5173 -7.67842
6.01626 -53.3457 -53.3457 -7.68537
6.02102 -55.0337 -55.0337 -7.69231
6.02579 -56.5686 -56.5686 -7.69925
6.03055 -57.9387 -57.9387 -7.70619
6.03531 -59.1339 -59.1339 -7.71314
6.04007 -60.1449 -60.1449 -7.72008
6.04483 -60.9643 -60.9643 -7.72702
6.04958 -61.5859 -61.5859 -7.73396
6.05434 -62.0052 -62.0052 -7.74091
6.05909 -62.2189 -62.2189 -7.74785
6.06385 -62.2257 -62.2257 -7.75479
6.0686 -62.0255 -62.0255 -7.76173
6.07335 -61.62 -61.62 -7.76868
6.0781 -61.0123 -61.0123 -7.77562
6.08285 -60.2073 -60.2073 -7.78256
6.08759 -59.211 -59.211 -7.7895
6.09234 -58.0312 -58.0312 -7.79645
6.09708 -56.677 -56.677 -7.80339
6.10183 -55.1587 -55.1587 -7.81033
6.10657 -53.4879 -53.4879 -7.81727
6.11131 -51.6775 -51.6775 -7.82422
6.11605 -49.7412 -49.7412 -7.83116
6.12079 -47.6938 -47.6938 -7.8381
6.12553 -45.5511 -45.5511 -7.84504
6.13026 -43.3292 -43.3292 -7.85199
6.135 -41.0451 -41.0451 -7.85893
6.13973 -38.7163 -38.7163 -7.86587
6.14446 -36.3604 -36.3604 -7.87281
6.1492 -33.9953 -33.9953 -7.87976
6.15393 -31.6391 -31.6391 -7.8867
6.15865 -29.3097 -29.3097 -7.89364
6.16338 -27.0247 -27.0247 -7.90058
6.16811 -24.8015 -24.8015 -7.90753
6.17283 -22.657 -22.657 -7.91447
6.17756 -20.6074 -20.6074 -7.92141
6.18228 -18.6682 -18.6682 -7.92835
6.187 -16.8541 -16.8541 -7.9353
6.19172 -15.179 -15.179 -7.94224
6.19644 -13.6553 -13.6553 -7.94918
6.20116 -12.2947 -12.2947 -7.95612
6.20588 -11.1073 -11.1073 -7.96307
6.21059 -10.1022 -10.1022 -7.97001
6.21531 -9.28683 -9.28683 -7.97695
6.22002 -8.66733 -8.66733 -7.98389
6.22473 -8.24831 -8.24831 -7.99084
6.22944 -8.03284 -8.03284 -7.99778
6.23415 -8.02246 -8.02246 -8.00472
6.23886 -8.21715 -8.21715 -8.01166
6.24357 -8.61532 -8.61532 -8.01861
6.24827 -9.21383 -9.21383 -8.02555
6.25298 -10.008 -10.008 -8.03249
6.25768 -10.9918 -10.9918 -8.03943
6.26238 -12.1576 -12.1576 -8.04638
6.26709 -13.4963 -13.4963 -8.05332
6.27179 -14.9979 -14.9979 -8.06026
6.27648 -16.6506 -16.6506 -8.0672
6.28118 -18.4421 -18.4421 -8.07415
6.28588 -20.3584 -20.3584 -8.08109
6.29057 -22.3851 -22.3851 -8.08803
6.29527 -24.5066 -24.5066 -8.09497
6.29996 -26.7068 -26.7068 -8.10192
6.30465 -28.9688 -28.9688 -8.10886
6.30934 -31.2756 -31.2756 -8.1158
6.31403 -33.6094 -33.6094 -8.12274
6.31872 -35.9526 -35.9526 -8.12969
6.3234 -38.2874 -38.2874 -8.13663
6.32809 -40.596 -40.596 -8.14357
6.33277 -42.8609 -42.8609 -8.15051
6.33746 -45.0648 -45.0648 -8.15746
6.34214 -47.1911 -47.1911 -8.1644
6.34682 -49.2236 -49.2236 -8.17134
6.3515 -51.1469 -51.1469 -8.17828
6.35618 -52.9466 -52.9466 -8.18523
6.36085 -54.6089 -54.6089 -8.19217
6.36553 -56.1212 -56.1212 -8.19911
6.3702 -57.4723 -57.4723 -8.20605
6.37488 -58.6518 -58.6518 -8.213
6.37955 -59.651 -59.651 -8.21994
6.38422 -60.4622 -60.4622 -8.22688
6.38889 -61.0795 -61.0795 -8.23382
6.39356 -61.4982 -61.4982 -8.24077
6.39822 -61.7154 -61.7154 -8.24771
6.40289 -61.7293 -61.7293 -8.25465
6.40755 -61.54 -61.54 -8.26159
6.41222 -61.1491 -61.1491 -8.26854
6.41688 -60.5597 -60.5597 -8.27548
6.42154 -59.7763 -59.7763 -8.28242
6.4262 -58.805 -58.805 -8.28936
6.43086 -57.6532 -57.6532 -8.29631
6.43552 -56.3298 -56.3298 -8.30325
6.44017 -54.845 -54.845 -8.31019
6.44483 -53.2102 -53.2102 -8.31713
6.44948 -51.4377 -51.4377 -8.32408
6.45414 -49.5413 -49.5413 -8.33102
6.45879 -47.5353 -47.5353 -8.33796
6.46344 -45.435 -45.435 -8.3449
6.46809 -43.2566 -43.2566 -8.35185
6.47273 -41.0165 -41.0165 -8.35879
6.47738 -38.7318 -38.7318 -8.36573
6.48203 -36.42 -36.42 -8.37267
6.48667 -34.0986 -34.0986 -8.37962
6.49131 -31.7852 -31.7852 -8.38656
6.49595 -29.4975 -29.4975 -8.3935
6.5006 -27.2528 -27.2528 -8.40044
6.50523 -25.0682 -25.0682 -8.40739
6.50987 -22.9602 -22.9602 -8.41433
6.51451 -20.9448 -20.9448 -8.42127
6.51915 -19.0373 -19.0373 -8.42821
6.52378 -17.2522 -17.2522 -8.43516
6.52841 -15.6028 -15.6028 -8.4421
6.53305 -14.1018 -14.1018 -8.44904
6.53768 -12.7604 -12.7604 -8.45598
6.54231 -11.5887 -11.5887 -8.46293
6.54693 -10.5956 -10.5956 -8.46987
6.55156 -9.78857 -9.78857 -8.47681
6.55619 -9.17355 -9.17355 -8.48375
6.56081 -8.75517 -8.75517 -8.4907
6.56544 -8.53649 -8.53649 -8.49764
6.57006 -8.51907 -8.51907 -8.50458
6.57468 -8.70295 -8.70295 -8.51152
6.5793 -9.08661 -9.08661 -8.51847
6.58392 -9.66704 -9.66704 -8.52541
6.58854 -10.4397 -10.4397 -8.53235
6.59315 -11.3987 -11.3987 -8.53929
6.59777 -12.5366 -12.5366 -8.54624
6.60238 -13.8446 -13.8446 -8.55318
6.60699 -15.3127 -15.3127 -8.56012
6.6116 -16.9297 -16.9297 -8.56706
6.61622 -18.6832 -18.6832 -8.57401
6.62082 -20.5598 -20.5598 -8.58095
6.62543 -22.5451 -22.5451 -8.58789
6.63004 -24.6241 -24.6241 -8.59483
6.63464 -26.7809 -26.7809 -8.60178
6.63925 -28.999 -28.999 -8.60872
6.64385 -31.2616 -31.2616 -8.61566
6.64845 -33.5514 -33.5514 -8.6226
6.65305 -35.851 -35.851 -8.62955
6.65765 -38.1429 -38.1429 -8.63649
6.66225 -40.4097 -40.4097 -8.64343
6.66685 -42.6342 -42.6342 -8.65037
6.67144 -44.7995 -44.7995 -8.65732
6.67604 -46.8892 -46.8892 -8.66426
6.68063 -48.8874 -48.8874 -8.6712
6.68522 -50.779 -50.779 -8.67814
6.68981 -52.5497 -52.5497 -8.68509
6.6944 -54.186 -54.186 -8.69203
6.69899 -55.6756 -55.6756 -8.69897
6.70358 -57.0073 -57.0073 -8.70592
6.70817 -58.171 -58.171 -8.71286
6.71275 -59.158 -59.158 -8.7198
6.71733 -59.9608 -59.9608 -8.72674
6.72192 -60.5735 -60.5735 -8.73369
6.7265 -60.9915 -60.9915 -8.74063
6.73108 -61.2116 -61.2116 -8.74757
6.73566 -61.2325 -61.2325 -8.75451
6.74023 -61.0539 -61.0539 -8.76146
6.74481 -60.6774 -60.6774 -8.7684
6.74939 -60.1059 -60.1059 -8.77534
6.75396 -59.3439 -59.3439 -8.78228
6.75853 -58.3972 -58.3972 -8.78923
6.7631 -57.2732 -57.2732 -8.79617
6.76767 -55.9805 -55.9805 -8.80311
6.77224 -54.529 -54.529 -8.81005
6.77681 -52.9299 -52.9299 -8.817
6.78138 -51.1953 -51.1953 -8.82394
6.78594 -49.3385 -49.3385 -8.83088
6.79051 -47.3737 -47.3737 -8.83782
6.79507 -45.3159 -45.3159 -8.84477
6.79963 -43.1808 -43.1808 -8.85171
6.80419 -40.9847 -40.9847 -8.85865
6.80875 -38.7442 -38.7442 -8.86559
6.81331 -36.4764 -36.4764 -8.87254
6.81787 -34.1987 -34.1987 -8.87948
6.82242 -31.9282 -31.9282 -8.88642
6.82698 -29.6823 -29.6823 -8.89336
6.83153 -27.478 -27.478 -8.90031
6.83608 -25.332 -25.332 -8.90725
6.84064 -23.2607 -23.2607 -8.91419
6.84518 -21.2797 -21.2797 -8.92113
6.84973 -19.4041 -19.4041 -8.92808
6.85428 -17.648 -17.648 -8.93502
6.85883 -16.0247 -16.0247 -8.94196
6.86337 -14.5465 -14.5465 -8.9489
6.86792 -13.2246 -13.2246 -8.95585
6.87246 -12.0689 -12.0689 -8.96279
6.877 -11.0881 -11.0881 -8.96973
6.88154 -10.2896 -10.2896 -8.97667
6.88608 -9.67932 -9.67932 -8.98362
6.89062 -9.26184 -9.26184 -8.99056
6.89515 -9.04023 -9.04023 -8.9975
6.89969 -9.01605 -9.01605 -9.00444
6.90422 -9.18939 -9.18939 -9.01139
6.90875 -9.55883 -9.55883 -9.01833
6.91329 -10.1214 -10.1214 -9.02527
6.91782 -10.8729 -10.8729 -9.03221
6.92234 -11.8073 -11.8073 -9.03916
6.92687 -12.9175 -12.9175 -9.0461
6.9314 -14.1949 -14.1949 -9.05304
6.93593 -15.6298 -15.6298 -9.05998
6.94045 -17.2112 -17.2112 -9.06693
6.94497 -18.9269 -18.9269 -9.07387
6.94949 -20.7639 -20.7639 -9.08081
6.95402 -22.7081 -22.7081 -9.08775
6.95853 -24.7447 -24.7447 -9.0947
6.96305 -26.8582 -26.8582 -9.10164
6.96757 -29.0324 -29.0324 -9.10858
6.97209 -31.2508 -31.2508 -9.11552
6.9766 -33.4965 -33.4965 -9.12247
6.98111 -35.7525 -35.7525 -9.12941
6.98563 -38.0015 -38.0015 -9.13635
6.99014 -40.2265 -40.2265 -9.14329
6.99465 -42.4106 -42.4106 -9.15024
6.99916 -44.5371 -44.5371 -9.15718
7.00366 -46.59 -46.59 -9.16412
7.00817 -48.5538 -48.5538 -9.17106
7.01267 -50.4134 -50.4134 -9.17801
7.01718 -52.1549 -52.1549 -9.18495
7.02168 -53.7651 -53.7651 -9.19189
7.02618 -55.2318 -55.2318 -9.19883
7.03068 -56.5439 -56.5439 -9.20578
7.03518 -57.6915 -57.6915 -9.21272
7.03968 -58.6661 -58.6661 -9.21966
7.04417 -59.4602 -59.4602 -9.2266
7.04867 -60.068 -60.068 -9.23355
7.05316 -60.4849 -60.4849 -9.24049
7.05766 -60.7079 -60.7079 -9.24743
7.06215 -60.7353 -60.7353 -9.25437
7.06664 -60.5671 -60.5671 -9.26132
7.07113 -60.2047 -60.2047 -9.26826
7.07562 -59.6509 -59.6509 -9.2752
7.0801 -58.91 -58.91 -9.28214
7.08459 -57.9878 -57.9878 -9.28909
7.08907 -56.8914 -56.8914 -9.29603
7.09356 -55.6291 -55.6291 -9.30297
7.09804 -54.2107 -54.2107 -9.30991
7.10252 -52.6471 -52.6471 -9.31686
7.107 -50.9502 -50.9502 -9.3238
7.11148 -49.133 -49.133 -9.33074
7.11595 -47.2093 -47.2093 -9.33768
7.12043 -45.1938 -45.1938 -9.34463
7.1249 -43.102 -43.102 -9.35157
7.12938 -40.9497 -40.9497 -9.35851
7.13385 -38.7534 -38.7534 -9.36545
7.13832 -36.5297 -36.5297 -9.3724
7.14279 -34.2956 -34.2956 -9.37934
7.14726 -32.068 -32.068 -9.38628
7.15173 -29.864 -29.864 -9.39322
7.15619 -27.7002 -27.7002 -9.40017
7.16066 -25.593 -25.593 -9.40711
7.16512 -23.5585 -23.5585 -9.41405
7.16958 -21.6121 -21.6121 -9.42099
7.17405 -19.7684 -19.7684 -9.42794
7.17851 -18.0416 -18.0416 -9.43488
7.18296 -16.4446 -16.4446 -9.44182
7.18742 -14.9895 -14.9895 -9.44876
7.19188 -13.6873 -13.6873 -9.45571
7.19633 -12.5478 -12.5478 -9.46265
7.20079 -11.5795 -11.5795 -9.46959
7.20524 -10.7898 -10.7898 -9.47653
7.20969 -10.1846 -10.1846 -9.48348
7.21414 -9.76832 -9.76832 -9.49042
7.21859 -9.54405 -9.54405 -9.49736
7.22304 -9.51339 -9.51339 -9.5043
7.22749 -9.67647 -9.67647 -9.51125
7.23193 -10.032 -10.032 -9.51819
7.23638 -10.577 -10.577 -9.52513
7.24082 -11.3074 -11.3074 -9.53207
7.24526 -12.2175 -12.2175 -9.53902
7.2497 -13.3003 -13.3003 -9.54596
7.25414 -14.5474 -14.5474 -9.5529
7.25858 -15.9493 -15.9493 -9.55984
7.26302 -17.4952 -17.4952 -9.56679
7.26745 -19.1733 -19.1733 -9.57373
7.27189 -20.9709 -20.9709 -9.58067
7.27632 -22.8741 -22.8741 -9.58761
7.28075 -24.8684 -24.8684 -9.59456
7.28519 -26.9386 -26.9386 -9.6015
7.28962 -29.069 -29.069 -9.60844
7.29404 -31.2432 -31.2432 -9.61538
7.29847 -33.4449 -33.4449 -9.62233
7.3029 -35.6572 -35.6572 -9.62927
7.30732 -37.8632 -37.8632 -9.63621
7.31175 -40.0463 -40.0463 -9.64315
7.31617 -42.1899 -42.1899 -9.6501
7.32059 -44.2776 -44.2776 -9.65704
7.32501 -46.2936 -46.2936 -9.66398
7.32943 -48.2227 -48.2227 -9.67092
7.33385 -50.0503 -50.0503 -9.67787
7.33826 -51.7624 -51.7624 -9.68481
7.34268 -53.3462 -53.3462 -9.69175
7.34709 -54.7897 -54.7897 -9.69869
7.35151 -56.082 -56.082 -9.70564
7.35592 -57.2133 -57.2133 -9.71258
7.36033 -58.1751 -58.1751 -9.71952
7.36474 -58.9603 -58.9603 -9.72646
7.36915 -59.5629 -59.5629 -9.73341
7.37355 -59.9785 -59.9785 -9.74035
7.37796 -60.204 -60.204 -9.74729
7.38236 -60.2378 -60.2378 -9.75423
7.38677 -60.0798 -60.0798 -9.76118
7.39117 -59.7312 -59.7312 -9.76812
7.39557 -59.1948 -59.1948 -9.77506
7.39997 -58.4748 -58.4748 -9.782
7.40437 -57.5768 -57.5768 -9.78895
7.40876 -56.5076 -56.5076 -9.79589
7.41316 -55.2756 -55.2756 -9.80283
7.41755 -53.8901 -53.8901 -9.80978
7.42195 -52.3618 -52.3618 -9.81672
7.42634 -50.7024 -50.7024 -9.82366
7.43073 -48.9246 -48.9246 -9.8306
7.43512 -47.0419 -47.0419 -9.83755
7.43951 -45.0687 -45.0687 -9.84449
7.4439 -43.0201 -43.0201 -9.85143
7.44828 -40.9116 -40.9116 -9.85837
7.45267 -38.7594 -38.7594 -9.86532
7.45705 -36.5797 -36.5797 -9.87226
7.46144 -34.3893 -34.3893 -9.8792
7.46582 -32.2047 -32.2047 -9.88614
7.4702 -30.0426 -30.0426 -9.89309
7.47458 -27.9194 -27.9194 -9.90003
7.47895 -25.8511 -25.8511 -9.90697
7.48333 -23.8536 -23.8536 -9.91391
7.48771 -21.9418 -21.9418 -9.92086
7.49208 -20.1304 -20.1304 -9.9278
7.49645 -18.433 -18.433 -9.93474
7.50083 -16.8625 -16.8625 -9.94168
7.5052 -15.4307 -15.4307 -9.94863
7.50957 -14.1484 -14.1484 -9.95557
7.51393 -13.0253 -13.0253 -9.96251
7.5183 -12.0699 -12.0699 -9.96945
7.52267 -11.2893 -11.2893 -9.9764
7.52703 -10.6894 -10.6894 -9.98334
7.53139 -10.2746 -10.2746 -9.99028
7.53576 -10.0479 -10.0479 -9.99722
7.54012 -10.0111 -10.0111 -10.0042
7.54448 -10.1642 -10.1642 -10.0111
7.54883 -10.506 -10.506 -10.0181
7.55319 -11.0337 -11.0337 -10.025
7.55755 -11.7434 -11.7434 -10.0319
7.5619 -12.6294 -12.6294 -10.0389
7.56626 -13.685 -13.685 -10.0458
7.57061 -14.902 -14.902 -10.0528
7.57496 -16.271 -16.271 -10.0597
7.57931 -17.7817 -17.7817 -10.0666
7.58366 -19.4224 -19.4224 -10.0736
7.58801 -21.1806 -21.1806 -10.0805
7.59235 -23.0429 -23.0429 -10.0875
7.5967 -24.995 -24.995 -10.0944
7.60104 -27.0221 -27.0221 -10.1014
7.60538 -29.1086 -29.1086 -10.1083
7.60973 -31.2388 -31.2388 -10.1153
7.61407 -33.3964 -33.3964 -10.1222
7.61841 -35.565 -35.565 -10.1291
7.62274 -37.7281 -37.7281 -10.1361
7.62708 -39.8692 -39.8692 -10.143
7.63142 -41.9721 -41.9721 -10.15
7.63575 -44.0209 -44.0209 -10.1569
7.64008 -45.9999 -45.9999 -10.1638
7.64441 -47.8943 -47.8943 -10.1708
7.64874 -49.6895 -49.6895 -10.1777
7.65307 -51.3721 -51.3721 -10.1847
7.6574 -52.9293 -52.9293 -10.1916
7.66173 -54.3494 -54.3494 -10.1986
7.66605 -55.6216 -55.6216 -10.2055
7.67038 -56.7364 -56.7364 -10.2124
7.6747 -57.6853 -57.6853 -10.2194
7.67902 -58.4612 -58.4612 -10.2263
7.68335 -59.0584 -59.0584 -10.2333
7.68767 -59.4724 -59.4724 -10.2402
7.69198 -59.7001 -59.7001 -10.2472
7.6963 -59.74 -59.74 -10.2541
7.70062 -59.5917 -59.5917 -10.261
7.70493 -59.2567 -59.2567 -10.268
7.70925 -58.7375 -58.7375 -10.2749
7.71356 -58.0381 -58.0381 -10.2819
7.71787 -57.164 -57.164 -10.2888
7.72218 -56.122 -56.122 -10.2958
7.72649 -54.92 -54.92 -10.3027
7.7308 -53.5672 -53.5672 -10.3096
7.7351 -52.0741 -52.0741 -10.3166
7.73941 -50.452 -50.452 -10.3235
7.74371 -48.7135 -48.7135 -10.3305
7.74801 -46.8716 -46.8716 -10.3374
7.75232 -44.9406 -44.9406 -10.3444
7.75662 -42.935 -42.935 -10.3513
7.76092 -40.8703 -40.8703 -10.3582
7.76521 -38.7622 -38.7622 -10.3652
7.76951 -36.6266 -36.6266 -10.3721
7.77381 -34.4799 -34.4799 -10.3791
7.7781 -32.3383 -32.3383 -10.386
7.78239 -30.2182 -30.2182 -10.393
7.78668 -28.1356 -28.1356 -10.3999
7.79098 -26.1064 -26.1064 -10.4068
7.79526 -24.1459 -24.1459 -10.4138
7.79955 -22.269 -22.269 -10.4207
7.80384 -20.49 -20.49 -10.4277
7.80813 -18.8222 -18.8222 -10.4346
7.81241 -17.2783 -17.2783 -10.4415
7.81669 -15.8701 -15.8701 -10.4485
7.82098 -14.608 -14.608 -10.4554
7.82526 -13.5016 -13.5016 -10.4624
7.82954 -12.5593 -12.5593 -10.4693
7.83382 -11.7881 -11.7881 -10.4763
7.83809 -11.1937 -11.1937 -10.4832
7.84237 -10.7806 -10.7806 -10.4901
7.84664 -10.5519 -10.5519 -10.4971
7.85092 -10.5091 -10.5091 -10.504
7.85519 -10.6525 -10.6525 -10.511
7.85946 -10.9808 -10.9808 -10.5179
7.86373 -11.4916 -11.4916 -10.5249
7.868 -12.1807 -12.1807 -10.5318
7.87227 -13.0429 -13.0429 -10.5387
7.87653 -14.0715 -14.0715 -10.5457
7.8808 -15.2586 -15.2586 -10.5526
7.88506 -16.5951 -16.5951 -10.5596
7.88933 -18.0707 -18.0707 -10.5665
7.89359 -19.6742 -19.6742 -10.5734
7.89785 -21.3932 -21.3932 -10.5804
7.90211 -23.2146 -23.2146 -10.5873
7.90636 -25.1247 -25.1247 -10.5943
7.91062 -27.1087 -27.1087 -10.6012
7.91488 -29.1515 -29.1515 -10.6082
7.91913 -31.2376 -31.2376 -10.6151
7.92338 -33.3512 -33.3512 -10.6221
7.92764 -35.476 -35.476 -10.629
7.93189 -37.5961 -37.5961 -10.6359
7.93614 -39.6952 -39.6952 -10.6429
7.94038 -41.7574 -41.7574 -10.6498
7.94463 -43.7671 -43.7671 -10.6568
7.94888 -45.709 -45.709 -10.6637
7.95312 -47.5684 -47.5684 -10.6707
7.95737 -49.3312 -49.3312 -10.6776
7.96161 -50.9841 -50.9841 -10.6845
7.96585 -52.5145 -52.5145 -10.6915
7.97009 -53.9109 -53.9109 -10.6984
7.97433 -55.1628 -55.1628 -10.7054
7.97856 -56.2607 -56.2607 -10.7123
7.9828 -57.1964 -57.1964 -10.7192
7.98704 -57.9629 -57.9629 -10.7262
7.99127 -58.5543 -58.5543 -10.7331
7.9955 -58.9664 -58.9664 -10.7401
7.99973 -59.1961 -59.1961 -10.747
8.00396 -59.2418 -59.2418 -10.754
8.00819 -59.1031 -59.1031 -10.7609
8.01242 -58.7814 -58.7814 -10.7678
8.01665 -58.2791 -58.2791 -10.7748
8.02087 -57.6001 -57.6001 -10.7817
8.0251 -56.7497 -56.7497 -10.7887
8.02932 -55.7345 -55.7345 -10.7956
8.03354 -54.5623 -54.5623 -10.8026
8.03776 -53.242 -53.242 -10.8095
8.04198 -51.7839 -51.7839 -10.8164
8.0462 -50.199 -50.199 -10.8234
8.05041 -48.4995 -48.4995 -10.8303
8.05463 -46.6984 -46.6984 -10.8373
8.05884 -44.8094 -44.8094 -10.8442
8.06306 -42.8469 -42.8469 -10.8512
8.06727 -40.8259 -40.8259 -10.8581
8.07148 -38.7618 -38.7618 -10.865
8.07569 -36.6703 -36.6703 -10.872
8.0799 -34.5673 -34.5673 -10.8789
8.08411 -32.4687 -32.4687 -10.8859
8.08831 -30.3907 -30.3907 -10.8928
8.09252 -28.3488 -28.3488 -10.8997
8.09672 -26.3587 -26.3587 -10.9067
8.10092 -24.4354 -24.4354 -10.9136
8.10512 -22.5936 -22.5936 -10.9206
8.10932 -20.8471 -20.8471 -10.9275
8.11352 -19.2091 -19.2091 -10.9345
8.11772 -17.6922 -17.6922 -10.9414
8.12192 -16.3077 -16.3077 -10.9484
8.12611 -15.066 -15.066 -10.9553
8.1303 -13.9766 -13.9766 -10.9622
8.1345 -13.0476 -13.0476 -10.9692
8.13869 -12.286 -12.286 -10.9761
8.14288 -11.6975 -11.6975 -10.9831
8.14707 -11.2864 -11.2864 -10.99
8.15125 -11.0559 -11.0559 -10.997
8.15544 -11.0074 -11.0074 -11.0039
8.15963 -11.1414 -11.1414 -11.0108
8.16381 -11.4566 -11.4566 -11.0178
8.16799 -11.9506 -11.9506 -11.0247
8.17218 -12.6195 -12.6195 -11.0317
8.17636 -13.4581 -13.4581 -11.0386
8.18053 -14.4599 -14.4599 -11.0455
8.18471 -15.6174 -15.6174 -11.0525
8.18889 -16.9214 -16.9214 -11.0594
8.19307 -18.3622 -18.3622 -11.0664
8.19724 -19.9285 -19.9285 -11.0733
8.20141 -21.6085 -21.6085 -11.0803
8.20559 -23.3893 -23.3893 -11.0872
8.20976 -25.2573 -25.2573 -11.0941
8.21393 -27.1983 -27.1983 -11.1011
8.21809 -29.1975 -29.1975 -11.108
8.22226 -31.2396 -31.2396 -11.115
8.22643 -33.3091 -33.3091 -11.1219
8.23059 -35.3903 -35.3903 -11.1289
8.23476 -37.4672 -37.4672 -11.1358
8.23892 -39.5243 -39.5243 -11.1427
8.24308 -41.5457 -41.5457 -11.1497
8.24724 -43.5162 -43.5162 -11.1566
8.2514 -45.4208 -45.4208 -11.1636
8.25555 -47.2451 -47.2451 -11.1705
8.25971 -48.9753 -48.9753 -11.1775
8.26387 -50.5982 -50.5982 -11.1844
8.26802 -52.1016 -52.1016 -11.1913
8.27217 -53.4742 -53.4742 -11.1983
8.27632 -54.7056 -54.7056 -11.2052
8.28047 -55.7864 -55.7864 -11.2122
8.28462 -56.7086 -56.7086 -11.2191
8.28877 -57.4653 -57.4653 -11.2261
8.29292 -58.0508 -58.0508 -11.233
8.29706 -58.4608 -58.4608 -11.2399
8.30121 -58.6921 -58.6921 -11.2469
8.30535 -58.7433 -58.7433 -11.2538
8.30949 -58.614 -58.614 -11.2608
8.31363 -58.3052 -58.3052 -11.2677
8.31777 -57.8195 -57.8195 -11.2746
8.32191 -57.1607 -57.1607 -11.2816
8.32605 -56.3337 -56.3337 -11.2885
8.33018 -55.3451 -55.3451 -11.2955
8.33432 -54.2025 -54.2025 -11.3024
8.33845 -52.9145 -52.9145 -11.3094
8.34258 -51.4912 -51.4912 -11.3163
8.34671 -49.9433 -49.9433 -11.3232
8.35084 -48.2828 -48.2828 -11.3302
8.35497 -46.5223 -46.5223 -11.3371
8.3591 -44.6752 -44.6752 -11.3441
8.36322 -42.7557 -42.7557 -11.351
8.36735 -40.7783 -40.7783 -11.358
8.37147 -38.7582 -38.7582 -11.3649
8.37559 -36.7107 -36.7107 -11.3718
8.37972 -34.6514 -34.6514 -11.3788
8.38384 -32.596 -32.596 -11.3857
8.38795 -30.5601 -30.5601 -11.3927
8.39207 -28.5591 -28.5591 -11.3996
8.39619 -26.6082 -26.6082 -11.4065
8.4003 -24.7223 -24.7223 -11.4135
8.40442 -22.9156 -22.9156 -11.4204
8.40853 -21.2018 -21.2018 -11.4274
8.41264 -19.5939 -19.5939 -11.4343
8.41675 -18.104 -18.104 -11.4413
8.42086 -16.7434 -16.7434 -11.4482
8.42497 -15.5224 -15.5224 -11.4552
8.42907 -14.4502 -14.4502 -11.4621
8.43318 -13.5348 -13.5348 -11.469
8.43728 -12.7831 -12.7831 -11.476
8.44139 -12.2007 -12.2007 -11.4829
8.44549 -11.792 -11.792 -11.4899
8.44959 -11.5599 -11.5599 -11.4968
8.45369 -11.506 -11.506 -11.5038
8.45779 -11.6308 -11.6308 -11.5107
8.46188 -11.9332 -11.9332 -11.5176
8.46598 -12.4107 -12.4107 -11.5246
8.47007 -13.0596 -13.0596 -11.5315
8.47417 -13.8749 -13.8749 -11.5385
8.47826 -14.8502 -14.8502 -11.5454
8.48235 -15.9782 -15.9782 -11.5524
8.48644 -17.25 -17.25 -11.5593
8.49053 -18.6561 -18.6561 -11.5662
8.49462 -20.1855 -20.1855 -11.5732
8.4987 -21.8266 -21.8266 -11.5801
8.50279 -23.5669 -23.5669 -11.5871
8.50687 -25.393 -25.393 -11.594
8.51095 -27.2911 -27.2911 -11.6009
8.51503 -29.2466 -29.2466 -11.6079
8.51911 -31.2448 -31.2448 -11.6148
8.52319 -33.2702 -33.2702 -11.6218
8.52727 -35.3077 -35.3077 -11.6287
8.53135 -37.3415 -37.3415 -11.6357
8.53542 -39.3564 -39.3564 -11.6426
8.5395 -41.3369 -41.3369 -11.6495
8.54357 -43.2681 -43.2681 -11.6565
8.54764 -45.1354 -45.1354 -11.6634
8.55171 -46.9244 -46.9244 -11.6704
8.55578 -48.6218 -48.6218 -11.6773
8.55985 -50.2146 -50.2146 -11.6843
8.56391 -51.6909 -51.6909 -11.6912
8.56798 -53.0393 -53.0393 -11.6981
8.57204 -54.2499 -54.2499 -11.7051
8.57611 -55.3135 -55.3135 -11.712
8.58017 -56.222 -56.222 -11.719
8.58423 -56.9686 -56.9686 -11.7259
8.58829 -57.5479 -57.5479 -11.7328
8.59235 -57.9554 -57.9554 -11.7398
8.5964 -58.1882 -58.1882 -11.7467
8.60046 -58.2445 -58.2445 -11.7537
8.60451 -58.1242 -58.1242 -11.7606
8.60857 -57.8282 -57.8282 -11.7676
8.61262 -57.3589 -57.3589 -11.7745
8.61667 -56.7199 -56.7199 -11.7815
8.62072 -55.9162 -55.9162 -11.7884
8.62477 -54.9539 -54.9539 -11.7953
8.62882 -53.8406 -53.8406 -11.8023
8.63286 -52.5848 -52.5848 -11.8092
8.63691 -51.1961 -51.1961 -11.8162
8.64095 -49.685 -49.685 -11.8231
8.64499 -48.0633 -48.0633 -11.8301
8.64903 -46.3433 -46.3433 -11.837
8.65307 -44.538 -44.538 -11.8439
8.65711 -42.6614 -42.6614 -11.8509
8.66115 -40.7276 -40.7276 -11.8578
8.66519 -38.7515 -38.7515 -11.8648
8.66922 -36.748 -36.748 -11.8717
8.67326 -34.7325 -34.7325 -11.8786
8.67729 -32.7202 -32.7202 -11.8856
8.68132 -30.7264 -30.7264 -11.8925
8.68535 -28.7663 -28.7663 -11.8995
8.68938 -26.8548 -26.8548 -11.9064
8.69341 -25.0063 -25.0063 -11.9134
8.69744 -23.2349 -23.2349 -11.9203
8.70146 -21.554 -21.554 -11.9272
8.70548 -19.9763 -19.9763 -11.9342
8.70951 -18.5138 -18.5138 -11.9411
8.71353 -17.1774 -17.1774 -11.9481
8.71755 -15.9773 -15.9773 -11.955
8.72157 -14.9225 -14.9225 -11.962
8.72559 -14.021 -14.021 -11.9689
8.72961 -13.2794 -13.2794 -11.9758
8.73362 -12.7034 -12.7034 -11.9828
8.73764 -12.2972 -12.2972 -11.9897
8.74165 -12.0639 -12.0639 -11.9967
8.74566 -12.0049 -12.0049 -12.0036
8.74967 -12.1209 -12.1209 -12.0106
8.75368 -12.4106 -12.4106 -12.0175
8.75769 -12.8719 -12.8719 -12.0244
8.7617 -13.501 -13.501 -12.0314
8.7657 -14.2932 -14.2932 -12.0383
8.76971 -15.2423 -15.2423 -12.0453
8.77371 -16.341 -16.341 -12.0522
8.77772 -17.5809 -17.5809 -12.0592
8.78172 -18.9524 -18.9524 -12.0661
8.78572 -20.4451 -20.4451 -12.073
8.78972 -22.0475 -22.0475 -12.08
8.79371 -23.7473 -23.7473 -12.0869
8.79771 -25.5317 -25.5317 -12.0939
8.8017 -27.3869 -27.3869 -12.1008
8.8057 -29.2989 -29.2989 -12.1077
8.80969 -31.2531 -31.2531 -12.1147
8.81368 -33.2345 -33.2345 -12.1216
8.81767 -35.2282 -35.2282 -12.1286
8.82166 -37.219 -37.219 -12.1355
8.82565 -39.1916 -39.1916 -12.1425
8.82964 -41.1312 -41.1312 -12.1494
8.83362 -43.023 -43.023 -12.1564
8.83761 -44.8527 -44.8527 -12.1633
8.84159 -46.6064 -46.6064 -12.1702
8.84557 -48.2708 -48.2708 -12.1772
8.84955 -49.8333 -49.8333 -12.1841
8.85353 -51.2821 -51.2821 -12.1911
8.85751 -52.6063 -52.6063 -12.198
8.86149 -53.7959 -53.7959 -12.2049
8.86546 -54.8419 -54.8419 -12.2119
8.86944 -55.7364 -55.7364 -12.2188
8.87341 -56.4727 -56.4727 -12.2258
8.87738 -57.0454 -57.0454 -12.2327
8.88136 -57.4502 -57.4502 -12.2397
8.88532 -57.6842 -57.6842 -12.2466
8.88929 -57.7455 -57.7455 -12.2535
8.89326 -57.6339 -57.6339 -12.2605
8.89723 -57.3504 -57.3504 -12.2674
8.90119 -56.8972 -56.8972 -12.2744
8.90516 -56.2777 -56.2777 -12.2813
8.90912 -55.497 -55.497 -12.2883
8.91308 -54.5609 -54.5609 -12.2952
8.91704 -53.4768 -53.4768 -12.3021
8.921 -52.2528 -52.2528 -12.3091
8.92496 -50.8985 -50.8985 -12.316
8.92891 -49.4241 -49.4241 -12.323
8.93287 -47.8411 -47.8411 -12.3299
8.93682 -46.1613 -46.1613 -12.3369
8.94078 -44.3978 -44.3978 -12.3438
8.94473 -42.564 -42.564 -12.3507
8.94868 -40.6737 -40.6737 -12.3577
8.95263 -38.7415 -38.7415 -12.3646
8.95657 -36.7821 -36.7821 -12.3716
8.96052 -34.8103 -34.8103 -12.3785
8.96447 -32.8412 -32.8412 -12.3855
8.96841 -30.8896 -30.8896 -12.3924
8.97235 -28.9705 -28.9705 -12.3993
8.9763 -27.0985 -27.0985 -12.4063
8.98024 -25.2876 -25.2876 -12.4132
8.98418 -23.5517 -23.5517 -12.4202
8.98812 -21.9038 -21.9038 -12.4271
8.99205 -20.3565 -20.3565 -12.434
8.99599 -18.9215 -18.9215 -12.441
8.99992 -17.6095 -17.6095 -12.4479
9.00386 -16.4305 -16.4305 -12.4549
9.00779 -15.3934 -15.3934 -12.4618
9.01172 -14.506 -14.506 -12.4688
9.01565 -13.7749 -13.7749 -12.4757
9.01958 -13.2056 -13.2056 -12.4826
9.02351 -12.8022 -12.8022 -12.4896
9.02743 -12.5678 -12.5678 -12.4965
9.03136 -12.5041 -12.5041 -12.5035
9.03528 -12.6114 -12.6114 -12.5104
9.0392 -12.8888 -12.8888 -12.5174
9.04312 -13.3341 -13.3341 -12.5243
9.04704 -13.9438 -13.9438 -12.5312
9.05096 -14.7132 -14.7132 -12.5382
9.05488 -15.6363 -15.6363 -12.5451
9.0588 -16.706 -16.706 -12.5521
9.06271 -17.914 -17.914 -12.559
9.06663 -19.2512 -19.2512 -12.566
9.07054 -20.7073 -20.7073 -12.5729
9.07445 -22.2711 -22.2711 -12.5798
9.07836 -23.9307 -23.9307 -12.5868
9.08227 -25.6734 -25.6734 -12.5937
9.08618 -27.4859 -27.4859 -12.6007
9.09009 -29.3544 -29.3544 -12.6076
9.09399 -31.2646 -31.2646 -12.6145
9.0979 -33.2021 -33.2021 -12.6215
9.1018 -35.152 -35.152 -12.6284
9.1057 -37.0995 -37.0995 -12.6354
9.1096 -39.0299 -39.0299 -12.6423
9.1135 -40.9285 -40.9285 -12.6493
9.1174 -42.7808 -42.7808 -12.6562
9.1213 -44.5728 -44.5728 -12.6632
9.12519 -46.291 -46.291 -12.6701
9.12909 -47.9222 -47.9222 -12.677
9.13298 -49.4543 -49.4543 -12.684
9.13687 -50.8755 -50.8755 -12.6909
9.14077 -52.1751 -52.1751 -12.6979
9.14466 -53.3434 -53.3434 -12.7048
9.14854 -54.3716 -54.3716 -12.7118
9.15243 -55.2519 -55.2519 -12.7187
9.15632 -55.9777 -55.9777 -12.7256
9.1602 -56.5436 -56.5436 -12.7326
9.16409 -56.9454 -56.9454 -12.7395
9.16797 -57.1802 -57.1802 -12.7465
9.17185 -57.2462 -57.2462 -12.7534
9.17573 -57.1431 -57.1431 -12.7603
9.17961 -56.8718 -56.8718 -12.7673
9.18349 -56.4343 -56.4343 -12.7742
9.18736 -55.8343 -55.8343 -12.7812
9.19124 -55.0763 -55.0763 -12.7881
9.19511 -54.1661 -54.1661 -12.7951
9.19899 -53.1108 -53.1108 -12.802
9.20286 -51.9186 -51.9186 -12.8089
9.20673 -50.5985 -50.5985 -12.8159
9.2106 -49.1606 -49.1606 -12.8228
9.21447 -47.6161 -47.6161 -12.8298
9.21833 -45.9766 -45.9766 -12.8367
9.2222 -44.2547 -44.2547 -12.8437
9.22606 -42.4635 -42.4635 -12.8506
9.22993 -40.6167 -40.6167 -12.8575
9.23379 -38.7284 -38.7284 -12.8645
9.23765 -36.813 -36.813 -12.8714
9.24151 -34.885 -34.885 -12.8784
9.24537 -32.959 -32.959 -12.8853
9.24923 -31.0498 -31.0498 -12.8923
9.25308 -29.1718 -29.1718 -12.8992
9.25694 -27.3393 -27.3393 -12.9061
9.26079 -25.5661 -25.5661 -12.9131
9.26464 -23.8658 -23.8658 -12.92
9.26849 -22.2511 -22.2511 -12.927
9.27234 -20.7344 -20.7344 -12.9339
9.27619 -19.3271 -19.3271 -12.9408
9.28004 -18.0398 -18.0398 -12.9478
9.28389 -16.8822 -16.8822 -12.9547
9.28773 -15.863 -15.863 -12.9617
9.29157 -14.9899 -14.9899 -12.9686
9.29542 -14.2695 -14.2695 -12.9756
9.29926 -13.7071 -13.7071 -12.9825
9.3031 -13.3069 -13.3069 -12.9895
9.30694 -13.0718 -13.0718 -12.9964
9.31078 -13.0036 -13.0036 -13.0033
9.31461 -13.1025 -13.1025 -13.0103
9.31845 -13.3679 -13.3679 -13.0172
9.32228 -13.7975 -13.7975 -13.0242
9.32612 -14.3879 -14.3879 -13.0311
9.32995 -15.1347 -15.1347 -13.038
9.33378 -16.032 -16.032 -13.045
9.33761 -17.0729 -17.0729 -13.0519
9.34144 -18.2494 -18.2494 -13.0589
9.34526 -19.5525 -19.5525 -13.0658
9.34909 -20.9721 -20.9721 -13.0728
9.35291 -22.4975 -22.4975 -13.0797
9.35674 -24.1169 -24.1169 -13.0866
9.36056 -25.818 -25.818 -13.0936
9.36438 -27.5879 -27.5879 -13.1005
9.3682 -29.4129 -29.4129 -13.1075
9.37202 -31.2793 -31.2793 -13.1144
9.37583 -33.1728 -33.1728 -13.1214
9.37965 -35.0789 -35.0789 -13.1283
9.38347 -36.9832 -36.9832 -13.1352
9.38728 -38.8713 -38.8713 -13.1422
9.39109 -40.7287 -40.7287 -13.1491
9.3949 -42.5414 -42.5414 -13.1561
9.39871 -44.2957 -44.2957 -13.163
9.40252 -45.9781 -45.9781 -13.17
9.40633 -47.5761 -47.5761 -13.1769
9.41014 -49.0775 -49.0775 -13.1838
9.41394 -50.4709 -50.4709 -13.1908
9.41774 -51.7458 -51.7458 -13.1977
9.42155 -52.8926 -52.8926 -13.2047
9.42535 -53.9027 -53.9027 -13.2116
9.42915 -54.7685 -54.7685 -13.2186
9.43295 -55.4835 -55.4835 -13.2255
9.43675 -56.0423 -56.0423 -13.2324
9.44054 -56.4409 -56.4409 -13.2394
9.44434 -56.6762 -56.6762 -13.2463
9.44813 -56.7467 -56.7467 -13.2533
9.45193 -56.6517 -56.6517 -13.2602
9.45572 -56.3923 -56.3923 -13.2672
9.45951 -55.9705 -55.9705 -13.2741
9.4633 -55.3895 -55.3895 -13.281
9.46709 -54.6539 -54.6539 -13.288
9.47087 -53.7695 -53.7695 -13.2949
9.47466 -52.7429 -52.7429 -13.3019
9.47844 -51.5821 -51.5821 -13.3088
9.48223 -50.296 -50.296 -13.3158
9.48601 -48.8945 -48.8945 -13.3227
9.48979 -47.3883 -47.3883 -13.3296
9.49357 -45.7889 -45.7889 -13.3366
9.49735 -44.1085 -44.1085 -13.3435
9.50112 -42.36 -42.36 -13.3505
9.5049 -40.5566 -40.5566 -13.3574
9.50868 -38.7122 -38.7122 -13.3643
9.51245 -36.8407 -36.8407 -13.3713
9.51622 -34.9564 -34.9564 -13.3782
9.51999 -33.0737 -33.0737 -13.3852
9.52376 -31.2068 -31.2068 -13.3921
9.52753 -29.37 -29.37 -13.3991
9.5313 -27.5771 -27.5771 -13.406
9.53507 -25.8418 -25.8418 -13.4129
9.53883 -24.1773 -24.1773 -13.4199
9.5426 -22.596 -22.596 -13.4268
9.54636 -21.1101 -21.1101 -13.4338
9.55012 -19.7307 -19.7307 -13.4407
9.55388 -18.4682 -18.4682 -13.4476
9.55764 -17.3322 -17.3322 -13.4546
9.5614 -16.3312 -16.3312 -13.4615
9.56515 -15.4727 -15.4727 -13.4685
9.56891 -14.7633 -14.7633 -13.4754
9.57266 -14.2081 -14.2081 -13.4824
9.57642 -13.8112 -13.8112 -13.4893
9.58017 -13.5757 -13.5757 -13.4963
9.58392 -13.5032 -13.5032 -13.5032
9.58767 -13.5941 -13.5941 -13.5101
9.59142 -13.8477 -13.8477 -13.5171
9.59516 -14.2619 -14.2619 -13.524
9.59891 -14.8334 -14.8334 -13.531
9.60265 -15.5578 -15.5578 -13.5379
9.6064 -16.4295 -16.4295 -13.5449
9.61014 -17.4418 -17.4418 -13.5518
9.61388 -18.587 -18.587 -13.5587
9.61762 -19.8561 -19.8561 -13.5657
9.62136 -21.2395 -21.2395 -13.5726
9.6251 -22.7266 -22.7266 -13.5796
9.62883 -24.306 -24.306 -13.5865
9.63257 -25.9657 -25.9657 -13.5935
9.6363 -27.693 -27.693 -13.6004
9.64003 -29.4747 -29.4747 -13.6073
9.64377 -31.2972 -31.2972 -13.6143
9.6475 -33.1467 -33.1467 -13.6212
9.65122 -35.009 -35.009 -13.6282
9.65495 -36.8701 -36.8701 -13.6351
9.65868 -38.7158 -38.7158 -13.642
9.6624 -40.532 -40.532 -13.649
9.66613 -42.305 -42.305 -13.6559
9.66985 -44.0213 -44.0213 -13.6629
9.67357 -45.668 -45.668 -13.6698
9.67729 -47.2325 -47.2325 -13.6768
9.68101 -48.703 -48.703 -13.6837
9.68473 -50.0684 -50.0684 -13.6906
9.68845 -51.3183 -51.3183 -13.6976
9.69216 -52.4434 -52.4434 -13.7045
9.69588 -53.4353 -53.4353 -13.7115
9.69959 -54.2863 -54.2863 -13.7184
9.7033 -54.9902 -54.9902 -13.7254
9.70701 -55.5417 -55.5417 -13.7323
9.71072 -55.9367 -55.9367 -13.7392
9.71443 -56.1723 -56.1723 -13.7462
9.71814 -56.2469 -56.2469 -13.7531
9.72184 -56.1599 -56.1599 -13.7601
9.72555 -55.9121 -55.9121 -13.767
9.72925 -55.5056 -55.5056 -13.7739
9.73295 -54.9434 -54.9434 -13.7809
9.73665 -54.2301 -54.2301 -13.7878
9.74035 -53.371 -53.371 -13.7948
9.74405 -52.3729 -52.3729 -13.8017
9.74775 -51.2434 -51.2434 -13.8087
9.75145 -49.9912 -49.9912 -13.8156
9.75514 -48.6258 -48.6258 -13.8226
9.75884 -47.1578 -47.1578 -13.8295
9.76253 -45.5984 -45.5984 -13.8364
9.76622 -43.9594 -43.9594 -13.8434
9.76991 -42.2533 -42.2533 -13.8503
9.7736 -40.4933 -40.4933 -13.8573
9.77729 -38.6927 -38.6927 -13.8642
9.78097 -36.8652 -36.8652 -13.8712
9.78466 -35.0247 -35.0247 -13.8781
9.78834 -33.1853 -33.1853 -13.885
9.79203 -31.3608 -31.3608 -13.892
9.79571 -29.5652 -29.5652 -13.8989
9.79939 -27.8121 -27.8121 -13.9059
9.80307 -26.1148 -26.1148 -13.9128
9.80674 -24.4861 -24.4861 -13.9197
9.81042 -22.9384 -22.9384 -13.9267
9.8141 -21.4834 -21.4834 -13.9336
9.81777 -20.1321 -20.1321 -13.9406
9.82144 -18.8947 -18.8947 -13.9475
9.82512 -17.7805 -17.7805 -13.9545
9.82879 -16.798 -16.798 -13.9614
9.83246 -15.9544 -15.9544 -13.9683
9.83613 -15.2561 -15.2561 -13.9753
9.83979 -14.7084 -14.7084 -13.9822
9.84346 -14.3153 -14.3153 -13.9892
9.84712 -14.0796 -14.0796 -13.9961
9.85079 -14.0031 -14.0031 -14.0031
9.85445 -14.0862 -14.0862 -14.01
9.85811 -14.3283 -14.3283 -14.0169
9.86177 -14.7273 -14.7273 -14.0239
9.86543 -15.2801 -15.2801 -14.0308
9.86909 -15.9824 -15.9824 -14.0378
9.87274 -16.8288 -16.8288 -14.0447
9.8764 -17.8128 -17.8128 -14.0517
9.88005 -18.9268 -18.9268 -14.0586
9.8837 -20.1621 -20.1621 -14.0655
9.88736 -21.5095 -21.5095 -14.0725
9.89101 -22.9584 -22.9584 -14.0794
9.89465 -24.498 -24.498 -14.0864
9.8983 -26.1163 -26.1163 -14.0933
9.90195 -27.8011 -27.8011 -14.1003
9.90559 -29.5395 -29.5395 -14.1072
9.90924 -31.3182 -31.3182 -14.1141
9.91288 -33.1238 -33.1238 -14.1211
9.91652 -34.9423 -34.9423 -14.128
9.92016 -36.7602 -36.7602 -14.135
9.9238 -38.5634 -38.5634 -14.1419
9.92744 -40.3383 -40.3383 -14.1488
9.93108 -42.0715 -42.0715 -14.1558
9.93471 -43.7498 -43.7498 -14.1627
9.93835 -45.3605 -45.3605 -14.1697
9.94198 -46.8913 -46.8913 -14.1766
9.94561 -48.3308 -48.3308 -14.1836
9.94924 -49.6679 -49.6679 -14.1905
9.95287 -50.8927 -50.8927 -14.1975
9.9565 -51.9959 -51.9959 -14.2044
9.96013 -52.9692 -52.9692 -14.2113
9.96375 -53.8052 -53.8052 -14.2183
9.96738 -54.4978 -54.4978 -14.2252
9.971 -55.0417 -55.0417 -14.2322
9.97463 -55.4329 -55.4329 -14.2391
9.97825 -55.6685 -55.6685 -14.246
9.98187 -55.7469 -55.7469 -14.253
9.98549 -55.6675 -55.6675 -14.2599
9.9891 -55.4311 -55.4311 -14.2669
9.99272 -55.0396 -55.0396 -14.2738
9.99633 -54.4961 -54.4961 -14.2808
9.99995 -53.8047 -53.8047 -14.2877
10.0036 -52.9708 -52.9708 -14.2946
10.0072 -52.001 -52.001 -14.3016
10.0108 -50.9025 -50.9025 -14.3085
10.0144 -49.6839 -49.6839 -14.3155
10.018 -48.3546 -48.3546 -14.3224
10.0216 -46.9246 -46.9246 -14.3294
10.0252 -45.405 -45.405 -14.3363
10.0288 -43.8073 -43.8073 -14.3432
10.0324 -42.1437 -42.1437 -14.3502
10.036 -40.4269 -40.4269 -14.3571
10.0396 -38.6701 -38.6701 -14.3641
10.0432 -36.8865 -36.8865 -14.371
10.0468 -35.0898 -35.0898 -14.378
10.0504 -33.2937 -33.2937 -14.3849
10.054 -31.5116 -31.5116 -14.3918
10.0576 -29.7574 -29.7574 -14.3988
10.0612 -28.0441 -28.0441 -14.4057
10.0648 -26.3849 -26.3849 -14.4127
10.0684 -24.7923 -24.7923 -14.4196
10.072 -23.2783 -23.2783 -14.4266
10.0756 -21.8544 -21.8544 -14.4335
10.0792 -20.5315 -20.5315 -14.4404
10.0827 -19.3193 -19.3193 -14.4474
10.0863 -18.2272 -18.2272 -14.4543
10.0899 -17.2633 -17.2633 -14.4613
10.0935 -16.4349 -16.4349 -14.4682
10.0971 -15.7481 -15.7481 -14.4751
10.1006 -15.2081 -15.2081 -14.4821
10.1042 -14.8189 -14.8189 -14.489
10.1078 -14.5834 -14.5834 -14.496
10.1114 -14.5032 -14.5032 -14.5029
10.115 -14.5788 -14.5788 -14.5099
10.1185 -14.8096 -14.8096 -14.5168
10.1221 -15.1937 -15.1937 -14.5237
10.1257 -15.7281 -15.7281 -14.5307
10.1292 -16.4086 -16.4086 -14.5376
10.1328 -17.2299 -17.2299 -14.5446
10.1364 -18.1858 -18.1858 -14.5515
10.1399 -19.2688 -19.2688 -14.5585
10.1435 -20.4706 -20.4706 -14.5654
10.1471 -21.782 -21.782 -14.5723
10.1506 -23.193 -23.193 -14.5793
10.1542 -24.6928 -24.6928 -14.5862
10.1578 -26.2699 -26.2699 -14.5932
10.1613 -27.9123 -27.9123 -14.6001
10.1649 -29.6075 -29.6075 -14.607
10.1684 -31.3424 -31.3424 -14.614
10.172 -33.104 -33.104 -14.6209
10.1755 -34.8788 -34.8788 -14.6279
10.1791 -36.6533 -36.6533 -14.6348
10.1827 -38.4141 -38.4141 -14.6418
10.1862 -40.1477 -40.1477 -14.6487
10.1898 -41.8409 -41.8409 -14.6557
10.1933 -43.4811 -43.4811 -14.6626
10.1969 -45.0556 -45.0556 -14.6695
10.2004 -46.5527 -46.5527 -14.6765
10.2039 -47.9609 -47.9609 -14.6834
10.2075 -49.2696 -49.2696 -14.6904
10.211 -50.4691 -50.4691 -14.6973
10.2146 -51.5501 -51.5501 -14.7043
10.2181 -52.5045 -52.5045 -14.7112
10.2216 -53.3253 -53.3253 -14.7181
10.2252 -54.0062 -54.0062 -14.7251
10.2287 -54.5423 -54.5423 -14.732
10.2323 -54.9294 -54.9294 -14.739
10.2358 -55.1647 -55.1647 -14.7459
10.2393 -55.2467 -55.2467 -14.7529
10.2429 -55.1747 -55.1747 -14.7598
10.2464 -54.9494 -54.9494 -14.7667
10.2499 -54.5727 -54.5727 -14.7737
10.2534 -54.0474 -54.0474 -14.7806
10.257 -53.3777 -53.3777 -14.7876
10.2605 -52.5689 -52.5689 -14.7945
10.264 -51.627 -51.627 -14.8014
10.2675 -50.5594 -50.5594 -14.8084
10.2711 -49.3743 -49.3743 -14.8153
10.2746 -48.0807 -48.0807 -14.8223
10.2781 -46.6887 -46.6887 -14.8292
10.2816 -45.2087 -45.2087 -14.8362
10.2851 -43.6522 -43.6522 -14.8431
10.2887 -42.0309 -42.0309 -14.85
10.2922 -40.3574 -40.3574 -14.857
10.2957 -38.6443 -38.6443 -14.8639
10.2992 -36.9046 -36.9046 -14.8709
10.3027 -35.1517 -35.1517 -14.8778
10.3062 -33.3989 -33.3989 -14.8848
10.3097 -31.6594 -31.6594 -14.8917
10.3132 -29.9465 -29.9465 -14.8986
10.3167 -28.2732 -28.2732 -14.9056
10.3202 -26.6522 -26.6522 -14.9125
10.3237 -25.0958 -25.0958 -14.9195
10.3272 -23.6157 -23.6157 -14.9264
10.3308 -22.2232 -22.2232 -14.9334
10.3343 -20.9287 -20.9287 -14.9403
10.3377 -19.7421 -19.7421 -14.9472
10.3412 -18.6722 -18.6722 -14.9542
10.3447 -17.7273 -17.7273 -14.9611
10.3482 -16.9142 -16.9142 -14.9681
10.3517 -16.2392 -16.2392 -14.975
10.3552 -15.7072 -15.7072 -14.9819
10.3587 -15.3222 -15.3222 -14.9889
10.3622 -15.0871 -15.0871 -14.9958
10.3657 -15.0035 -15.0035 -15.0028
10.3692 -15.0719 -15.0719 -15.0097
10.3727 -15.2917 -15.2917 -15.0167
10.3762 -15.6612 -15.6612 -15.0236
10.3796 -16.1774 -16.1774 -15.0306
10.3831 -16.8363 -16.8363 -15.0375
10.3866 -17.6328 -17.6328 -15.0444
10.3901 -18.5607 -18.5607 -15.0514
10.3936 -19.613 -19.613 -15.0583
10.397 -20.7814 -20.7814 -15.0653
10.4005 -22.0571 -22.0571 -15.0722
10.404 -23.4303 -23.4303 -15.0791
10.4075 -24.8905 -24.8905 -15.0861
10.4109 -26.4265 -26.4265 -15.093
10.4144 -28.0266 -28.0266 -15.1
10.4179 -29.6786 -29.6786 -15.1069
10.4214 -31.3698 -31.3698 -15.1139
10.4248 -33.0875 -33.0875 -15.1208
10.4283 -34.8185 -34.8185 -15.1277
10.4318 -36.5497 -36.5497 -15.1347
10.4352 -38.2679 -38.2679 -15.1416
10.4387 -39.96 -39.96 -15.1486
10.4422 -41.6133 -41.6133 -15.1555
10.4456 -43.2152 -43.2152 -15.1625
10.4491 -44.7535 -44.7535 -15.1694
10.4525 -46.2165 -46.2165 -15.1763
10.456 -47.5934 -47.5934 -15.1833
10.4594 -48.8735 -48.8735 -15.1902
10.4629 -50.0473 -50.0473 -15.1972
10.4664 -51.1059 -51.1059 -15.2041
10.4698 -52.0413 -52.0413 -15.2111
10.4733 -52.8466 -52.8466 -15.218
10.4767 -53.5156 -53.5156 -15.2249
10.4802 -54.0435 -54.0435 -15.2319
10.4836 -54.4263 -54.4263 -15.2388
10.4871 -54.6611 -54.6611 -15.2458
10.4905 -54.7463 -54.7463 -15.2527
10.4939 -54.6814 -54.6814 -15.2597
10.4974 -54.467 -54.467 -15.2666
10.5008 -54.1047 -54.1047 -15.2735
10.5043 -53.5975 -53.5975 -15.2805
10.5077 -52.9493 -52.9493 -15.2874
10.5111 -52.1651 -52.1651 -15.2944
10.5146 -51.2511 -51.2511 -15.3013
10.518 -50.2141 -50.2141 -15.3082
10.5215 -49.0623 -49.0623 -15.3152
10.5249 -47.8044 -47.8044 -15.3221
10.5283 -46.45 -46.45 -15.3291
10.5318 -45.0096 -45.0096 -15.336
10.5352 -43.4941 -43.4941 -15.343
10.5386 -41.9151 -41.9151 -15.3499
10.542 -40.2847 -40.2847 -15.3569
10.5455 -38.6153 -38.6153 -15.3638
10.5489 -36.9196 -36.9196 -15.3707
10.5523 -35.2105 -35.2105 -15.3777
10.5557 -33.501 -33.501 -15.3846
10.5592 -31.8041 -31.8041 -15.3916
10.5626 -30.1327 -30.1327 -15.3985
10.566 -28.4994 -28.4994 -15.4054
10.5694 -26.9168 -26.9168 -15.4124
10.5728 -25.3966 -25.3966 -15.4193
10.5762 -23.9506 -23.9506 -15.4263
10.5797 -22.5896 -22.5896 -15.4332
10.5831 -21.3238 -21.3238 -15.4402
10.5865 -20.1629 -20.1629 -15.4471
10.5899 -19.1156 -19.1156 -15.454
10.5933 -18.1898 -18.1898 -15.461
10.5967 -17.3923 -17.3923 -15.4679
10.6001 -16.7293 -16.7293 -15.4749
10.6035 -16.2056 -16.2056 -15.4818
10.6069 -15.8252 -15.8252 -15.4888
10.6103 -15.5907 -15.5907 -15.4957
10.6137 -15.5039 -15.5039 -15.5026
10.6171 -15.5654 -15.5654 -15.5096
10.6205 -15.7745 -15.7745 -15.5165
10.6239 -16.1296 -16.1296 -15.5235
10.6273 -16.6279 -16.6279 -15.5304
10.6307 -17.2655 -17.2655 -15.5374
10.6341 -18.0374 -18.0374 -15.5443
10.6375 -18.9376 -18.9376 -15.5512
10.6409 -19.9593 -19.9593 -15.5582
10.6443 -21.0946 -21.0946 -15.5651
10.6477 -22.3348 -22.3348 -15.5721
10.6511 -23.6703 -23.6703 -15.579
10.6545 -25.091 -25.091 -15.586
10.6579 -26.586 -26.586 -15.5929
10.6612 -28.1439 -28.1439 -15.5998
10.6646 -29.7528 -29.7528 -15.6068
10.668 -31.4004 -31.4004 -15.6137
10.6714 -33.0742 -33.0742 -15.6207
10.6748 -34.7614 -34.7614 -15.6276
10.6781 -36.4492 -36.4492 -15.6346
10.6815 -38.1248 -38.1248 -15.6415
10.6849 -39.7754 -39.7754 -15.6484
10.6883 -41.3886 -41.3886 -15.6554
10.6916 -42.9521 -42.9521 -15.6623
10.695 -44.4539 -44.4539 -15.6693
10.6984 -45.8829 -45.8829 -15.6762
10.7018 -47.2281 -47.2281 -15.6831
10.7051 -48.4794 -48.4794 -15.6901
10.7085 -49.6274 -49.6274 -15.697
10.7119 -50.6634 -50.6634 -15.704
10.7152 -51.5795 -51.5795 -15.7109
10.7186 -52.369 -52.369 -15.7179
10.722 -53.026 -53.026 -15.7248
10.7253 -53.5454 -53.5454 -15.7317
10.7287 -53.9235 -53.9235 -15.7387
10.732 -54.1575 -54.1575 -15.7456
10.7354 -54.2458 -54.2458 -15.7526
10.7388 -54.1877 -54.1877 -15.7595
10.7421 -53.9838 -53.9838 -15.7665
10.7455 -53.6358 -53.6358 -15.7734
10.7488 -53.1463 -53.1463 -15.7803
10.7522 -52.5194 -52.5194 -15.7873
10.7555 -51.7597 -51.7597 -15.7942
10.7589 -50.8732 -50.8732 -15.8012
10.7622 -49.8667 -49.8667 -15.8081
10.7656 -48.7479 -48.7479 -15.815
10.7689 -47.5254 -47.5254 -15.822
10.7723 -46.2086 -46.2086 -15.8289
10.7756 -44.8076 -44.8076 -15.8359
10.779 -43.3331 -43.3331 -15.8428
10.7823 -41.7963 -41.7963 -15.8498
10.7856 -40.209 -40.209 -15.8567
10.789 -38.5832 -38.5832 -15.8637
10.7923 -36.9313 -36.9313 -15.8706
10.7956 -35.266 -35.266 -15.8775
10.799 -33.5999 -33.5999 -15.8845
10.8023 -31.9456 -31.9456 -15.8914
10.8056 -30.3157 -30.3157 -15.8984
10.809 -28.7227 -28.7227 -15.9053
10.8123 -27.1785 -27.1785 -15.9123
10.8156 -25.6948 -25.6948 -15.9192
10.819 -24.283 -24.283 -15.9261
10.8223 -22.9536 -22.9536 -15.9331
10.8256 -21.7168 -21.7168 -15.94
10.8289 -20.5818 -20.5818 -15.947
10.8323 -19.5573 -19.5573 -15.9539
10.8356 -18.6508 -18.6508 -15.9608
10.8389 -17.8693 -17.8693 -15.9678
10.8422 -17.2185 -17.2185 -15.9747
10.8455 -16.7034 -16.7034 -15.9817
10.8489 -16.3277 -16.3277 -15.9886
10.8522 -16.0942 -16.0942 -15.9956
10.8555 -16.0045 -16.0045 -16.0025
10.8588 -16.0593 -16.0593 -16.0094
10.8621 -16.2581 -16.2581 -16.0164
10.8654 -16.5991 -16.5991 -16.0233
10.8687 -17.0797 -17.0797 -16.0303
10.8721 -17.6962 -17.6962 -16.0372
10.8754 -18.4437 -18.4437 -16.0441
10.8787 -19.3165 -19.3165 -16.0511
10.882 -20.3079 -20.3079 -16.058
10.8853 -21.4102 -21.4102 -16.065
10.8886 -22.615 -22.615 -16.0719
10.8919 -23.913 -23.913 -16.0789
10.8952 -25.2944 -25.2944 -16.0858
10.8985 -26.7485 -26.7485 -16.0927
10.9018 -28.2643 -28.2643 -16.0997
10.9051 -29.8301 -29.8301 -16.1066
10.9084 -31.4341 -31.4341 -16.1136
10.9117 -33.064 -33.064 -16.1205
10.9149 -34.7074 -34.7074 -16.1275
10.9182 -36.3518 -36.3518 -16.1344
10.9215 -37.9848 -37.9848 -16.1413
10.9248 -39.5939 -39.5939 -16.1483
10.9281 -41.1668 -41.1668 -16.1552
10.9314 -42.6918 -42.6918 -16.1622
10.9347 -44.1571 -44.1571 -16.1691
10.938 -45.5518 -45.5518 -16.1761
10.9413 -46.8652 -46.8652 -16.183
10.9445 -48.0875 -48.0875 -16.19
10.9478 -49.2095 -49.2095 -16.1969
10.9511 -50.2226 -50.2226 -16.2038
10.9544 -51.1192 -51.1192 -16.2108
10.9576 -51.8927 -51.8927 -16.2177
10.9609 -52.5372 -52.5372 -16.2247
10.9642 -53.048 -53.048 -16.2316
10.9675 -53.4212 -53.4212 -16.2385
10.9708 -53.6541 -53.6541 -16.2455
10.974 -53.7451 -53.7451 -16.2524
10.9773 -53.6935 -53.6935 -16.2594
10.9806 -53.4999 -53.4999 -16.2663
10.9838 -53.1658 -53.1658 -16.2733
10.9871 -52.694 -52.694 -16.2802
10.9904 -52.0879 -52.0879 -16.2871
10.9936 -51.3525 -51.3525 -16.2941
10.9969 -50.4933 -50.4933 -16.301
11.0002 -49.517 -49.517 -16.308
11.0034 -48.4311 -48.4311 -16.3149
11.0067 -47.2439 -47.2439 -16.3219
11.0099 -45.9646 -45.9646 -16.3288
11.0132 -44.6028 -44.6028 -16.3357
11.0164 -43.1691 -43.1691 -16.3427
11.0197 -41.6744 -41.6744 -16.3496
11.0229 -40.13 -40.13 -16.3566
11.0262 -38.5479 -38.5479 -16.3635
11.0295 -36.9399 -36.9399 -16.3705
11.0327 -35.3184 -35.3184 -16.3774
11.0359 -33.6956 -33.6956 -16.3843
11.0392 -32.084 -32.084 -16.3913
11.0424 -30.4958 -30.4958 -16.3982
11.0457 -28.943 -28.943 -16.4052
11.0489 -27.4373 -27.4373 -16.4121
11.0522 -25.9903 -25.9903 -16.419
11.0554 -24.6128 -24.6128 -16.426
11.0587 -23.3153 -23.3153 -16.4329
11.0619 -22.1076 -22.1076 -16.4399
11.0651 -20.9988 -20.9988 -16.4468
11.0684 -19.9972 -19.9972 -16.4538
11.0716 -19.1104 -19.1104 -16.4607
11.0748 -18.345 -18.345 -16.4676
11.0781 -17.7068 -17.7068 -16.4746
11.0813 -17.2005 -17.2005 -16.4815
11.0845 -16.8298 -16.8298 -16.4885
11.0878 -16.5975 -16.5975 -16.4954
11.091 -16.5053 -16.5053 -16.5024
11.0942 -16.5537 -16.5537 -16.5093
11.0974 -16.7423 -16.7423 -16.5162
11.1007 -17.0695 -17.0695 -16.5232
11.1039 -17.5327 -17.5327 -16.5301
11.1071 -18.1283 -18.1283 -16.5371
11.1103 -18.8517 -18.8517 -16.544
11.1135 -19.6973 -19.6973 -16.551
11.1168 -20.6586 -20.6586 -16.5579
11.12 -21.7281 -21.7281 -16.5648
11.1232 -22.8977 -22.8977 -16.5718
11.1264 -24.1584 -24.1584 -16.5787
11.1296 -25.5006 -25.5006 -16.5857
11.1328 -26.914 -26.914 -16.5926
11.136 -28.3877 -28.3877 -16.5996
11.1393 -29.9106 -29.9106 -16.6065
11.1425 -31.471 -31.471 -16.6134
11.1457 -33.057 -33.057 -16.6204
11.1489 -34.6566 -34.6566 -16.6273
11.1521 -36.2577 -36.2577 -16.6343
11.1553 -37.8479 -37.8479 -16.6412
11.1585 -39.4153 -39.4153 -16.6482
11.1617 -40.948 -40.948 -16.6551
11.1649 -42.4343 -42.4343 -16.662
11.1681 -43.863 -43.863 -16.669
11.1713 -45.2232 -45.2232 -16.6759
11.1745 -46.5047 -46.5047 -16.6829
11.1777 -47.6978 -47.6978 -16.6898
11.1809 -48.7935 -48.7935 -16.6968
11.1841 -49.7835 -49.7835 -16.7037
11.1873 -50.6604 -50.6604 -16.7106
11.1904 -51.4176 -51.4176 -16.7176
11.1936 -52.0495 -52.0495 -16.7245
11.1968 -52.5513 -52.5513 -16.7315
11.2 -52.9193 -52.9193 -16.7384
11.2032 -53.1508 -53.1508 -16.7453
11.2064 -53.2442 -53.2442 -16.7523
11.2096 -53.1989 -53.1989 -16.7592
11.2127 -53.0153 -53.0153 -16.7662
11.2159 -52.695 -52.695 -16.7731
11.2191 -52.2403 -52.2403 -16.7801
11.2223 -51.6551 -51.6551 -16.787
11.2255 -50.9436 -50.9436 -16.7939
11.2286 -50.1115 -50.1115 -16.8009
11.2318 -49.1653 -49.1653 -16.8078
11.235 -48.112 -48.112 -16.8148
11.2381 -46.9599 -46.9599 -16.8217
11.2413 -45.7178 -45.7178 -16.8287
11.2445 -44.3952 -44.3952 -16.8356
11.2477 -43.0022 -43.0022 -16.8425
11.2508 -41.5495 -41.5495 -16.8495
11.254 -40.0481 -40.0481 -16.8564
11.2571 -38.5094 -38.5094 -16.8634
11.2603 -36.9453 -36.9453 -16.8703
11.2635 -35.3675 -35.3675 -16.8773
11.2666 -33.7882 -33.7882 -16.8842
11.2698 -32.2193 -32.2193 -16.8911
11.273 -30.6728 -30.6728 -16.8981
11.2761 -29.1603 -29.1603 -16.905
11.2793 -27.6934 -27.6934 -16.912
11.2824 -26.2831 -26.2831 -16.9189
11.2856 -24.9401 -24.9401 -16.9259
11.2887 -23.6747 -23.6747 -16.9328
11.2919 -22.4963 -22.4963 -16.9397
11.295 -21.4138 -21.4138 -16.9467
11.2982 -20.4354 -20.4354 -16.9536
11.3013 -19.5685 -19.5685 -16.9606
11.3045 -18.8195 -18.8195 -16.9675
11.3076 -18.1941 -18.1941 -16.9745
11.3108 -17.6969 -17.6969 -16.9814
11.3139 -17.3315 -17.3315 -16.9883
11.3171 -17.1008 -17.1008 -16.9953
11.3202 -17.0062 -17.0062 -17.0022
11.3233 -17.0485 -17.0485 -17.0092
11.3265 -17.2272 -17.2272 -17.0161
11.3296 -17.5408 -17.5408 -17.0231
11.3327 -17.9869 -17.9869 -17.03
11.3359 -18.5619 -18.5619 -17.0369
11.339 -19.2615 -19.2615 -17.0439
11.3421 -20.0801 -20.0801 -17.0508
11.3453 -21.0115 -21.0115 -17.0578
11.3484 -22.0484 -22.0484 -17.0647
11.3515 -23.183 -23.183 -17.0717
11.3547 -24.4065 -24.4065 -17.0786
11.3578 -25.7096 -25.7096 -17.0855
11.3609 -27.0823 -27.0823 -17.0925
11.364 -28.5141 -28.5141 -17.0994
11.3672 -29.9941 -29.9941 -17.1064
11.3703 -31.511 -31.511 -17.1133
11.3734 -33.0532 -33.0532 -17.1202
11.3765 -34.6091 -34.6091 -17.1272
11.3796 -36.1667 -36.1667 -17.1341
11.3828 -37.7142 -37.7142 -17.1411
11.3859 -39.2399 -39.2399 -17.148
11.389 -40.7321 -40.7321 -17.155
11.3921 -42.1797 -42.1797 -17.1619
11.3952 -43.5715 -43.5715 -17.1688
11.3983 -44.8972 -44.8972 -17.1758
11.4014 -46.1465 -46.1465 -17.1827
11.4045 -47.3102 -47.3102 -17.1897
11.4076 -48.3794 -48.3794 -17.1966
11.4107 -49.3461 -49.3461 -17.2036
11.4138 -50.203 -50.203 -17.2105
11.4169 -50.9437 -50.9437 -17.2174
11.4201 -51.5626 -51.5626 -17.2244
11.4232 -52.0552 -52.0552 -17.2313
11.4263 -52.4178 -52.4178 -17.2383
11.4293 -52.6477 -52.6477 -17.2452
11.4324 -52.7433 -52.7433 -17.2522
11.4355 -52.704 -52.704 -17.2591
11.4386 -52.5301 -52.5301 -17.266
11.4417 -52.2231 -52.2231 -17.273
11.4448 -51.7855 -51.7855 -17.2799
11.4479 -51.2207 -51.2207 -17.2869
11.451 -50.533 -50.533 -17.2938
11.4541 -49.7278 -49.7278 -17.3008
11.4572 -48.8113 -48.8113 -17.3077
11.4603 -47.7906 -47.7906 -17.3146
11.4633 -46.6734 -46.6734 -17.3216
11.4664 -45.4684 -45.4684 -17.3285
11.4695 -44.1848 -44.1848 -17.3355
11.4726 -42.8324 -42.8324 -17.3424
11.4757 -41.4215 -41.4215 -17.3494
11.4788 -39.9629 -39.9629 -17.3563
11.4818 -38.4678 -38.4678 -17.3632
11.4849 -36.9475 -36.9475 -17.3702
11.488 -35.4135 -35.4135 -17.3771
11.4911 -33.8777 -33.8777 -17.3841
11.4941 -32.3515 -32.3515 -17.391
11.4972 -30.8467 -30.8467 -17.398
11.5003 -29.3747 -29.3747 -17.4049
11.5033 -27.9466 -27.9466 -17.4118
11.5064 -26.5732 -26.5732 -17.4188
11.5095 -25.2649 -25.2649 -17.4257
11.5125 -24.0317 -24.0317 -17.4327
11.5156 -22.8828 -22.8828 -17.4396
11.5187 -21.8269 -21.8269 -17.4465
11.5217 -20.8719 -20.8719 -17.4535
11.5248 -20.0251 -20.0251 -17.4604
11.5278 -19.2928 -19.2928 -17.4674
11.5309 -18.6804 -18.6804 -17.4743
11.534 -18.1925 -18.1925 -17.4813
11.537 -17.8328 -17.8328 -17.4882
11.5401 -17.6038 -17.6038 -17.4951
11.5431 -17.5072 -17.5072 -17.5021
11.5462 -17.5437 -17.5437 -17.509
11.5492 -17.7128 -17.7128 -17.516
11.5523 -18.0131 -18.0131 -17.5229
11.5553 -18.4423 -18.4423 -17.5299
11.5584 -18.997 -18.997 -17.5368
11.5614 -19.6729 -19.6729 -17.5437
11.5645 -20.4647 -20.4647 -17.5507
11.5675 -21.3664 -21.3664 -17.5576
11.5706 -22.371 -22.371 -17.5646
11.5736 -23.4708 -23.4708 -17.5715
11.5766 -24.6573 -24.6573 -17.5785
11.5797 -25.9215 -25.9215 -17.5854
11.5827 -27.2536 -27.2536 -17.5923
11.5857 -28.6436 -28.6436 -17.5993
11.5888 -30.0808 -30.0808 -17.6062
11.5918 -31.5542 -31.5542 -17.6132
11.5948 -33.0527 -33.0527 -17.6201
11.5979 -34.5647 -34.5647 -17.6271
11.6009 -36.0788 -36.0788 -17.634
11.6039 -37.5835 -37.5835 -17.6409
11.607 -39.0674 -39.0674 -17.6479
11.61 -40.5192 -40.5192 -17.6548
11.613 -41.9279 -41.9279 -17.6618
11.616 -43.2828 -43.2828 -17.6687
11.6191 -44.5737 -44.5737 -17.6757
11.6221 -45.7907 -45.7907 -17.6826
11.6251 -46.9248 -46.9248 -17.6895
11.6281 -47.9673 -47.9673 -17.6965
11.6311 -48.9105 -48.9105 -17.7034
11.6342 -49.7472 -49.7472 -17.7104
11.6372 -50.4711 -50.4711 -17.7173
11.6402 -51.0768 -51.0768 -17.7242
11.6432 -51.5599 -51.5599 -17.7312
11.6462 -51.9168 -51.9168 -17.7381
11.6492 -52.1447 -52.1447 -17.7451
11.6522 -52.2422 -52.2422 -17.752
11.6553 -52.2086 -52.2086 -17.759
11.6583 -52.0442 -52.0442 -17.7659
11.6613 -51.7504 -51.7504 -17.7728
11.6643 -51.3295 -51.3295 -17.7798
11.6673 -50.7849 -50.7849 -17.7867
11.6703 -50.1207 -50.1207 -17.7937
11.6733 -49.3422 -49.3422 -17.8006
11.6763 -48.4553 -48.4553 -17.8075
11.6793 -47.4668 -47.4668 -17.8145
11.6823 -46.3844 -46.3844 -17.8214
11.6853 -45.2163 -45.2163 -17.8284
11.6883 -43.9716 -43.9716 -17.8353
11.6913 -42.6596 -42.6596 -17.8423
11.6943 -41.2905 -41.2905 -17.8492
11.6972 -39.8747 -39.8747 -17.8562
11.7002 -38.423 -38.423 -17.8631
11.7032 -36.9465 -36.9465 -17.87
11.7062 -35.4563 -35.4563 -17.877
11.7092 -33.9639 -33.9639 -17.8839
11.7122 -32.4806 -32.4806 -17.8909
11.7152 -31.0176 -31.0176 -17.8978
11.7181 -29.5861 -29.5861 -17.9048
11.7211 -28.1969 -28.1969 -17.9117
11.7241 -26.8606 -26.8606 -17.9186
11.7271 -25.5871 -25.5871 -17.9256
11.7301 -24.3863 -24.3863 -17.9325
11.733 -23.2671 -23.2671 -17.9395
11.736 -22.238 -22.238 -17.9464
11.739 -21.3067 -21.3067 -17.9534
11.742 -20.4802 -20.4802 -17.9603
11.7449 -19.7648 -19.7648 -17.9672
11.7479 -19.1657 -19.1657 -17.9742
11.7509 -18.6875 -18.6875 -17.9811
11.7539 -18.3336 -18.3336 -17.9881
11.7568 -18.1067 -18.1067 -17.995
11.7598 -18.0084 -18.0084 -18.0019
11.7628 -18.0392 -18.0392 -18.0089
11.7657 -18.199 -18.199 -18.0158
11.7687 -18.4863 -18.4863 -18.0228
11.7716 -18.8989 -18.8989 -18.0297
11.7746 -19.4335 -19.4335 -18.0367
11.7776 -20.086 -20.086 -18.0436
11.7805 -20.8513 -20.8513 -18.0505
11.7835 -21.7235 -21.7235 -18.0575
11.7864 -22.696 -22.696 -18.0644
11.7894 -23.7611 -23.7611 -18.0714
11.7923 -24.9107 -24.9107 -18.0783
11.7953 -26.1361 -26.1361 -18.0852
11.7982 -27.4279 -27.4279 -18.0922
11.8012 -28.7761 -28.7761 -18.0991
11.8041 -30.1706 -30.1706 -18.1061
11.8071 -31.6006 -31.6006 -18.113
11.81 -33.0552 -33.0552 -18.12
11.813 -34.5235 -34.5235 -18.1269
11.8159 -35.9941 -35.9941 -18.1338
11.8188 -37.456 -37.456 -18.1408
11.8218 -38.8981 -38.8981 -18.1477
11.8247 -40.3093 -40.3093 -18.1547
11.8277 -41.679 -41.679 -18.1616
11.8306 -42.9968 -42.9968 -18.1686
11.8335 -44.2527 -44.2527 -18.1755
11.8365 -45.4373 -45.4373 -18.1824
11.8394 -46.5416 -46.5416 -18.1894
11.8423 -47.5572 -47.5572 -18.1963
11.8453 -48.4766 -48.4766 -18.2033
11.8482 -49.2928 -49.2928 -18.2102
11.8511 -49.9997 -49.9997 -18.2172
11.8541 -50.592 -50.592 -18.2241
11.857 -51.0654 -51.0654 -18.2311
11.8599 -51.4162 -51.4162 -18.238
11.8628 -51.642 -51.642 -18.2449
11.8658 -51.7411 -51.7411 -18.2519
11.8687 -51.7129 -51.7129 -18.2588
11.8716 -51.5577 -51.5577 -18.2658
11.8745 -51.2767 -51.2767 -18.2727
11.8774 -50.8724 -50.8724 -18.2796
11.8804 -50.3477 -50.3477 -18.2866
11.8833 -49.7068 -49.7068 -18.2935
11.8862 -48.9547 -48.9547 -18.3005
11.8891 -48.0971 -48.0971 -18.3074
11.892 -47.1407 -47.1407 -18.3144
11.8949 -46.0928 -46.0928 -18.3213
11.8978 -44.9616 -44.9616 -18.3282
11.9007 -43.7555 -43.7555 -18.3352
11.9036 -42.4839 -42.4839 -18.3421
11.9065 -41.1565 -41.1565 -18.3491
11.9095 -39.7834 -39.7834 -18.356
11.9124 -38.3751 -38.3751 -18.363
11.9153 -36.9423 -36.9423 -18.3699
11.9182 -35.4959 -35.4959 -18.3768
11.9211 -34.047 -34.047 -18.3838
11.924 -32.6065 -32.6065 -18.3907
11.9269 -31.1855 -31.1855 -18.3977
11.9298 -29.7946 -29.7946 -18.4046
11.9326 -28.4444 -28.4444 -18.4115
11.9355 -27.1452 -27.1452 -18.4185
11.9384 -25.9068 -25.9068 -18.4254
11.9413 -24.7385 -24.7385 -18.4324
11.9442 -23.6492 -23.6492 -18.4393
11.9471 -22.6471 -22.6471 -18.4463
11.95 -21.7397 -21.7397 -18.4532
11.9529 -20.9338 -20.9338 -18.4601
11.9558 -20.2355 -20.2355 -18.4671
11.9586 -19.65 -19.65 -18.474
11.9615 -19.1817 -19.1817 -18.481
11.9644 -18.8339 -18.8339 -18.4879
11.9673 -18.6094 -18.6094 -18.4949
11.9702 -18.5096 -18.5096 -18.5018
11.973 -18.5351 -18.5351 -18.5087
11.9759 -18.6859 -18.6859 -18.5157
11.9788 -18.9604 -18.9604 -18.5226
11.9817 -19.3567 -19.3567 -18.5296
11.9845 -19.8715 -19.8715 -18.5365
11.9874 -20.5008 -20.5008 -18.5435
11.9903 -21.2398 -21.2398 -18.5504
11.9932 -22.0828 -22.0828 -18.5574
11.996 -23.0232 -23.0232 -18.5643
11.9989 -24.0539 -24.0539 -18.5712
12.0017 -25.1668 -25.1668 -18.5782
12.0046 -26.3536 -26.3536 -18.5851
12.0075 -27.605 -27.605 -18.5921
12.0103 -28.9117 -28.9117 -18.599
12.0132 -30.2634 -30.2634 -18.6059
12.0161 -31.6501 -31.6501 -18.6129
12.0189 -33.061 -33.061 -18.6198
12.0218 -34.4855 -34.4855 -18.6268
12.0246 -35.9126 -35.9126 -18.6337
12.0275 -37.3317 -37.3317 -18.6407
12.0303 -38.7317 -38.7317 -18.6476
12.0332 -40.1023 -40.1023 -18.6545
12.036 -41.4329 -41.4329 -18.6615
12.0389 -42.7135 -42.7135 -18.6684
12.0417 -43.9343 -43.9343 -18.6754
12.0446 -45.0863 -45.0863 -18.6823
12.0474 -46.1606 -46.1606 -18.6893
12.0503 -47.1491 -47.1491 -18.6962
12.0531 -48.0445 -48.0445 -18.7031
12.056 -48.84 -48.84 -18.7101
12.0588 -49.5296 -49.5296 -18.717
12.0617 -50.1082 -50.1082 -18.724
12.0645 -50.5715 -50.5715 -18.7309
12.0673 -50.9161 -50.9161 -18.7379
12.0702 -51.1394 -51.1394 -18.7448
12.073 -51.2398 -51.2398 -18.7517
12.0758 -51.2168 -51.2168 -18.7587
12.0787 -51.0705 -51.0705 -18.7656
12.0815 -50.8022 -50.8022 -18.7726
12.0843 -50.414 -50.414 -18.7795
12.0872 -49.909 -49.909 -18.7864
12.09 -49.2912 -49.2912 -18.7934
12.0928 -48.5652 -48.5652 -18.8003
12.0956 -47.7368 -47.7368 -18.8073
12.0985 -46.8123 -46.8123 -18.8142
12.1013 -45.7988 -45.7988 -18.8212
12.1041 -44.7041 -44.7041 -18.8281
12.1069 -43.5366 -43.5366 -18.835
12.1098 -42.3053 -42.3053 -18.842
12.1126 -41.0194 -41.0194 -18.8489
12.1154 -39.6889 -39.6889 -18.8559
12.1182 -38.324 -38.324 -18.8628
12.121 -36.9349 -36.9349 -18.8698
12.1238 -35.5323 -35.5323 -18.8767
12.1266 -34.1269 -34.1269 -18.8836
12.1295 -32.7294 -32.7294 -18.8906
12.1323 -31.3503 -31.3503 -18.8975
12.1351 -30.0001 -30.0001 -18.9045
12.1379 -28.6891 -28.6891 -18.9114
12.1407 -27.4272 -27.4272 -18.9184
12.1435 -26.2239 -26.2239 -18.9253
12.1463 -25.0883 -25.0883 -18.9322
12.1491 -24.0291 -24.0291 -18.9392
12.1519 -23.0542 -23.0542 -18.9461
12.1547 -22.1709 -22.1709 -18.9531
12.1575 -21.3858 -21.3858 -18.96
12.1603 -20.7049 -20.7049 -18.967
12.1631 -20.1333 -20.1333 -18.9739
12.1659 -19.6751 -19.6751 -18.9808
12.1687 -19.3338 -19.3338 -18.9878
12.1715 -19.1118 -19.1118 -18.9947
12.1743 -19.0108 -19.0108 -19.0017
12.1771 -19.0314 -19.0314 -19.0086
12.1799 -19.1733 -19.1733 -19.0156
12.1826 -19.4354 -19.4354 -19.0225
12.1854 -19.8156 -19.8156 -19.0294
12.1882 -20.3108 -20.3108 -19.0364
12.191 -20.9172 -20.9172 -19.0433
12.1938 -21.6302 -21.6302 -19.0503
12.1966 -22.4441 -22.4441 -19.0572
12.1993 -23.3528 -23.3528 -19.0642
12.2021 -24.3491 -24.3491 -19.0711
12.2049 -25.4256 -25.4256 -19.078
12.2077 -26.5738 -26.5738 -19.085
12.2105 -27.7851 -27.7851 -19.0919
12.2132 -29.0502 -29.0502 -19.0989
12.216 -30.3594 -30.3594 -19.1058
12.2188 -31.7028 -31.7028 -19.1127
12.2215 -33.07 -33.07 -19.1197
12.2243 -34.4506 -34.4506 -19.1266
12.2271 -35.8343 -35.8343 -19.1336
12.2299 -37.2104 -37.2104 -19.1405
12.2326 -38.5685 -38.5685 -19.1475
12.2354 -39.8983 -39.8983 -19.1544
12.2381 -41.1897 -41.1897 -19.1613
12.2409 -42.4329 -42.4329 -19.1683
12.2437 -43.6185 -43.6185 -19.1752
12.2464 -44.7376 -44.7376 -19.1822
12.2492 -45.7818 -45.7818 -19.1891
12.252 -46.743 -46.743 -19.1961
12.2547 -47.6142 -47.6142 -19.203
12.2575 -48.3887 -48.3887 -19.2099
12.2602 -49.0608 -49.0608 -19.2169
12.263 -49.6255 -49.6255 -19.2238
12.2657 -50.0785 -50.0785 -19.2308
12.2685 -50.4165 -50.4165 -19.2377
12.2712 -50.637 -50.637 -19.2447
12.274 -50.7385 -50.7385 -19.2516
12.2767 -50.7203 -50.7203 -19.2585
12.2795 -50.5827 -50.5827 -19.2655
12.2822 -50.3267 -50.3267 -19.2724
12.285 -49.9545 -49.9545 -19.2794
12.2877 -49.469 -49.469 -19.2863
12.2904 -48.8739 -48.8739 -19.2933
12.2932 -48.1739 -48.1739 -19.3002
12.2959 -47.3744 -47.3744 -19.3071
12.2987 -46.4816 -46.4816 -19.3141
12.3014 -45.5023 -45.5023 -19.321
12.3041 -44.4441 -44.4441 -19.328
12.3069 -43.315 -43.315 -19.3349
12.3096 -42.1237 -42.1237 -19.3419
12.3123 -40.8794 -40.8794 -19.3488
12.315 -39.5914 -39.5914 -19.3557
12.3178 -38.2697 -38.2697 -19.3627
12.3205 -36.9244 -36.9244 -19.3696
12.3232 -35.5656 -35.5656 -19.3766
12.326 -34.2037 -34.2037 -19.3835
12.3287 -32.8491 -32.8491 -19.3905
12.3314 -31.512 -31.512 -19.3974
12.3341 -30.2026 -30.2026 -19.4043
12.3368 -28.9309 -28.9309 -19.4113
12.3396 -27.7064 -27.7064 -19.4182
12.3423 -26.5384 -26.5384 -19.4252
12.345 -25.4358 -25.4358 -19.4321
12.3477 -24.4068 -24.4068 -19.439
12.3504 -23.4593 -23.4593 -19.446
12.3531 -22.6003 -22.6003 -19.4529
12.3559 -21.8363 -21.8363 -19.4599
12.3586 -21.1731 -21.1731 -19.4668
12.3613 -20.6155 -20.6155 -19.4738
12.364 -20.1678 -20.1678 -19.4807
12.3667 -19.8331 -19.8331 -19.4876
12.3694 -19.6141 -19.6141 -19.4946
12.3721 -19.5121 -19.5121 -19.5015
12.3748 -19.528 -19.528 -19.5085
12.3775 -19.6614 -19.6614 -19.5154
12.3802 -19.9113 -19.9113 -19.5223
12.3829 -20.2756 -20.2756 -19.5293
12.3856 -20.7516 -20.7516 -19.5362
12.3883 -21.3353 -21.3353 -19.5432
12.391 -22.0224 -22.0224 -19.5501
12.3937 -22.8075 -22.8075 -19.5571
12.3964 -23.6846 -23.6846 -19.564
12.3991 -24.6469 -24.6469 -19.571
12.4018 -25.6869 -25.6869 -19.5779
12.4045 -26.7969 -26.7969 -19.5848
12.4072 -27.9681 -27.9681 -19.5918
12.4098 -29.1918 -29.1918 -19.5987
12.4125 -30.4585 -30.4585 -19.6057
12.4152 -31.7586 -31.7586 -19.6126
12.4179 -33.0821 -33.0821 -19.6196
12.4206 -34.419 -34.419 -19.6265
12.4233 -35.7591 -35.7591 -19.6334
12.4259 -37.0923 -37.0923 -19.6404
12.4286 -38.4083 -38.4083 -19.6473
12.4313 -39.6972 -39.6972 -19.6543
12.434 -40.9493 -40.9493 -19.6612
12.4367 -42.1551 -42.1551 -19.6682
12.4393 -43.3053 -43.3053 -19.6751
12.442 -44.3914 -44.3914 -19.682
12.4447 -45.4052 -45.4052 -19.689
12.4473 -46.3389 -46.3389 -19.6959
12.45 -47.1856 -47.1856 -19.7029
12.4527 -47.939 -47.939 -19.7098
12.4553 -48.5933 -48.5933 -19.7168
12.458 -49.1437 -49.1437 -19.7237
12.4607 -49.5862 -49.5862 -19.7306
12.4633 -49.9174 -49.9174 -19.7376
12.466 -50.1349 -50.1349 -19.7445
12.4687 -50.2372 -50.2372 -19.7515
12.4713 -50.2236 -50.2236 -19.7584
12.474 -50.0943 -50.0943 -19.7653
12.4766 -49.8504 -49.8504 -19.7723
12.4793 -49.4939 -49.4939 -19.7792
12.4819 -49.0275 -49.0275 -19.7862
12.4846 -48.455 -48.455 -19.7931
12.4873 -47.7808 -47.7808 -19.8001
12.4899 -47.01 -47.01 -19.807
12.4926 -46.1486 -46.1486 -19.8139
12.4952 -45.2034 -45.2034 -19.8209
12.4979 -44.1814 -44.1814 -19.8278
12.5005 -43.0906 -43.0906 -19.8348
12.5031 -41.9393 -41.9393 -19.8417
12.5058 -40.7363 -40.7363 -19.8486
12.5084 -39.4908 -39.4908 -19.8556
12.5111 -38.2124 -38.2124 -19.8625
12.5137 -36.9106 -36.9106 -19.8695
12.5163 -35.5956 -35.5956 -19.8764
12.519 -34.2773 -34.2773 -19.8834
12.5216 -32.9656 -32.9656 -19.8903
12.5243 -31.6706 -31.6706 -19.8973
12.5269 -30.4021 -30.4021 -19.9042
12.5295 -29.1698 -29.1698 -19.9111
12.5322 -27.9828 -27.9828 -19.9181
12.5348 -26.8503 -26.8503 -19.925
12.5374 -25.7808 -25.7808 -19.932
12.5401 -24.7823 -24.7823 -19.9389
12.5427 -23.8624 -23.8624 -19.9459
12.5453 -23.028 -23.028 -19.9528
12.5479 -22.2853 -22.2853 -19.9597
12.5505 -21.6399 -21.6399 -19.9667
12.5532 -21.0967 -21.0967 -19.9736
12.5558 -20.6596 -20.6596 -19.9806
12.5584 -20.332 -20.332 -19.9875
12.561 -20.1161 -20.1161 -19.9945
12.5637 -20.0135 -20.0135 -20.0014
12.5663 -20.0249 -20.0249 -20.0083
12.5689 -20.1501 -20.1501 -20.0153
12.5715 -20.3881 -20.3881 -20.0222
12.5741 -20.7368 -20.7368 -20.0292
12.5767 -21.1937 -21.1937 -20.0361
12.5793 -21.755 -21.755 -20.043
12.5819 -22.4165 -22.4165 -20.05
12.5846 -23.173 -23.173 -20.0569
12.5871 -24.0187 -24.0187 -20.0639
12.5898 -24.9471 -24.9471 -20.0708
12.5924 -25.9509 -25.9509 -20.0778
12.595 -27.0227 -27.0227 -20.0847
12.5976 -28.154 -28.154 -20.0916
12.6002 -29.3364 -29.3364 -20.0986
12.6028 -30.5606 -30.5606 -20.1055
12.6054 -31.8175 -31.8175 -20.1125
12.608 -33.0974 -33.0974 -20.1194
12.6106 -34.3905 -34.3905 -20.1263
12.6131 -35.6871 -35.6871 -20.1333
12.6158 -36.9773 -36.9773 -20.1402
12.6183 -38.2512 -38.2512 -20.1472
12.6209 -39.4992 -39.4992 -20.1541
12.6235 -40.7118 -40.7118 -20.1611
12.6261 -41.88 -41.88 -20.168
12.6287 -42.9947 -42.9947 -20.1749
12.6313 -44.0476 -44.0476 -20.1819
12.6339 -45.0308 -45.0308 -20.1888
12.6365 -45.9368 -45.9368 -20.1958
12.639 -46.7589 -46.7589 -20.2027
12.6416 -47.4908 -47.4908 -20.2097
12.6442 -48.1271 -48.1271 -20.2166
12.6468 -48.6631 -48.6631 -20.2235
12.6494 -49.0947 -49.0947 -20.2305
12.6519 -49.4188 -49.4188 -20.2374
12.6545 -49.633 -49.633 -20.2444
12.6571 -49.7358 -49.7358 -20.2513
12.6596 -49.7265 -49.7265 -20.2583
12.6622 -49.6053 -49.6053 -20.2652
12.6648 -49.3732 -49.3732 -20.2722
12.6674 -49.0322 -49.0322 -20.2791
12.6699 -48.5847 -48.5847 -20.286
12.6725 -48.0345 -48.0345 -20.293
12.6751 -47.3857 -47.3857 -20.2999
12.6776 -46.6435 -46.6435 -20.3069
12.6802 -45.8134 -45.8134 -20.3138
12.6828 -44.9019 -44.9019 -20.3207
12.6853 -43.916 -43.916 -20.3277
12.6879 -42.8634 -42.8634 -20.3346
12.6904 -41.7519 -41.7519 -20.3416
12.693 -40.5902 -40.5902 -20.3485
12.6955 -39.3871 -39.3871 -20.3555
12.6981 -38.1518 -38.1518 -20.3624
12.7007 -36.8937 -36.8937 -20.3693
12.7032 -35.6225 -35.6225 -20.3763
12.7058 -34.3477 -34.3477 -20.3832
12.7083 -33.0791 -33.0791 -20.3902
12.7109 -31.8262 -31.8262 -20.3971
12.7134 -30.5987 -30.5987 -20.4041
12.7159 -29.4058 -29.4058 -20.411
12.7185 -28.2566 -28.2566 -20.4179
12.721 -27.1596 -27.1596 -20.4249
12.7236 -26.1234 -26.1234 -20.4318
12.7261 -25.1555 -25.1555 -20.4388
12.7287 -24.2634 -24.2634 -20.4457
12.7312 -23.4538 -23.4538 -20.4526
12.7337 -22.7327 -22.7327 -20.4596
12.7363 -22.1055 -22.1055 -20.4665
12.7388 -21.5768 -21.5768 -20.4735
12.7413 -21.1507 -21.1507 -20.4804
12.7439 -20.8303 -20.8303 -20.4874
12.7464 -20.6178 -20.6178 -20.4943
12.7489 -20.5149 -20.5149 -20.5012
12.7515 -20.5221 -20.5221 -20.5082
12.754 -20.6394 -20.6394 -20.5151
12.7565 -20.8656 -20.8656 -20.5221
12.759 -21.1991 -21.1991 -20.529
12.7616 -21.6372 -21.6372 -20.536
12.7641 -22.1763 -22.1763 -20.5429
12.7666 -22.8125 -22.8125 -20.5498
12.7691 -23.5406 -23.5406 -20.5568
12.7716 -24.3551 -24.3551 -20.5637
12.7742 -25.2497 -25.2497 -20.5707
12.7767 -26.2176 -26.2176 -20.5776
12.7792 -27.2513 -27.2513 -20.5846
12.7817 -28.3428 -28.3428 -20.5915
12.7842 -29.484 -29.484 -20.5984
12.7867 -30.6659 -30.6659 -20.6054
12.7892 -31.8796 -31.8796 -20.6123
12.7918 -33.1159 -33.1159 -20.6193
12.7943 -34.3653 -34.3653 -20.6262
12.7968 -35.6183 -35.6183 -20.6332
12.7993 -36.8654 -36.8654 -20.6401
12.8018 -38.0971 -38.0971 -20.647
12.8043 -39.3041 -39.3041 -20.654
12.8068 -40.4773 -40.4773 -20.6609
12.8093 -41.6076 -41.6076 -20.6679
12.8118 -42.6867 -42.6867 -20.6748
12.8143 -43.7062 -43.7062 -20.6818
12.8168 -44.6587 -44.6587 -20.6887
12.8193 -45.5368 -45.5368 -20.6956
12.8218 -46.334 -46.334 -20.7026
12.8243 -47.0442 -47.0442 -20.7095
12.8268 -47.6623 -47.6623 -20.7165
12.8293 -48.1835 -48.1835 -20.7234
12.8318 -48.604 -48.604 -20.7304
12.8342 -48.9208 -48.9208 -20.7373
12.8367 -49.1314 -49.1314 -20.7442
12.8392 -49.2344 -49.2344 -20.7512
12.8417 -49.2292 -49.2292 -20.7581
12.8442 -49.1158 -49.1158 -20.7651
12.8467 -48.8952 -48.8952 -20.772
12.8492 -48.5693 -48.5693 -20.7789
12.8516 -48.1406 -48.1406 -20.7859
12.8541 -47.6124 -47.6124 -20.7928
12.8566 -46.9889 -46.9889 -20.7998
12.8591 -46.2749 -46.2749 -20.8067
12.8615 -45.4759 -45.4759 -20.8137
12.864 -44.598 -44.598 -20.8206
12.8665 -43.6481 -43.6481 -20.8275
12.869 -42.6334 -42.6334 -20.8345
12.8714 -41.5617 -41.5617 -20.8414
12.8739 -40.4411 -40.4411 -20.8484
12.8764 -39.2803 -39.2803 -20.8553
12.8788 -38.0881 -38.0881 -20.8623
12.8813 -36.8737 -36.8737 -20.8692
12.8838 -35.6461 -35.6461 -20.8761
12.8862 -34.4149 -34.4149 -20.8831
12.8887 -33.1893 -33.1893 -20.89
12.8912 -31.9787 -31.9787 -20.897
12.8936 -30.7923 -30.7923 -20.9039
12.8961 -29.639 -29.639 -20.9109
12.8985 -28.5275 -28.5275 -20.9178
12.901 -27.4664 -27.4664 -20.9247
12.9034 -26.4635 -26.4635 -20.9317
12.9059 -25.5265 -25.5265 -20.9386
12.9084 -24.6625 -24.6625 -20.9456
12.9108 -23.8778 -23.8778 -20.9525
12.9133 -23.1785 -23.1785 -20.9595
12.9157 -22.5696 -22.5696 -20.9664
12.9182 -22.0559 -22.0559 -20.9733
12.9206 -21.641 -21.641 -20.9803
12.923 -21.3281 -21.3281 -20.9872
12.9255 -21.1193 -21.1193 -20.9942
12.9279 -21.0163 -21.0163 -21.0011
12.9304 -21.0196 -21.0196 -21.0081
12.9328 -21.1292 -21.1292 -21.015
12.9353 -21.3441 -21.3441 -21.0219
12.9377 -21.6625 -21.6625 -21.0289
12.9401 -22.082 -22.082 -21.0358
12.9426 -22.5993 -22.5993 -21.0428
12.945 -23.2102 -23.2102 -21.0497
12.9474 -23.9102 -23.9102 -21.0567
12.9499 -24.6938 -24.6938 -21.0636
12.9523 -25.5548 -25.5548 -21.0705
12.9547 -26.4869 -26.4869 -21.0775
12.9572 -27.4826 -27.4826 -21.0844
12.9596 -28.5345 -28.5345 -21.0914
12.962 -29.6345 -29.6345 -21.0983
12.9644 -30.7742 -30.7742 -21.1053
12.9669 -31.9449 -31.9449 -21.1122
12.9693 -33.1376 -33.1376 -21.1191
12.9717 -34.3432 -34.3432 -21.1261
12.9741 -35.5527 -35.5527 -21.133
12.9765 -36.7567 -36.7567 -21.14
12.979 -37.9462 -37.9462 -21.1469
12.9814 -39.1121 -39.1121 -21.1538
12.9838 -40.2456 -40.2456 -21.1608
12.9862 -41.338 -41.338 -21.1677
12.9886 -42.3813 -42.3813 -21.1747
12.991 -43.3673 -43.3673 -21.1816
12.9934 -44.2888 -44.2888 -21.1886
12.9959 -45.1388 -45.1388 -21.1955
12.9983 -45.9109 -45.9109 -21.2024
13.0007 -46.5992 -46.5992 -21.2094
13.0031 -47.1988 -47.1988 -21.2163
13.0055 -47.705 -47.705 -21.2233
13.0079 -48.1142 -48.1142 -21.2302
13.0103 -48.4233 -48.4233 -21.2372
13.0127 -48.63 -48.63 -21.2441
13.0151 -48.733 -48.733 -21.251
13.0175 -48.7315 -48.7315 -21.258
13.0199 -48.6257 -48.6257 -21.2649
13.0223 -48.4164 -48.4164 -21.2719
13.0247 -48.1054 -48.1054 -21.2788
13.0271 -47.6951 -47.6951 -21.2858
13.0295 -47.1887 -47.1887 -21.2927
13.0318 -46.5902 -46.5902 -21.2996
13.0342 -45.9042 -45.9042 -21.3066
13.0366 -45.1361 -45.1361 -21.3135
13.039 -44.2917 -44.2917 -21.3205
13.0414 -43.3775 -43.3775 -21.3274
13.0438 -42.4007 -42.4007 -21.3344
13.0462 -41.3685 -41.3685 -21.3413
13.0485 -40.2891 -40.2891 -21.3482
13.0509 -39.1705 -39.1705 -21.3552
13.0533 -38.0213 -38.0213 -21.3621
13.0557 -36.8504 -36.8504 -21.3691
13.0581 -35.6666 -35.6666 -21.376
13.0604 -34.479 -34.479 -21.383
13.0628 -33.2965 -33.2965 -21.3899
13.0652 -32.1281 -32.1281 -21.3968
13.0676 -30.9828 -30.9828 -21.4038
13.0699 -29.8692 -29.8692 -21.4107
13.0723 -28.7957 -28.7957 -21.4177
13.0747 -27.7705 -27.7705 -21.4246
13.077 -26.8012 -26.8012 -21.4316
13.0794 -25.8953 -25.8953 -21.4385
13.0818 -25.0594 -25.0594 -21.4454
13.0841 -24.3 -24.3 -21.4524
13.0865 -23.6226 -23.6226 -21.4593
13.0889 -23.0325 -23.0325 -21.4663
13.0912 -22.5338 -22.5338 -21.4732
13.0936 -22.1304 -22.1304 -21.4801
13.0959 -21.8253 -21.8253 -21.4871
13.0983 -21.6205 -21.6205 -21.494
13.1007 -21.5177 -21.5177 -21.501
13.103 -21.5174 -21.5174 -21.5079
13.1054 -21.6196 -21.6196 -21.5149
13.1077 -21.8233 -21.8233 -21.5218
13.1101 -22.127 -22.127 -21.5287
13.1124 -22.5282 -22.5282 -21.5357
13.1148 -23.0238 -23.0238 -21.5426
13.1171 -23.6098 -23.6098 -21.5496
13.1195 -24.2819 -24.2819 -21.5565
13.1218 -25.0346 -25.0346 -21.5635
13.1242 -25.8624 -25.8624 -21.5704
13.1265 -26.7587 -26.7587 -21.5773
13.1288 -27.7167 -27.7167 -21.5843
13.1312 -28.7291 -28.7291 -21.5912
13.1335 -29.7881 -29.7881 -21.5982
13.1359 -30.8856 -30.8856 -21.6051
13.1382 -32.0132 -32.0132 -21.6121
13.1405 -33.1624 -33.1624 -21.619
13.1429 -34.3243 -34.3243 -21.6259
13.1452 -35.4902 -35.4902 -21.6329
13.1475 -36.6511 -36.6511 -21.6398
13.1499 -37.7983 -37.7983 -21.6468
13.1522 -38.923 -38.923 -21.6537
13.1545 -40.0168 -40.0168 -21.6607
13.1568 -41.0712 -41.0712 -21.6676
13.1592 -42.0784 -42.0784 -21.6745
13.1615 -43.0309 -43.0309 -21.6815
13.1638 -43.9212 -43.9212 -21.6884
13.1661 -44.7429 -44.7429 -21.6954
13.1685 -45.4896 -45.4896 -21.7023
13.1708 -46.1559 -46.1559 -21.7093
13.1731 -46.7366 -46.7366 -21.7162
13.1754 -47.2276 -47.2276 -21.7231
13.1777 -47.6252 -47.6252 -21.7301
13.18 -47.9264 -47.9264 -21.737
13.1824 -48.129 -48.129 -21.744
13.1847 -48.2316 -48.2316 -21.7509
13.187 -48.2336 -48.2336 -21.7579
13.1893 -48.1351 -48.1351 -21.7648
13.1916 -47.9368 -47.9368 -21.7717
13.1939 -47.6403 -47.6403 -21.7787
13.1962 -47.2482 -47.2482 -21.7856
13.1985 -46.7634 -46.7634 -21.7926
13.2008 -46.1897 -46.1897 -21.7995
13.2031 -45.5315 -45.5315 -21.8064
13.2054 -44.7941 -44.7941 -21.8134
13.2077 -43.9829 -43.9829 -21.8203
13.21 -43.1044 -43.1044 -21.8273
13.2123 -42.1652 -42.1652 -21.8342
13.2146 -41.1725 -41.1725 -21.8412
13.2169 -40.134 -40.134 -21.8481
13.2192 -39.0575 -39.0575 -21.855
13.2215 -37.9514 -37.9514 -21.862
13.2238 -36.824 -36.824 -21.8689
13.2261 -35.6839 -35.6839 -21.8759
13.2284 -34.5399 -34.5399 -21.8828
13.2307 -33.4005 -33.4005 -21.8897
13.2329 -32.2745 -32.2745 -21.8967
13.2352 -31.1704 -31.1704 -21.9036
13.2375 -30.0966 -30.0966 -21.9106
13.2398 -29.0612 -29.0612 -21.9175
13.2421 -28.072 -28.072 -21.9245
13.2444 -27.1365 -27.1365 -21.9314
13.2466 -26.2617 -26.2617 -21.9384
13.2489 -25.4543 -25.4543 -21.9453
13.2512 -24.7203 -24.7203 -21.9522
13.2535 -24.0652 -24.0652 -21.9592
13.2558 -23.4939 -23.4939 -21.9661
13.258 -23.0106 -23.0106 -21.9731
13.2603 -22.619 -22.619 -21.98
13.2626 -22.3219 -22.3219 -21.987
13.2648 -22.1214 -22.1214 -21.9939
13.2671 -22.019 -22.019 -22.0008
13.2694 -22.0154 -22.0154 -22.0078
13.2716 -22.1105 -22.1105 -22.0147
13.2739 -22.3034 -22.3034 -22.0217
13.2762 -22.5926 -22.5926 -22.0286
13.2784 -22.9757 -22.9757 -22.0356
13.2807 -23.4499 -23.4499 -22.0425
13.283 -24.0113 -24.0113 -22.0494
13.2852 -24.6556 -24.6556 -22.0564
13.2875 -25.3778 -25.3778 -22.0633
13.2897 -26.1724 -26.1724 -22.0703
13.292 -27.0332 -27.0332 -22.0772
13.2942 -27.9536 -27.9536 -22.0841
13.2965 -28.9266 -28.9266 -22.0911
13.2987 -29.9447 -29.9447 -22.098
13.301 -31.0001 -31.0001 -22.105
13.3032 -32.0848 -32.0848 -22.1119
13.3055 -33.1904 -33.1904 -22.1189
13.3077 -34.3086 -34.3086 -22.1258
13.31 -35.4309 -35.4309 -22.1327
13.3122 -36.5487 -36.5487 -22.1397
13.3145 -37.6535 -37.6535 -22.1466
13.3167 -38.737 -38.737 -22.1536
13.3189 -39.7908 -39.7908 -22.1605
13.3212 -40.8072 -40.8072 -22.1674
13.3234 -41.7783 -41.7783 -22.1744
13.3257 -42.6968 -42.6968 -22.1813
13.3279 -43.5559 -43.5559 -22.1883
13.3301 -44.349 -44.349 -22.1952
13.3324 -45.0702 -45.0702 -22.2022
13.3346 -45.7141 -45.7141 -22.2091
13.3368 -46.2759 -46.2759 -22.216
13.3391 -46.7514 -46.7514 -22.223
13.3413 -47.137 -47.137 -22.2299
13.3435 -47.43 -47.43 -22.2369
13.3458 -47.6282 -47.6282 -22.2438
13.348 -47.7303 -47.7303 -22.2508
13.3502 -47.7355 -47.7355 -22.2577
13.3524 -47.6439 -47.6439 -22.2647
13.3546 -47.4563 -47.4563 -22.2716
13.3569 -47.1743 -47.1743 -22.2785
13.3591 -46.8 -46.8 -22.2855
13.3613 -46.3365 -46.3365 -22.2924
13.3635 -45.7874 -45.7874 -22.2994
13.3657 -45.1568 -45.1568 -22.3063
13.368 -44.4498 -44.4498 -22.3133
13.3702 -43.6718 -43.6718 -22.3202
13.3724 -42.8286 -42.8286 -22.3271
13.3746 -41.927 -41.927 -22.3341
13.3768 -40.9736 -40.9736 -22.341
13.379 -39.9759 -39.9759 -22.348
13.3812 -38.9415 -38.9415 -22.3549
13.3834 -37.8783 -37.8783 -22.3618
13.3856 -36.7944 -36.7944 -22.3688
13.3878 -35.698 -35.698 -22.3757
13.39 -34.5975 -34.5975 -22.3827
13.3922 -33.5014 -33.5014 -22.3896
13.3944 -32.4177 -32.4177 -22.3966
13.3966 -31.3549 -31.3549 -22.4035
13.3988 -30.321 -30.321 -22.4104
13.401 -29.3238 -29.3238 -22.4174
13.4032 -28.3708 -28.3708 -22.4243
13.4054 -27.4693 -27.4693 -22.4313
13.4076 -26.6259 -26.6259 -22.4382
13.4098 -25.8472 -25.8472 -22.4452
13.412 -25.1388 -25.1388 -22.4521
13.4142 -24.5062 -24.5062 -22.459
13.4164 -23.954 -23.954 -22.466
13.4185 -23.4864 -23.4864 -22.4729
13.4207 -23.1067 -23.1067 -22.4799
13.4229 -22.8179 -22.8179 -22.4868
13.4251 -22.622 -22.622 -22.4937
13.4273 -22.5204 -22.5204 -22.5007
13.4295 -22.5137 -22.5137 -22.5076
13.4316 -22.6019 -22.6019 -22.5146
13.4338 -22.7842 -22.7842 -22.5215
13.436 -23.0592 -23.0592 -22.5285
13.4382 -23.4246 -23.4246 -22.5354
13.4403 -23.8775 -23.8775 -22.5423
13.4425 -24.4145 -24.4145 -22.5493
13.4447 -25.0313 -25.0313 -22.5562
13.4469 -25.7231 -25.7231 -22.5632
13.449 -26.4847 -26.4847 -22.5701
13.4512 -27.3102 -27.3102 -22.5771
13.4534 -28.1932 -28.1932 -22.584
13.4555 -29.1269 -29.1269 -22.5909
13.4577 -30.1042 -30.1042 -22.5979
13.4599 -31.1176 -31.1176 -22.6048
13.462 -32.1594 -32.1594 -22.6118
13.4642 -33.2216 -33.2216 -22.6187
13.4663 -34.2961 -34.2961 -22.6257
13.4685 -35.3748 -35.3748 -22.6326
13.4707 -36.4494 -36.4494 -22.6395
13.4728 -37.5118 -37.5118 -22.6465
13.475 -38.5539 -38.5539 -22.6534
13.4771 -39.5678 -39.5678 -22.6604
13.4793 -40.5459 -40.5459 -22.6673
13.4814 -41.4807 -41.4807 -22.6743
13.4836 -42.3653 -42.3653 -22.6812
13.4857 -43.1928 -43.1928 -22.6881
13.4879 -43.9572 -43.9572 -22.6951
13.49 -44.6527 -44.6527 -22.702
13.4922 -45.274 -45.274 -22.709
13.4943 -45.8165 -45.8165 -22.7159
13.4964 -46.2762 -46.2762 -22.7229
13.4986 -46.6497 -46.6497 -22.7298
13.5007 -46.9343 -46.9343 -22.7367
13.5029 -47.1278 -47.1278 -22.7437
13.505 -47.229 -47.229 -22.7506
13.5071 -47.2371 -47.2371 -22.7576
13.5093 -47.1522 -47.1522 -22.7645
13.5114 -46.9751 -46.9751 -22.7715
13.5136 -46.7071 -46.7071 -22.7784
13.5157 -46.3505 -46.3505 -22.7853
13.5178 -45.9081 -45.9081 -22.7923
13.5199 -45.3833 -45.3833 -22.7992
13.5221 -44.7801 -44.7801 -22.8062
13.5242 -44.1033 -44.1033 -22.8131
13.5263 -43.3582 -43.3582 -22.82
13.5284 -42.5503 -42.5503 -22.827
13.5306 -41.686 -41.686 -22.8339
13.5327 -40.7719 -40.7719 -22.8409
13.5348 -39.8149 -39.8149 -22.8478
13.5369 -38.8225 -38.8225 -22.8548
13.5391 -37.8021 -37.8021 -22.8617
13.5412 -36.7616 -36.7616 -22.8686
13.5433 -35.7089 -35.7089 -22.8756
13.5454 -34.6521 -34.6521 -22.8825
13.5475 -33.5991 -33.5991 -22.8895
13.5496 -32.5579 -32.5579 -22.8964
13.5517 -31.5365 -31.5365 -22.9034
13.5539 -30.5426 -30.5426 -22.9103
13.556 -29.5837 -29.5837 -22.9172
13.5581 -28.667 -28.667 -22.9242
13.5602 -27.7996 -27.7996 -22.9311
13.5623 -26.9878 -26.9878 -22.9381
13.5644 -26.2379 -26.2379 -22.945
13.5665 -25.5554 -25.5554 -22.952
13.5686 -24.9455 -24.9455 -22.9589
13.5707 -24.4127 -24.4127 -22.9658
13.5728 -23.9609 -23.9609 -22.9728
13.5749 -23.5936 -23.5936 -22.9797
13.577 -23.3134 -23.3134 -22.9867
13.5791 -23.1223 -23.1223 -22.9936
13.5812 -23.0217 -23.0217 -23.0006
13.5833 -23.0122 -23.0122 -23.0075
13.5854 -23.0938 -23.0938 -23.0144
13.5875 -23.2658 -23.2658 -23.0214
13.5895 -23.5268 -23.5268 -23.0283
13.5916 -23.8747 -23.8747 -23.0353
13.5937 -24.3067 -24.3067 -23.0422
13.5958 -24.8195 -24.8195 -23.0492
13.5979 -25.409 -25.409 -23.0561
13.6 -26.0707 -26.0707 -23.063
13.6021 -26.7995 -26.7995 -23.07
13.6041 -27.5898 -27.5898 -23.0769
13.6062 -28.4355 -28.4355 -23.0839
13.6083 -29.3301 -29.3301 -23.0908
13.6104 -30.2667 -30.2667 -23.0978
13.6125 -31.2382 -31.2382 -23.1047
13.6145 -32.2372 -32.2372 -23.1116
13.6166 -33.2559 -33.2559 -23.1186
13.6187 -34.2868 -34.2868 -23.1255
13.6207 -35.3219 -35.3219 -23.1325
13.6228 -36.3533 -36.3533 -23.1394
13.6249 -37.3732 -37.3732 -23.1464
13.627 -38.3739 -38.3739 -23.1533
13.629 -39.3477 -39.3477 -23.1602
13.6311 -40.2874 -40.2874 -23.1672
13.6331 -41.1859 -41.1859 -23.1741
13.6352 -42.0362 -42.0362 -23.1811
13.6373 -42.8321 -42.8321 -23.188
13.6393 -43.5675 -43.5675 -23.1949
13.6414 -44.237 -44.237 -23.2019
13.6435 -44.8355 -44.8355 -23.2088
13.6455 -45.3585 -45.3585 -23.2158
13.6476 -45.8022 -45.8022 -23.2227
13.6496 -46.1633 -46.1633 -23.2297
13.6517 -46.4391 -46.4391 -23.2366
13.6537 -46.6277 -46.6277 -23.2435
13.6558 -46.7277 -46.7277 -23.2505
13.6578 -46.7385 -46.7385 -23.2574
13.6599 -46.66 -46.66 -23.2644
13.6619 -46.4931 -46.4931 -23.2713
13.664 -46.239 -46.239 -23.2783
13.666 -45.8998 -45.8998 -23.2852
13.668 -45.4781 -45.4781 -23.2921
13.6701 -44.9774 -44.9774 -23.2991
13.6721 -44.4014 -44.4014 -23.306
13.6742 -43.7547 -43.7547 -23.313
13.6762 -43.0422 -43.0422 -23.3199
13.6783 -42.2694 -42.2694 -23.3269
13.6803 -41.4423 -41.4423 -23.3338
13.6823 -40.5672 -40.5672 -23.3407
13.6844 -39.6509 -39.6509 -23.3477
13.6864 -38.7003 -38.7003 -23.3546
13.6884 -37.7228 -37.7228 -23.3616
13.6905 -36.7257 -36.7257 -23.3685
13.6925 -35.7167 -35.7167 -23.3755
13.6945 -34.7034 -34.7034 -23.3824
13.6965 -33.6936 -33.6936 -23.3893
13.6986 -32.695 -32.695 -23.3963
13.7006 -31.715 -31.715 -23.4032
13.7026 -30.7612 -30.7612 -23.4102
13.7046 -29.8408 -29.8408 -23.4171
13.7067 -28.9606 -28.9606 -23.4241
13.7087 -28.1274 -28.1274 -23.431
13.7107 -27.3474 -27.3474 -23.4379
13.7127 -26.6265 -26.6265 -23.4449
13.7147 -25.9702 -25.9702 -23.4518
13.7167 -25.3832 -25.3832 -23.4588
13.7188 -24.87 -24.87 -23.4657
13.7208 -24.4344 -24.4344 -23.4727
13.7228 -24.0796 -24.0796 -23.4796
13.7248 -23.8082 -23.8082 -23.4865
13.7268 -23.6222 -23.6222 -23.4935
13.7288 -23.5229 -23.5229 -23.5004
13.7308 -23.5109 -23.5109 -23.5074
13.7328 -23.5862 -23.5862 -23.5143
13.7348 -23.7482 -23.7482 -23.5212
13.7368 -23.9955 -23.9955 -23.5282
13.7388 -24.3261 -24.3261 -23.5351
13.7408 -24.7374 -24.7374 -23.5421
13.7428 -25.2262 -25.2262 -23.549
13.7448 -25.7887 -25.7887 -23.556
13.7468 -26.4205 -26.4205 -23.5629
13.7488 -27.1167 -27.1167 -23.5698
13.7508 -27.872 -27.872 -23.5768
13.7528 -28.6806 -28.6806 -23.5837
13.7548 -29.5361 -29.5361 -23.5907
13.7568 -30.4322 -30.4322 -23.5976
13.7588 -31.3619 -31.3619 -23.6046
13.7608 -32.3181 -32.3181 -23.6115
13.7627 -33.2935 -33.2935 -23.6184
13.7647 -34.2807 -34.2807 -23.6254
13.7667 -35.2721 -35.2721 -23.6323
13.7687 -36.2603 -36.2603 -23.6393
13.7707 -37.2377 -37.2377 -23.6462
13.7727 -38.1968 -38.1968 -23.6532
13.7746 -39.1306 -39.1306 -23.6601
13.7766 -40.0318 -40.0318 -23.667
13.7786 -40.8936 -40.8936 -23.674
13.7806 -41.7096 -41.7096 -23.6809
13.7825 -42.4736 -42.4736 -23.6879
13.7845 -43.1799 -43.1799 -23.6948
13.7865 -43.8232 -43.8232 -23.7018
13.7884 -44.3986 -44.3986 -23.7087
13.7904 -44.9019 -44.9019 -23.7156
13.7924 -45.3294 -45.3294 -23.7226
13.7944 -45.6778 -45.6778 -23.7295
13.7963 -45.9446 -45.9446 -23.7365
13.7983 -46.128 -46.128 -23.7434
13.8003 -46.2266 -46.2266 -23.7504
13.8022 -46.2397 -46.2397 -23.7573
13.8042 -46.1674 -46.1674 -23.7642
13.8061 -46.0104 -46.0104 -23.7712
13.8081 -45.7698 -45.7698 -23.7781
13.8101 -45.4477 -45.4477 -23.7851
13.812 -45.0467 -45.0467 -23.792
13.814 -44.5697 -44.5697 -23.7989
13.8159 -44.0207 -44.0207 -23.8059
13.8179 -43.4038 -43.4038 -23.8128
13.8198 -42.7238 -42.7238 -23.8198
13.8218 -41.9859 -41.9859 -23.8267
13.8237 -41.1959 -41.1959 -23.8337
13.8257 -40.3598 -40.3598 -23.8406
13.8276 -39.484 -39.484 -23.8475
13.8296 -38.5752 -38.5752 -23.8545
13.8315 -37.6403 -37.6403 -23.8614
13.8334 -36.6866 -36.6866 -23.8684
13.8354 -35.7212 -35.7212 -23.8753
13.8373 -34.7516 -34.7516 -23.8822
13.8393 -33.785 -33.785 -23.8892
13.8412 -32.8289 -32.8289 -23.8961
13.8432 -31.8905 -31.8905 -23.9031
13.8451 -30.9769 -30.9769 -23.91
13.847 -30.095 -30.095 -23.917
13.849 -29.2515 -29.2515 -23.9239
13.8509 -28.4528 -28.4528 -23.9309
13.8528 -27.7047 -27.7047 -23.9378
13.8547 -27.0131 -27.0131 -23.9447
13.8567 -26.383 -26.383 -23.9517
13.8586 -25.8192 -25.8192 -23.9586
13.8605 -25.3258 -25.3258 -23.9656
13.8625 -24.9066 -24.9066 -23.9725
13.8644 -24.5646 -24.5646 -23.9795
13.8663 -24.3024 -24.3024 -23.9864
13.8682 -24.1217 -24.1217 -23.9933
13.8701 -24.024 -24.024 -24.0003
13.8721 -24.0098 -24.0098 -24.0072
13.874 -24.0791 -24.0791 -24.0142
13.8759 -24.2313 -24.2313 -24.0211
13.8778 -24.4652 -24.4652 -24.0281
13.8797 -24.7788 -24.7788 -24.035
13.8816 -25.1696 -25.1696 -24.0419
13.8836 -25.6347 -25.6347 -24.0489
13.8855 -26.1704 -26.1704 -24.0558
13.8874 -26.7725 -26.7725 -24.0628
13.8893 -27.4363 -27.4363 -24.0697
13.8912 -28.1568 -28.1568 -24.0767
13.8931 -28.9283 -28.9283 -24.0836
13.895 -29.745 -29.745 -24.0905
13.8969 -30.6006 -30.6006 -24.0975
13.8988 -31.4886 -31.4886 -24.1044
13.9007 -32.4021 -32.4021 -24.1114
13.9026 -33.3342 -33.3342 -24.1183
13.9045 -34.2777 -34.2777 -24.1252
13.9064 -35.2255 -35.2255 -24.1322
13.9083 -36.1704 -36.1704 -24.1391
13.9102 -37.1052 -37.1052 -24.1461
13.9121 -38.0228 -38.0228 -24.153
13.914 -38.9163 -38.9163 -24.16
13.9159 -39.7789 -39.7789 -24.1669
13.9178 -40.604 -40.604 -24.1738
13.9196 -41.3855 -41.3855 -24.1808
13.9215 -42.1175 -42.1175 -24.1877
13.9234 -42.7944 -42.7944 -24.1947
13.9253 -43.4113 -43.4113 -24.2016
13.9272 -43.9635 -43.9635 -24.2085
13.9291 -44.4468 -44.4468 -24.2155
13.9309 -44.8577 -44.8577 -24.2224
13.9328 -45.1932 -45.1932 -24.2294
13.9347 -45.4508 -45.4508 -24.2363
13.9366 -45.6286 -45.6286 -24.2433
13.9385 -45.7255 -45.7255 -24.2502
13.9403 -45.7407 -45.7407 -24.2571
13.9422 -45.6743 -45.6743 -24.2641
13.9441 -45.5269 -45.5269 -24.271
13.946 -45.2996 -45.2996 -24.278
13.9478 -44.9944 -44.9944 -24.2849
13.9497 -44.6137 -44.6137 -24.2919
13.9516 -44.1604 -44.1604 -24.2988
13.9534 -43.638 -43.638 -24.3058
13.9553 -43.0507 -43.0507 -24.3127
13.9572 -42.403 -42.403 -24.3196
13.959 -41.6999 -41.6999 -24.3266
13.9609 -40.9468 -40.9468 -24.3335
13.9627 -40.1494 -40.1494 -24.3405
13.9646 -39.314 -39.314 -24.3474
13.9665 -38.4469 -38.4469 -24.3544
13.9683 -37.5547 -37.5547 -24.3613
13.9702 -36.6443 -36.6443 -24.3682
13.972 -35.7226 -35.7226 -24.3752
13.9739 -34.7966 -34.7966 -24.3821
13.9757 -33.8733 -33.8733 -24.3891
13.9776 -32.9598 -32.9598 -24.396
13.9794 -32.063 -32.063 -24.4029
13.9813 -31.1897 -31.1897 -24.4099
13.9831 -30.3465 -30.3465 -24.4168
13.985 -29.5398 -29.5398 -24.4238
13.9868 -28.7756 -28.7756 -24.4307
13.9887 -28.0597 -28.0597 -24.4377
13.9905 -27.3975 -27.3975 -24.4446
13.9924 -26.7939 -26.7939 -24.4515
13.9942 -26.2535 -26.2535 -24.4585
13.996 -25.7802 -25.7802 -24.4654
13.9979 -25.3777 -25.3777 -24.4724
13.9997 -25.0488 -25.0488 -24.4793
14.0015 -24.7959 -24.7959 -24.4862
14.0034 -24.6209 -24.6209 -24.4932
14.0052 -24.525 -24.525 -24.5001
14.007 -24.5088 -24.5088 -24.5071
14.0089 -24.5724 -24.5724 -24.514
14.0107 -24.7151 -24.7151 -24.521
14.0125 -24.9358 -24.9358 -24.5279
14.0144 -25.2327 -25.2327 -24.5348
14.0162 -25.6034 -25.6034 -24.5418
14.018 -26.045 -26.045 -24.5487
14.0198 -26.5541 -26.5541 -24.5557
14.0216 -27.1266 -27.1266 -24.5626
14.0235 -27.7583 -27.7583 -24.5696
14.0253 -28.4441 -28.4441 -24.5765
14.0271 -29.1788 -29.1788 -24.5834
14.0289 -29.9568 -29.9568 -24.5904
14.0307 -30.7721 -30.7721 -24.5973
14.0326 -31.6184 -31.6184 -24.6043
14.0344 -32.4892 -32.4892 -24.6112
14.0362 -33.378 -33.378 -24.6182
14.038 -34.2779 -34.2779 -24.6251
14.0398 -35.1821 -35.1821 -24.6321
14.0416 -36.0838 -36.0838 -24.639
14.0434 -36.9759 -36.9759 -24.6459
14.0452 -37.8519 -37.8519 -24.6529
14.047 -38.705 -38.705 -24.6598
14.0488 -39.5288 -39.5288 -24.6668
14.0506 -40.3171 -40.3171 -24.6737
14.0524 -41.0639 -41.0639 -24.6806
14.0542 -41.7637 -41.7637 -24.6876
14.056 -42.4111 -42.4111 -24.6945
14.0578 -43.0013 -43.0013 -24.7015
14.0596 -43.53 -43.53 -24.7084
14.0614 -43.9931 -43.9931 -24.7154
14.0632 -44.3872 -44.3872 -24.7223
14.065 -44.7095 -44.7095 -24.7292
14.0668 -44.9576 -44.9576 -24.7362
14.0686 -45.1296 -45.1296 -24.7431
14.0704 -45.2245 -45.2245 -24.7501
14.0722 -45.2415 -45.2415 -24.757
14.074 -45.1808 -45.1808 -24.764
14.0757 -45.0427 -45.0427 -24.7709
14.0775 -44.8285 -44.8285 -24.7778
14.0793 -44.5399 -44.5399 -24.7848
14.0811 -44.1792 -44.1792 -24.7917
14.0829 -43.7492 -43.7492 -24.7987
14.0847 -43.2534 -43.2534 -24.8056
14.0864 -42.6955 -42.6955 -24.8126
14.0882 -42.0799 -42.0799 -24.8195
14.09 -41.4113 -41.4113 -24.8264
14.0918 -40.6949 -40.6949 -24.8334
14.0935 -39.9363 -39.9363 -24.8403
14.0953 -39.1411 -39.1411 -24.8473
14.0971 -38.3156 -38.3156 -24.8542
14.0989 -37.466 -37.466 -24.8611
14.1006 -36.5989 -36.5989 -24.8681
14.1024 -35.7208 -35.7208 -24.875
14.1042 -34.8384 -34.8384 -24.882
14.1059 -33.9584 -33.9584 -24.8889
14.1077 -33.0876 -33.0876 -24.8959
14.1095 -32.2325 -32.2325 -24.9028
14.1112 -31.3996 -31.3996 -24.9097
14.113 -30.5952 -30.5952 -24.9167
14.1147 -29.8254 -29.8254 -24.9236
14.1165 -29.0959 -29.0959 -24.9306
14.1183 -28.4123 -28.4123 -24.9375
14.12 -27.7798 -27.7798 -24.9445
14.1218 -27.2029 -27.2029 -24.9514
14.1235 -26.6861 -26.6861 -24.9583
14.1253 -26.2332 -26.2332 -24.9653
14.127 -25.8476 -25.8476 -24.9722
14.1288 -25.532 -25.532 -24.9792
14.1305 -25.2888 -25.2888 -24.9861
14.1323 -25.1266 -25.1266 -25
and this my amplitude
*Amplitude, name=x, time=TOTAL TIME, definition=SMOOTH STEP
0., 0., 0.0061, -0.13997, 0.01221, -0.54487, 0.01831, -1.21151
0.02441, -2.13474, 0.03051, -3.30742, 0.03661, -4.72055, 0.0427, -6.36328
0.0488, -8.22304, 0.05489, -10.2856, 0.06099, -12.5352, 0.06708, -14.9547
0.07317, -17.5256, 0.07926, -20.2283, 0.08535, -23.0422, 0.09144, -25.9459
0.09752, -28.9173, 0.10361, -31.9337, 0.10969, -34.9722, 0.11577, -38.0098
0.12185, -41.0232, 0.12793, -43.9896, 0.13401, -46.8866, 0.14009, -49.692
0.14617, -52.3847, 0.15224, -54.9441, 0.15832, -57.3508, 0.16439, -59.5868
0.17046, -61.6349, 0.17653, -63.4798, 0.1826, -65.1074, 0.18867, -66.5055
0.19473, -67.6636, 0.2008, -68.5729, 0.20686, -69.2267, 0.21293, -69.62
0.21899, -69.75, 0.22505, -69.6158, 0.23111, -69.2186, 0.23717, -68.5613
0.24322, -67.6492, 0.24928, -66.4894, 0.25534, -65.0906, 0.26139, -63.4636
0.26744, -61.6209, 0.27349, -59.5766, 0.27954, -57.3463, 0.28559, -54.947
0.29164, -52.3971, 0.29768, -49.7159, 0.30373, -46.924, 0.30977, -44.0425
0.31581, -41.0935, 0.32186, -38.0993, 0.3279, -35.0827, 0.33394, -32.0667
0.33997, -29.0743, 0.34601, -26.1281, 0.35204, -23.2505, 0.35808, -20.4633
0.36411, -17.7878, 0.37014, -15.2442, 0.37617, -12.8518, 0.3822, -10.6288
0.38823, -8.59181, 0.39426, -6.75643, 0.40028, -5.13649, 0.40631, -3.74419
0.41233, -2.59005, 0.41835, -1.68274, 0.42437, -1.02904, 0.43039, -0.63384
0.43641, -0.50004, 0.44243, -0.62853, 0.44844, -1.01825, 0.45446, -1.66612
0.46047, -2.56711, 0.46648, -3.71428, 0.4725, -5.0988, 0.4785, -6.71006
0.48451, -8.53571, 0.49052, -10.5618, 0.49653, -12.7728, 0.50253, -15.1519
0.50854, -17.6809, 0.51454, -20.3406, 0.52054, -23.1106, 0.52654, -25.9699
0.53254, -28.8966, 0.53854, -31.8686, 0.54453, -34.8631, 0.55053, -37.8575
0.55652, -40.829, 0.56252, -43.755, 0.56851, -46.6132, 0.5745, -49.382
0.58049, -52.0403, 0.58647, -54.5681, 0.59246, -56.946, 0.59845, -59.1562
0.60443, -61.1819, 0.61041, -63.0078, 0.6164, -64.62, 0.62238, -66.0063
0.62836, -67.1565, 0.63434, -68.0617, 0.64031, -68.7153, 0.64629, -69.1123
0.65226, -69.2498, 0.65824, -69.1269, 0.66421, -68.7447, 0.67018, -68.1062
0.67615, -67.2162, 0.68212, -66.0817, 0.68809, -64.7114, 0.69405, -63.1158
0.70002, -61.3071, 0.70598, -59.2992, 0.71194, -57.1074, 0.71791, -54.7484
0.72387, -52.2403, 0.72982, -49.6021, 0.73578, -46.8541, 0.74174, -44.017
0.74769, -41.1125, 0.75365, -38.1628, 0.7596, -35.1902, 0.76555, -32.2174
0.7715, -29.267, 0.77745, -26.3613, 0.7834, -23.5224, 0.78935, -20.772
0.79529, -18.1309, 0.80124, -15.619, 0.80718, -13.2555, 0.81312, -11.0583
0.81906, -9.04391, 0.825, -7.22767, 0.83094, -5.62329, 0.83688, -4.24286
0.84281, -3.09679, 0.84875, -2.1937, 0.85468, -1.54035, 0.86062, -1.14162
0.86655, -1.00041, 0.87248, -1.11771, 0.87841, -1.49252, 0.88433, -2.12187
0.89026, -3.00089, 0.89618, -4.12279, 0.90211, -5.47894, 0.90803, -7.05894
0.91395, -8.85069, 0.91987, -10.8405, 0.92579, -13.0131, 0.93171, -15.352
0.93763, -17.8392, 0.94354, -20.4559, 0.94946, -23.1821, 0.95537, -25.9969
0.96128, -28.8791, 0.96719, -31.8066, 0.9731, -34.7572, 0.97901, -37.7084
0.98491, -40.6379, 0.99082, -43.5232, 0.99673, -46.3426, 1.00263, -49.0747
1.00853, -51.6986, 1.01443, -54.1945, 1.02033, -56.5435, 1.02623, -58.7277
1.03213, -60.7307, 1.03802, -62.5373, 1.04392, -64.1338, 1.04981, -65.5082
1.0557, -66.6501, 1.06159, -67.551, 1.06748, -68.2041, 1.07337, -68.6045
1.07926, -68.7493, 1.08515, -68.6375, 1.09103, -68.27, 1.09692, -67.6498
1.1028, -66.7817, 1.10868, -65.6723, 1.11456, -64.3303, 1.12044, -62.7658
1.12632, -60.991, 1.13219, -59.0193, 1.13807, -56.8658, 1.14394, -54.547
1.14982, -52.0806, 1.15569, -49.4853, 1.16156, -46.781, 1.16743, -43.9883
1.1733, -41.1284, 1.17916, -38.2231, 1.18503, -35.2945, 1.19089, -32.3649
1.19676, -29.4565, 1.20262, -26.5915, 1.20848, -23.7915, 1.21434, -21.078
1.2202, -18.4713, 1.22606, -15.9914, 1.23191, -13.657, 1.23777, -11.4858
1.24362, -9.49421, 1.24947, -7.69735, 1.25532, -6.10878, 1.26117, -4.74047
1.26702, -3.60275, 1.27287, -2.70416, 1.27872, -2.05143, 1.28456, -1.64943
1.29041, -1.50111, 1.29625, -1.60749, 1.30209, -1.96766, 1.30793, -2.57877
1.31377, -3.43607, 1.31961, -4.53294, 1.32544, -5.86096, 1.33128, -7.40992
1.33711, -9.16796, 1.34295, -11.1216, 1.34878, -13.256, 1.35461, -15.5548
1.36044, -18.0004, 1.36627, -20.5742, 1.37209, -23.2566, 1.37792, -26.0272
1.38374, -28.8648, 1.38957, -31.7479, 1.39539, -34.6545, 1.40121, -37.5625
1.40703, -40.4498, 1.41285, -43.2945, 1.41867, -46.075, 1.42448, -48.7701
1.4303, -51.3595, 1.43611, -53.8233, 1.44192, -56.1431, 1.44774, -58.3012
1.45355, -60.2813, 1.45935, -62.0684, 1.46516, -63.649, 1.47097, -65.0111
1.47677, -66.1446, 1.48258, -67.0408, 1.48838, -67.6931, 1.49418, -68.0966
1.49998, -68.2484, 1.50578, -68.1474, 1.51158, -67.7944, 1.51738, -67.1924
1.52317, -66.3458, 1.52897, -65.2614, 1.53476, -63.9473, 1.54055, -62.4138
1.54634, -60.6726, 1.55213, -58.7369, 1.55792, -56.6216, 1.56371, -54.3428
1.56949, -51.9179, 1.57528, -49.3655, 1.58106, -46.7049, 1.58684, -43.9565
1.59262, -41.1411, 1.5984, -38.2803, 1.60418, -35.3957, 1.60996, -32.5093
1.61574, -29.643, 1.62151, -26.8187, 1.62728, -24.0577, 1.63306, -21.3811
1.63883, -18.8091, 1.6446, -16.3613, 1.65037, -14.0562, 1.65613, -11.9112
1.6619, -9.9427, 1.66767, -8.16546, 1.67343, -6.59294, 1.67919, -5.23702
1.68495, -4.1079, 1.69072, -3.21409, 1.69647, -2.56226, 1.70223, -2.15728
1.70799, -2.00212, 1.71374, -2.09786, 1.7195, -2.44366, 1.72525, -3.03678
1.731, -3.87262, 1.73676, -4.94472, 1.7425, -6.24483, 1.74825, -7.76297
1.754, -9.48751, 1.75975, -11.4053, 1.76549, -13.5016, 1.77123, -15.7604
1.77698, -18.1645, 1.78272, -20.6956, 1.78846, -23.3343, 1.7942, -26.0606
1.79993, -28.8537, 1.80567, -31.6924, 1.8114, -34.555, 1.81714, -37.4197
1.82287, -40.2649, 1.8286, -43.0688, 1.83433, -45.8103, 1.84006, -48.4683
1.84579, -51.0229, 1.85152, -53.4546, 1.85724, -55.745, 1.86296, -57.8768
1.86869, -59.8337, 1.87441, -61.6011, 1.88013, -63.1655, 1.88585, -64.5151
1.89157, -65.6398, 1.89728, -66.5311, 1.903, -67.1824, 1.90871, -67.5888
1.91443, -67.7473, 1.92014, -67.6567, 1.92585, -67.318, 1.93156, -66.7338
1.93727, -65.9086, 1.94298, -64.8488, 1.94868, -63.5625, 1.95439, -62.0597
1.96009, -60.3518, 1.96579, -58.452, 1.97149, -56.3747, 1.97719, -54.1358
1.98289, -51.7524, 1.98859, -49.2426, 1.99429, -46.6257, 1.99998, -43.9215
2.00567, -41.1506, 2.01137, -38.3342, 2.01706, -35.4936, 2.02275, -32.6505
2.02844, -29.8264, 2.03413, -27.0429, 2.03981, -24.321, 2.0455, -21.6815
2.05118, -19.1443, 2.05686, -16.7288, 2.06255, -14.4532, 2.06823, -12.3347
2.07391, -10.3894, 2.07958, -8.63198, 2.08526, -7.07577, 2.09094, -5.73248
2.09661, -4.61225, 2.10228, -3.72347, 2.10796, -3.07283, 2.11363, -2.66515
2.1193, -2.50343, 2.12496, -2.5888, 2.13063, -2.9205, 2.1363, -3.49591
2.14196, -4.31055, 2.14763, -5.35812, 2.15329, -6.63056, 2.15895, -8.1181
2.16461, -9.80934, 2.17027, -11.6914, 2.17593, -13.7497, 2.18158, -15.9688
2.18724, -18.3315, 2.19289, -20.8199, 2.19854, -23.4151, 2.2042, -26.0972
2.20985, -28.8458, 2.21549, -31.64, 2.22114, -34.4586, 2.22679, -37.2801
2.23243, -40.083, 2.23808, -42.8461, 2.24372, -45.5484, 2.24936, -48.1693
2.255, -50.689, 2.26064, -53.0884, 2.26628, -55.3492, 2.27192, -57.4544
2.27755, -59.388, 2.28319, -61.1354, 2.28882, -62.6833, 2.29445, -64.0202
2.30008, -65.1359, 2.30571, -66.022, 2.31134, -66.672, 2.31697, -67.0809
2.3226, -67.2458, 2.32822, -67.1655, 2.33384, -66.8408, 2.33947, -66.2741
2.34509, -65.47, 2.35071, -64.4346, 2.35633, -63.1759, 2.36194, -61.7036
2.36756, -60.0289, 2.37318, -58.1647, 2.37879, -56.1252, 2.3844, -53.926
2.39001, -51.5839, 2.39562, -49.1168, 2.40123, -46.5434, 2.40684, -43.8834
2.41245, -41.157, 2.41805, -38.3849, 2.42366, -35.5884, 2.42926, -32.7886
2.43486, -30.0068, 2.44046, -27.2641, 2.44606, -24.5815, 2.45166, -21.9792
2.45726, -19.4769, 2.46285, -17.0938, 2.46845, -14.8479, 2.47404, -12.756
2.47963, -10.8342, 2.48522, -9.0969, 2.49081, -7.55724, 2.4964, -6.22686
2.50199, -5.11576, 2.50758, -4.23231, 2.51316, -3.58311, 2.51874, -3.17301
2.52433, -3.00501, 2.52991, -3.08029, 2.53549, -3.39817, 2.54107, -3.95613
2.54664, -4.74982, 2.55222, -5.77311, 2.5578, -7.01811, 2.56337, -8.47528
2.56894, -10.1334, 2.57451, -11.9799, 2.58009, -14.0005, 2.58565, -16.1799
2.59122, -18.5014, 2.59679, -20.9473, 2.60235, -23.4989, 2.60792, -26.1369
2.61348, -28.8411, 2.61904, -31.5909, 2.6246, -34.3655, 2.63016, -37.1436
2.63572, -39.9043, 2.64128, -42.6264, 2.64683, -45.2894, 2.65239, -47.8731
2.65794, -50.3577, 2.66349, -52.7246, 2.66905, -54.9556, 2.6746, -57.0341
2.68014, -58.9441, 2.68569, -60.6712, 2.69124, -62.2025, 2.69678, -63.5264
2.70233, -64.6328, 2.70787, -65.5135, 2.71341, -66.1619, 2.71895, -66.5731
2.72449, -66.7441, 2.73003, -66.6738, 2.73556, -66.3627, 2.7411, -65.8134
2.74663, -65.03, 2.75217, -64.0188, 2.7577, -62.7874, 2.76323, -61.3454
2.76876, -59.7037, 2.77428, -57.8749, 2.77981, -55.8731, 2.78534, -53.7135
2.79086, -51.4126, 2.79638, -48.9879, 2.80191, -46.458, 2.80743, -43.8421
2.81295, -41.1601, 2.81846, -38.4325, 2.82398, -35.6799, 2.8295, -32.9235
2.83501, -30.184, 2.84053, -27.4823, 2.84604, -24.839, 2.85155, -22.274
2.85706, -19.8069, 2.86257, -17.4564, 2.86807, -15.2403, 2.87358, -13.1753
2.87909, -11.2772, 2.88459, -9.56021, 2.89009, -8.03735, 2.89559, -6.72012
2.90109, -5.61843, 2.90659, -4.74057, 2.91209, -4.0931, 2.91759, -3.68086
2.92308, -3.50686, 2.92858, -3.57233, 2.93407, -3.87665, 2.93956, -4.41743
2.94505, -5.19043, 2.95054, -6.18969, 2.95603, -7.4075, 2.96151, -8.83451
2.967, -10.4598, 2.97248, -12.2709, 2.97797, -14.2539, 2.98345, -16.3938
2.98893, -18.6742, 2.99441, -21.0777, 2.99989, -23.5859, 3.00537, -26.1798
3.01084, -28.8395, 3.01632, -31.545, 3.02179, -34.2755, 3.02726, -37.0103
3.03273, -39.7286, 3.0382, -42.4098, 3.04367, -45.0334, 3.04914, -47.5796
3.05461, -50.0291, 3.06007, -52.3632, 3.06553, -54.5644, 3.071, -56.6158
3.07646, -58.502, 3.08192, -60.2088, 3.08738, -61.7231, 3.09283, -63.0337
3.09829, -64.1305, 3.10375, -65.0055, 3.1092, -65.652, 3.11465, -66.0652
3.12011, -66.2421, 3.12556, -66.1815, 3.13101, -65.8838, 3.13645, -65.3515
3.1419, -64.5888, 3.14735, -63.6014, 3.15279, -62.3971, 3.15823, -60.9851
3.16368, -59.3762, 3.16912, -57.5827, 3.17456, -55.6184, 3.17999, -53.4982
3.18543, -51.2383, 3.19087, -48.856, 3.1963, -46.3695, 3.20174, -43.7976
3.20717, -41.16, 3.2126, -38.4768, 3.21803, -35.7683, 3.22346, -33.0552
3.22889, -30.3581, 3.23431, -27.6975, 3.23974, -25.0935, 3.24516, -22.5661
3.25058, -20.1343, 3.256, -17.8165, 3.26142, -15.6304, 3.26684, -13.5926
3.27226, -11.7183, 3.27768, -10.0219, 3.28309, -8.51608, 3.28851, -7.21226
3.29392, -6.12025, 3.29933, -5.24825, 3.30474, -4.60279, 3.31015, -4.18868
3.31556, -4.00895, 3.32097, -4.06488, 3.32637, -4.35594, 3.33178, -4.87979
3.33718, -5.63237, 3.34258, -6.60784, 3.34798, -7.79869, 3.35338, -9.19577
3.35878, -10.7884, 3.36418, -12.5643, 3.36957, -14.51, 3.37497, -16.6105
3.38036, -18.8499, 3.38576, -21.211, 3.39115, -23.6759, 3.39654, -26.2258
3.40193, -28.8412, 3.40731, -31.5023, 3.4127, -34.1887, 3.41808, -36.8801
3.42347, -39.556, 3.42885, -42.1961, 3.43423, -44.7803, 3.43961, -47.2889
3.44499, -49.7031, 3.45037, -52.0044, 3.45575, -54.1754, 3.46112, -56.1996
3.4665, -58.0618, 3.47187, -59.7479, 3.47724, -61.2451, 3.48261, -62.5421
3.48798, -63.6292, 3.49335, -64.4981, 3.49872, -65.1425, 3.50408, -65.5574
3.50945, -65.7399, 3.51481, -65.6886, 3.52017, -65.4041, 3.52553, -64.8886
3.53089, -64.1462, 3.53625, -63.1825, 3.54161, -62.005, 3.54696, -60.6229
3.55232, -59.0465, 3.55767, -57.2881, 3.56302, -55.3611, 3.56838, -53.2801
3.57373, -51.0612, 3.57907, -48.7212, 3.58442, -46.2779, 3.58977, -43.75
3.59511, -41.1568, 3.60046, -38.5179, 3.6058, -35.8535, 3.61114, -33.1838
3.61648, -30.5291, 3.62182, -27.9096, 3.62716, -25.3452, 3.6325, -22.8554
3.63783, -20.4589, 3.64317, -18.1741, 3.6485, -16.0183, 3.65383, -14.0077
3.65916, -12.1576, 3.66449, -10.4819, 3.66982, -8.99342, 3.67515, -7.70327
3.68047, -6.6212, 3.6858, -5.75533, 3.69112, -5.11215, 3.69644, -4.69645
3.70176, -4.51128, 3.70708, -4.55795, 3.7124, -4.836, 3.71772, -5.34321
3.72303, -6.07561, 3.72835, -7.02755, 3.73366, -8.19167, 3.73898, -9.55904
3.74429, -11.1192, 3.7496, -12.8601, 3.75491, -14.7686, 3.76021, -16.8299
3.76552, -19.0284, 3.77082, -21.3474, 3.77613, -23.769, 3.78143, -26.275
3.78673, -28.846, 3.79203, -31.4627, 3.79733, -34.1051, 3.80263, -36.7531
3.80793, -39.3866, 3.81322, -41.9854, 3.81852, -44.5301, 3.82381, -47.0011
3.8291, -49.3797, 3.83439, -51.648, 3.83968, -53.7886, 3.84497, -55.7855
3.85026, -57.6235, 3.85554, -59.2887, 3.86083, -60.7684, 3.86611, -62.0517
3.87139, -63.1287, 3.87667, -63.9914, 3.88195, -64.6333, 3.88723, -65.0497
3.89251, -65.2375, 3.89779, -65.1953, 3.90306, -64.9237, 3.90833, -64.4247
3.91361, -63.7023, 3.91888, -62.762, 3.92415, -61.6112, 3.92942, -60.2586
3.93469, -58.7146, 3.93995, -56.9911, 3.94522, -55.1012, 3.95048, -53.0593
3.95574, -50.8812, 3.96101, -48.5833, 3.96627, -46.1833, 3.97152, -43.6993
3.97678, -41.1504, 3.98204, -38.5558, 3.9873, -35.9355, 3.99255, -33.3092
3.9978, -30.697, 4.00305, -28.1187, 4.00831, -25.594, 4.01355, -23.1418
4.0188, -20.781, 4.02405, -18.5293, 4.0293, -16.4038, 4.03454, -14.4207
4.03978, -12.595, 4.04503, -10.9403, 4.05027, -9.46936, 4.05551, -8.19313
4.06075, -7.12125, 4.06598, -6.26179, 4.07122, -5.62117, 4.07645, -5.20416
4.08169, -5.01383, 4.08692, -5.05152, 4.09215, -5.31684, 4.09738, -5.80766
4.10261, -6.52016, 4.10784, -7.4488, 4.11307, -8.58644, 4.11829, -9.92433
4.12351, -11.4522, 4.12874, -13.1584, 4.13396, -15.0298, 4.13918, -17.0521
4.1444, -19.2099, 4.14962, -21.4867, 4.15483, -23.8652, 4.16005, -26.3272
4.16526, -28.8541, 4.17048, -31.4264, 4.17569, -34.0247, 4.1809, -36.6292
4.18611, -39.2202, 4.19132, -41.7778, 4.19652, -44.2828, 4.20173, -46.716
4.20694, -49.059, 4.21214, -51.2941, 4.21734, -53.4043, 4.22254, -55.3736
4.22774, -57.1871, 4.23294, -58.8311, 4.23814, -60.2932, 4.24333, -61.5624
4.24853, -62.629, 4.25372, -63.4852, 4.25892, -64.1244, 4.26411, -64.542
4.2693, -64.7348, 4.27449, -64.7015, 4.27967, -64.4425, 4.28486, -63.9597
4.29005, -63.2571, 4.29523, -62.34, 4.30041, -61.2155, 4.3056, -59.8923
4.31078, -58.3805, 4.31595, -56.6916, 4.32113, -54.8387, 4.32631, -52.8358
4.33149, -50.6983, 4.33666, -48.4425, 4.34183, -46.0855, 4.34701, -43.6454
4.35218, -41.1407, 4.35735, -38.5906, 4.36251, -36.0143, 4.36768, -33.4315
4.37285, -30.8618, 4.37801, -28.3248, 4.38318, -25.8398, 4.38834, -23.4255
4.3935, -21.1003, 4.39866, -18.8819, 4.40382, -16.7871, 4.40898, -14.8316
4.41413, -13.0304, 4.41929, -11.3971, 4.42444, -9.94387, 4.42959, -8.68182
4.43474, -7.62041, 4.43989, -6.76762, 4.44504, -6.12984, 4.45019, -5.7118
4.45534, -5.51658, 4.46048, -5.54557, 4.46563, -5.79843, 4.47077, -6.27314
4.47591, -6.96598, 4.48105, -7.87159, 4.48619, -8.98298, 4.49133, -10.2916
4.49647, -11.7874, 4.5016, -13.459, 4.50674, -15.2935, 4.51187, -17.277
4.517, -19.3942, 4.52213, -21.629, 4.52726, -23.9645, 4.53239, -26.3827
4.53752, -28.8653, 4.54264, -31.3933, 4.54777, -33.9475, 4.55289, -36.5086
4.55802, -39.0569, 4.56314, -41.5733, 4.56826, -44.0384, 4.57338, -46.4337
4.57849, -48.741, 4.58361, -50.9427, 4.58872, -53.0222, 4.59384, -54.9637
4.59895, -56.7525, 4.60406, -58.3752, 4.60917, -59.8194, 4.61428, -61.0743
4.61939, -62.1304, 4.6245, -62.9797, 4.6296, -63.616, 4.63471, -64.0344
4.63981, -64.232, 4.64491, -64.2072, 4.65001, -63.9605, 4.65511, -63.4937
4.66021, -62.8106, 4.66531, -61.9164, 4.6704, -60.8181, 4.6755, -59.524
4.68059, -58.0441, 4.68568, -56.3898, 4.69077, -54.5736, 4.69586, -52.6096
4.70095, -50.5126, 4.70604, -48.2987, 4.71112, -45.9848, 4.71621, -43.5884
4.72129, -41.128, 4.72638, -38.6221, 4.73146, -36.0899, 4.73654, -33.5506
4.74162, -31.0235, 4.74669, -28.5279, 4.75177, -26.0827, 4.75684, -23.7064
4.76192, -21.417, 4.76699, -19.2321, 4.77206, -17.168, 4.77713, -15.2404
4.7822, -13.464, 4.78727, -11.8521, 4.79234, -10.417, 4.7974, -9.16933
4.80247, -8.11866, 4.80753, -7.27281, 4.81259, -6.63813, 4.81765, -6.21934
4.82271, -6.01952, 4.82777, -6.04008, 4.83283, -6.28075, 4.83788, -6.73962
4.84294, -7.41307, 4.84799, -8.2959, 4.85304, -9.38128, 4.85809, -10.6609
4.86314, -12.1249, 4.86819, -13.762, 4.87324, -15.5599, 4.87829, -17.5046
4.88333, -19.5814, 4.88837, -21.7743, 4.89342, -24.0668, 4.89846, -26.4412
4.9035, -28.8796, 4.90854, -31.3633, 4.91357, -33.8735, 4.91861, -36.3911
4.92365, -38.8968, 4.92868, -41.3717, 4.93371, -43.797, 4.93874, -46.1543
4.94377, -48.4256, 4.9488, -50.5938, 4.95383, -52.6424, 4.95886, -54.556
4.96388, -56.3199, 4.96891, -57.921, 4.97393, -59.3471, 4.97895, -60.5874
4.98397, -61.6326, 4.98899, -62.4748, 4.99401, -63.1079, 4.99903, -63.5269
5.00404, -63.7289, 5.00906, -63.7125, 5.01407, -63.4778, 5.01908, -63.0268
5.0241, -62.3629, 5.02911, -61.4914, 5.03411, -60.4189, 5.03912, -59.1537
5.04413, -57.7056, 5.04913, -56.0855, 5.05414, -54.306, 5.05914, -52.3806
5.06414, -50.324, 5.06914, -48.1519, 5.07414, -45.8809, 5.07914, -43.5283
5.08413, -41.112, 5.08913, -38.6504, 5.09412, -36.1623, 5.09912, -33.6665
5.10411, -31.1821, 5.1091, -28.7279, 5.11409, -26.3226, 5.11907, -23.9844
5.12406, -21.7311, 5.12905, -19.5797, 5.13403, -17.5466, 5.13901, -15.6471
5.144, -13.8957, 5.14898, -12.3055, 5.15396, -10.8886, 5.15894, -9.65565
5.16391, -8.61597, 5.16889, -7.77734, 5.17386, -7.14605, 5.17884, -6.72678
5.18381, -6.52263, 5.18878, -6.53504, 5.19375, -6.7638, 5.19872, -7.20709
5.20369, -7.86142, 5.20865, -8.72171, 5.21362, -9.78133, 5.21858, -11.0321
5.22354, -12.4645, 5.2285, -14.0674, 5.23346, -15.8287, 5.23842, -17.7349
5.24338, -19.7714, 5.24834, -21.9226, 5.25329, -24.1722, 5.25825, -26.5029
5.2632, -28.8972, 5.26815, -31.3366, 5.2731, -33.8027, 5.27805, -36.2767
5.283, -38.7398, 5.28795, -41.1732, 5.29289, -43.5585, 5.29784, -45.8777
5.30278, -48.1129, 5.30772, -50.2475, 5.31266, -52.265, 5.3176, -54.1504
5.32254, -55.8892, 5.32748, -57.4685, 5.33241, -58.8762, 5.33735, -60.1016
5.34228, -61.1357, 5.34721, -61.9706, 5.35215, -62.6001, 5.35708, -63.0196
5.362, -63.2258, 5.36693, -63.2173, 5.37186, -62.9944, 5.37678, -62.5588
5.38171, -61.914, 5.38663, -61.0648, 5.39155, -60.018, 5.39647, -58.7815
5.40139, -57.3649, 5.40631, -55.779, 5.41122, -54.0359, 5.41614, -52.1489
5.42105, -50.1326, 5.42597, -48.0022, 5.43088, -45.774, 5.43579, -43.465
5.4407, -41.0929, 5.44561, -38.6756, 5.45051, -36.2315, 5.45542, -33.7793
5.46032, -31.3376, 5.46523, -28.9249, 5.47013, -26.5596, 5.47503, -24.2596
5.47993, -22.0424, 5.48483, -19.9248, 5.48972, -17.9228, 5.49462, -16.0516
5.49952, -14.3254, 5.50441, -12.7571, 5.5093, -11.3588, 5.51419, -10.1408
5.51908, -9.11234, 5.52397, -8.2812, 5.52886, -7.65356, 5.53374, -7.2341
5.53863, -7.02589, 5.54351, -7.03043, 5.5484, -7.24756, 5.55328, -7.67554
5.55816, -8.311, 5.56304, -9.14901, 5.56791, -10.1831, 5.57279, -11.4053
5.57767, -12.8063, 5.58254, -14.3752, 5.58741, -16.1002, 5.59229, -17.9679
5.59716, -19.9642, 5.60203, -22.0738, 5.60689, -24.2806, 5.61176, -26.5678
5.61663, -28.9179, 5.62149, -31.3131, 5.62635, -33.7351, 5.63122, -36.1655
5.63608, -38.5859, 5.64094, -40.9778, 5.6458, -43.323, 5.65065, -45.6039
5.65551, -47.803, 5.66036, -49.9036, 5.66522, -51.89, 5.67007, -53.7469
5.67492, -55.4605, 5.67977, -57.0177, 5.68462, -58.4067, 5.68947, -59.6171
5.69431, -60.6398, 5.69916, -61.4671, 5.704, -62.0928, 5.70885, -62.5123
5.71369, -62.7224, 5.71853, -62.7217, 5.72337, -62.5103, 5.7282, -62.0899
5.73304, -61.4637, 5.73788, -60.6368, 5.74271, -59.6154, 5.74754, -58.4074
5.75238, -57.022, 5.75721, -55.47, 5.76204, -53.7632, 5.76686, -51.9145
5.77169, -49.9383, 5.77652, -47.8495, 5.78134, -45.6641, 5.78616, -43.3987
5.79099, -41.0706, 5.79581, -38.6975, 5.80063, -36.2975, 5.80545, -33.8889
5.81026, -31.4899, 5.81508, -29.1188, 5.81989, -26.7936, 5.82471, -24.532
5.82952, -22.351, 5.83433, -20.2673, 5.83914, -18.2967, 5.84395, -16.4539
5.84876, -14.7531, 5.85356, -13.2071, 5.85837, -11.8275, 5.86317, -10.6247
5.86798, -9.60775, 5.87278, -8.78436, 5.87758, -8.16066, 5.88238, -7.74128
5.88717, -7.5293, 5.89197, -7.52624, 5.89677, -7.73202, 5.90156, -8.14495
5.90635, -8.76181, 5.91115, -9.57779, 5.91594, -10.5866, 5.92073, -11.7805
5.92551, -13.1502, 5.9303, -14.6854, 5.93509, -16.3742, 5.93987, -18.2037
5.94466, -20.1599, 5.94944, -22.228, 5.95422, -24.3921, 5.959, -26.6357
5.96378, -28.9418, 5.96855, -31.2927, 5.97333, -33.6707, 5.97811, -36.0575
5.98288, -38.4351, 5.98765, -40.7854, 5.99242, -43.0905, 5.99719, -45.3329
6.00196, -47.4957, 6.00673, -49.5623, 6.0115, -51.5173, 6.01626, -53.3457
6.02102, -55.0337, 6.02579, -56.5686, 6.03055, -57.9387, 6.03531, -59.1339
6.04007, -60.1449, 6.04483, -60.9643, 6.04958, -61.5859, 6.05434, -62.0052
6.05909, -62.2189, 6.06385, -62.2257, 6.0686, -62.0255, 6.07335, -61.62
6.0781, -61.0123, 6.08285, -60.2073, 6.08759, -59.211, 6.09234, -58.0312
6.09708, -56.677, 6.10183, -55.1587, 6.10657, -53.4879, 6.11131, -51.6775
6.11605, -49.7412, 6.12079, -47.6938, 6.12553, -45.5511, 6.13026, -43.3292
6.135, -41.0451, 6.13973, -38.7163, 6.14446, -36.3604, 6.1492, -33.9953
6.15393, -31.6391, 6.15865, -29.3097, 6.16338, -27.0247, 6.16811, -24.8015
6.17283, -22.657, 6.17756, -20.6074, 6.18228, -18.6682, 6.187, -16.8541
6.19172, -15.179, 6.19644, -13.6553, 6.20116, -12.2947, 6.20588, -11.1073
6.21059, -10.1022, 6.21531, -9.28683, 6.22002, -8.66733, 6.22473, -8.24831
6.22944, -8.03284, 6.23415, -8.02246, 6.23886, -8.21715, 6.24357, -8.61532
6.24827, -9.21383, 6.25298, -10.008, 6.25768, -10.9918, 6.26238, -12.1576
6.26709, -13.4963, 6.27179, -14.9979, 6.27648, -16.6506, 6.28118, -18.4421
6.28588, -20.3584, 6.29057, -22.3851, 6.29527, -24.5066, 6.29996, -26.7068
6.30465, -28.9688, 6.30934, -31.2756, 6.31403, -33.6094, 6.31872, -35.9526
6.3234, -38.2874, 6.32809, -40.596, 6.33277, -42.8609, 6.33746, -45.0648
6.34214, -47.1911, 6.34682, -49.2236, 6.3515, -51.1469, 6.35618, -52.9466
6.36085, -54.6089, 6.36553, -56.1212, 6.3702, -57.4723, 6.37488, -58.6518
6.37955, -59.651, 6.38422, -60.4622, 6.38889, -61.0795, 6.39356, -61.4982
6.39822, -61.7154, 6.40289, -61.7293, 6.40755, -61.54, 6.41222, -61.1491
6.41688, -60.5597, 6.42154, -59.7763, 6.4262, -58.805, 6.43086, -57.6532
6.43552, -56.3298, 6.44017, -54.845, 6.44483, -53.2102, 6.44948, -51.4377
6.45414, -49.5413, 6.45879, -47.5353, 6.46344, -45.435, 6.46809, -43.2566
6.47273, -41.0165, 6.47738, -38.7318, 6.48203, -36.42, 6.48667, -34.0986
6.49131, -31.7852, 6.49595, -29.4975, 6.5006, -27.2528, 6.50523, -25.0682
6.50987, -22.9602, 6.51451, -20.9448, 6.51915, -19.0373, 6.52378, -17.2522
6.52841, -15.6028, 6.53305, -14.1018, 6.53768, -12.7604, 6.54231, -11.5887
6.54693, -10.5956, 6.55156, -9.78857, 6.55619, -9.17355, 6.56081, -8.75517
6.56544, -8.53649, 6.57006, -8.51907, 6.57468, -8.70295, 6.5793, -9.08661
6.58392, -9.66704, 6.58854, -10.4397, 6.59315, -11.3987, 6.59777, -12.5366
6.60238, -13.8446, 6.60699, -15.3127, 6.6116, -16.9297, 6.61622, -18.6832
6.62082, -20.5598, 6.62543, -22.5451, 6.63004, -24.6241, 6.63464, -26.7809
6.63925, -28.999, 6.64385, -31.2616, 6.64845, -33.5514, 6.65305, -35.851
6.65765, -38.1429, 6.66225, -40.4097, 6.66685, -42.6342, 6.67144, -44.7995
6.67604, -46.8892, 6.68063, -48.8874, 6.68522, -50.779, 6.68981, -52.5497
6.6944, -54.186, 6.69899, -55.6756, 6.70358, -57.0073, 6.70817, -58.171
6.71275, -59.158, 6.71733, -59.9608, 6.72192, -60.5735, 6.7265, -60.9915
6.73108, -61.2116, 6.73566, -61.2325, 6.74023, -61.0539, 6.74481, -60.6774
6.74939, -60.1059, 6.75396, -59.3439, 6.75853, -58.3972, 6.7631, -57.2732
6.76767, -55.9805, 6.77224, -54.529, 6.77681, -52.9299, 6.78138, -51.1953
6.78594, -49.3385, 6.79051, -47.3737, 6.79507, -45.3159, 6.79963, -43.1808
6.80419, -40.9847, 6.80875, -38.7442, 6.81331, -36.4764, 6.81787, -34.1987
6.82242, -31.9282, 6.82698, -29.6823, 6.83153, -27.478, 6.83608, -25.332
6.84064, -23.2607, 6.84518, -21.2797, 6.84973, -19.4041, 6.85428, -17.648
6.85883, -16.0247, 6.86337, -14.5465, 6.86792, -13.2246, 6.87246, -12.0689
6.877, -11.0881, 6.88154, -10.2896, 6.88608, -9.67932, 6.89062, -9.26184
6.89515, -9.04023, 6.89969, -9.01605, 6.90422, -9.18939, 6.90875, -9.55883
6.91329, -10.1214, 6.91782, -10.8729, 6.92234, -11.8073, 6.92687, -12.9175
6.9314, -14.1949, 6.93593, -15.6298, 6.94045, -17.2112, 6.94497, -18.9269
6.94949, -20.7639, 6.95402, -22.7081, 6.95853, -24.7447, 6.96305, -26.8582
6.96757, -29.0324, 6.97209, -31.2508, 6.9766, -33.4965, 6.98111, -35.7525
6.98563, -38.0015, 6.99014, -40.2265, 6.99465, -42.4106, 6.99916, -44.5371
7.00366, -46.59, 7.00817, -48.5538, 7.01267, -50.4134, 7.01718, -52.1549
7.02168, -53.7651, 7.02618, -55.2318, 7.03068, -56.5439, 7.03518, -57.6915
7.03968, -58.6661, 7.04417, -59.4602, 7.04867, -60.068, 7.05316, -60.4849
7.05766, -60.7079, 7.06215, -60.7353, 7.06664, -60.5671, 7.07113, -60.2047
7.07562, -59.6509, 7.0801, -58.91, 7.08459, -57.9878, 7.08907, -56.8914
7.09356, -55.6291, 7.09804, -54.2107, 7.10252, -52.6471, 7.107, -50.9502
7.11148, -49.133, 7.11595, -47.2093, 7.12043, -45.1938, 7.1249, -43.102
7.12938, -40.9497, 7.13385, -38.7534, 7.13832, -36.5297, 7.14279, -34.2956
7.14726, -32.068, 7.15173, -29.864, 7.15619, -27.7002, 7.16066, -25.593
7.16512, -23.5585, 7.16958, -21.6121, 7.17405, -19.7684, 7.17851, -18.0416
7.18296, -16.4446, 7.18742, -14.9895, 7.19188, -13.6873, 7.19633, -12.5478
7.20079, -11.5795, 7.20524, -10.7898, 7.20969, -10.1846, 7.21414, -9.76832
7.21859, -9.54405, 7.22304, -9.51339, 7.22749, -9.67647, 7.23193, -10.032
7.23638, -10.577, 7.24082, -11.3074, 7.24526, -12.2175, 7.2497, -13.3003
7.25414, -14.5474, 7.25858, -15.9493, 7.26302, -17.4952, 7.26745, -19.1733
7.27189, -20.9709, 7.27632, -22.8741, 7.28075, -24.8684, 7.28519, -26.9386
7.28962, -29.069, 7.29404, -31.2432, 7.29847, -33.4449, 7.3029, -35.6572
7.30732, -37.8632, 7.31175, -40.0463, 7.31617, -42.1899, 7.32059, -44.2776
7.32501, -46.2936, 7.32943, -48.2227, 7.33385, -50.0503, 7.33826, -51.7624
7.34268, -53.3462, 7.34709, -54.7897, 7.35151, -56.082, 7.35592, -57.2133
7.36033, -58.1751, 7.36474, -58.9603, 7.36915, -59.5629, 7.37355, -59.9785
7.37796, -60.204, 7.38236, -60.2378, 7.38677, -60.0798, 7.39117, -59.7312
7.39557, -59.1948, 7.39997, -58.4748, 7.40437, -57.5768, 7.40876, -56.5076
7.41316, -55.2756, 7.41755, -53.8901, 7.42195, -52.3618, 7.42634, -50.7024
7.43073, -48.9246, 7.43512, -47.0419, 7.43951, -45.0687, 7.4439, -43.0201
7.44828, -40.9116, 7.45267, -38.7594, 7.45705, -36.5797, 7.46144, -34.3893
7.46582, -32.2047, 7.4702, -30.0426, 7.47458, -27.9194, 7.47895, -25.8511
7.48333, -23.8536, 7.48771, -21.9418, 7.49208, -20.1304, 7.49645, -18.433
7.50083, -16.8625, 7.5052, -15.4307, 7.50957, -14.1484, 7.51393, -13.0253
7.5183, -12.0699, 7.52267, -11.2893, 7.52703, -10.6894, 7.53139, -10.2746
7.53576, -10.0479, 7.54012, -10.0111, 7.54448, -10.1642, 7.54883, -10.506
7.55319, -11.0337, 7.55755, -11.7434, 7.5619, -12.6294, 7.56626, -13.685
7.57061, -14.902, 7.57496, -16.271, 7.57931, -17.7817, 7.58366, -19.4224
7.58801, -21.1806, 7.59235, -23.0429, 7.5967, -24.995, 7.60104, -27.0221
7.60538, -29.1086, 7.60973, -31.2388, 7.61407, -33.3964, 7.61841, -35.565
7.62274, -37.7281, 7.62708, -39.8692, 7.63142, -41.9721, 7.63575, -44.0209
7.64008, -45.9999, 7.64441, -47.8943, 7.64874, -49.6895, 7.65307, -51.3721
7.6574, -52.9293, 7.66173, -54.3494, 7.66605, -55.6216, 7.67038, -56.7364
7.6747, -57.6853, 7.67902, -58.4612, 7.68335, -59.0584, 7.68767, -59.4724
7.69198, -59.7001, 7.6963, -59.74, 7.70062, -59.5917, 7.70493, -59.2567
7.70925, -58.7375, 7.71356, -58.0381, 7.71787, -57.164, 7.72218, -56.122
7.72649, -54.92, 7.7308, -53.5672, 7.7351, -52.0741, 7.73941, -50.452
7.74371, -48.7135, 7.74801, -46.8716, 7.75232, -44.9406, 7.75662, -42.935
7.76092, -40.8703, 7.76521, -38.7622, 7.76951, -36.6266, 7.77381, -34.4799
7.7781, -32.3383, 7.78239, -30.2182, 7.78668, -28.1356, 7.79098, -26.1064
7.79526, -24.1459, 7.79955, -22.269, 7.80384, -20.49, 7.80813, -18.8222
7.81241, -17.2783, 7.81669, -15.8701, 7.82098, -14.608, 7.82526, -13.5016
7.82954, -12.5593, 7.83382, -11.7881, 7.83809, -11.1937, 7.84237, -10.7806
7.84664, -10.5519, 7.85092, -10.5091, 7.85519, -10.6525, 7.85946, -10.9808
7.86373, -11.4916, 7.868, -12.1807, 7.87227, -13.0429, 7.87653, -14.0715
7.8808, -15.2586, 7.88506, -16.5951, 7.88933, -18.0707, 7.89359, -19.6742
7.89785, -21.3932, 7.90211, -23.2146, 7.90636, -25.1247, 7.91062, -27.1087
7.91488, -29.1515, 7.91913, -31.2376, 7.92338, -33.3512, 7.92764, -35.476
7.93189, -37.5961, 7.93614, -39.6952, 7.94038, -41.7574, 7.94463, -43.7671
7.94888, -45.709, 7.95312, -47.5684, 7.95737, -49.3312, 7.96161, -50.9841
7.96585, -52.5145, 7.97009, -53.9109, 7.97433, -55.1628, 7.97856, -56.2607
7.9828, -57.1964, 7.98704, -57.9629, 7.99127, -58.5543, 7.9955, -58.9664
7.99973, -59.1961, 8.00396, -59.2418, 8.00819, -59.1031, 8.01242, -58.7814
8.01665, -58.2791, 8.02087, -57.6001, 8.0251, -56.7497, 8.02932, -55.7345
8.03354, -54.5623, 8.03776, -53.242, 8.04198, -51.7839, 8.0462, -50.199
8.05041, -48.4995, 8.05463, -46.6984, 8.05884, -44.8094, 8.06306, -42.8469
8.06727, -40.8259, 8.07148, -38.7618, 8.07569, -36.6703, 8.0799, -34.5673
8.08411, -32.4687, 8.08831, -30.3907, 8.09252, -28.3488, 8.09672, -26.3587
8.10092, -24.4354, 8.10512, -22.5936, 8.10932, -20.8471, 8.11352, -19.2091
8.11772, -17.6922, 8.12192, -16.3077, 8.12611, -15.066, 8.1303, -13.9766
8.1345, -13.0476, 8.13869, -12.286, 8.14288, -11.6975, 8.14707, -11.2864
8.15125, -11.0559, 8.15544, -11.0074, 8.15963, -11.1414, 8.16381, -11.4566
8.16799, -11.9506, 8.17218, -12.6195, 8.17636, -13.4581, 8.18053, -14.4599
8.18471, -15.6174, 8.18889, -16.9214, 8.19307, -18.3622, 8.19724, -19.9285
8.20141, -21.6085, 8.20559, -23.3893, 8.20976, -25.2573, 8.21393, -27.1983
8.21809, -29.1975, 8.22226, -31.2396, 8.22643, -33.3091, 8.23059, -35.3903
8.23476, -37.4672, 8.23892, -39.5243, 8.24308, -41.5457, 8.24724, -43.5162
8.2514, -45.4208, 8.25555, -47.2451, 8.25971, -48.9753, 8.26387, -50.5982
8.26802, -52.1016, 8.27217, -53.4742, 8.27632, -54.7056, 8.28047, -55.7864
8.28462, -56.7086, 8.28877, -57.4653, 8.29292, -58.0508, 8.29706, -58.4608
8.30121, -58.6921, 8.30535, -58.7433, 8.30949, -58.614, 8.31363, -58.3052
8.31777, -57.8195, 8.32191, -57.1607, 8.32605, -56.3337, 8.33018, -55.3451
8.33432, -54.2025, 8.33845, -52.9145, 8.34258, -51.4912, 8.34671, -49.9433
8.35084, -48.2828, 8.35497, -46.5223, 8.3591, -44.6752, 8.36322, -42.7557
8.36735, -40.7783, 8.37147, -38.7582, 8.37559, -36.7107, 8.37972, -34.6514
8.38384, -32.596, 8.38795, -30.5601, 8.39207, -28.5591, 8.39619, -26.6082
8.4003, -24.7223, 8.40442, -22.9156, 8.40853, -21.2018, 8.41264, -19.5939
8.41675, -18.104, 8.42086, -16.7434, 8.42497, -15.5224, 8.42907, -14.4502
8.43318, -13.5348, 8.43728, -12.7831, 8.44139, -12.2007, 8.44549, -11.792
8.44959, -11.5599, 8.45369, -11.506, 8.45779, -11.6308, 8.46188, -11.9332
8.46598, -12.4107, 8.47007, -13.0596, 8.47417, -13.8749, 8.47826, -14.8502
8.48235, -15.9782, 8.48644, -17.25, 8.49053, -18.6561, 8.49462, -20.1855
8.4987, -21.8266, 8.50279, -23.5669, 8.50687, -25.393, 8.51095, -27.2911
8.51503, -29.2466, 8.51911, -31.2448, 8.52319, -33.2702, 8.52727, -35.3077
8.53135, -37.3415, 8.53542, -39.3564, 8.5395, -41.3369, 8.54357, -43.2681
8.54764, -45.1354, 8.55171, -46.9244, 8.55578, -48.6218, 8.55985, -50.2146
8.56391, -51.6909, 8.56798, -53.0393, 8.57204, -54.2499, 8.57611, -55.3135
8.58017, -56.222, 8.58423, -56.9686, 8.58829, -57.5479, 8.59235, -57.9554
8.5964, -58.1882, 8.60046, -58.2445, 8.60451, -58.1242, 8.60857, -57.8282
8.61262, -57.3589, 8.61667, -56.7199, 8.62072, -55.9162, 8.62477, -54.9539
8.62882, -53.8406, 8.63286, -52.5848, 8.63691, -51.1961, 8.64095, -49.685
8.64499, -48.0633, 8.64903, -46.3433, 8.65307, -44.538, 8.65711, -42.6614
8.66115, -40.7276, 8.66519, -38.7515, 8.66922, -36.748, 8.67326, -34.7325
8.67729, -32.7202, 8.68132, -30.7264, 8.68535, -28.7663, 8.68938, -26.8548
8.69341, -25.0063, 8.69744, -23.2349, 8.70146, -21.554, 8.70548, -19.9763
8.70951, -18.5138, 8.71353, -17.1774, 8.71755, -15.9773, 8.72157, -14.9225
8.72559, -14.021, 8.72961, -13.2794, 8.73362, -12.7034, 8.73764, -12.2972
8.74165, -12.0639, 8.74566, -12.0049, 8.74967, -12.1209, 8.75368, -12.4106
8.75769, -12.8719, 8.7617, -13.501, 8.7657, -14.2932, 8.76971, -15.2423
8.77371, -16.341, 8.77772, -17.5809, 8.78172, -18.9524, 8.78572, -20.4451
8.78972, -22.0475, 8.79371, -23.7473, 8.79771, -25.5317, 8.8017, -27.3869
8.8057, -29.2989, 8.80969, -31.2531, 8.81368, -33.2345, 8.81767, -35.2282
8.82166, -37.219, 8.82565, -39.1916, 8.82964, -41.1312, 8.83362, -43.023
8.83761, -44.8527, 8.84159, -46.6064, 8.84557, -48.2708, 8.84955, -49.8333
8.85353, -51.2821, 8.85751, -52.6063, 8.86149, -53.7959, 8.86546, -54.8419
8.86944, -55.7364, 8.87341, -56.4727, 8.87738, -57.0454, 8.88136, -57.4502
8.88532, -57.6842, 8.88929, -57.7455, 8.89326, -57.6339, 8.89723, -57.3504
8.90119, -56.8972, 8.90516, -56.2777, 8.90912, -55.497, 8.91308, -54.5609
8.91704, -53.4768, 8.921, -52.2528, 8.92496, -50.8985, 8.92891, -49.4241
8.93287, -47.8411, 8.93682, -46.1613, 8.94078, -44.3978, 8.94473, -42.564
8.94868, -40.6737, 8.95263, -38.7415, 8.95657, -36.7821, 8.96052, -34.8103
8.96447, -32.8412, 8.96841, -30.8896, 8.97235, -28.9705, 8.9763, -27.0985
8.98024, -25.2876, 8.98418, -23.5517, 8.98812, -21.9038, 8.99205, -20.3565
8.99599, -18.9215, 8.99992, -17.6095, 9.00386, -16.4305, 9.00779, -15.3934
9.01172, -14.506, 9.01565, -13.7749, 9.01958, -13.2056, 9.02351, -12.8022
9.02743, -12.5678, 9.03136, -12.5041, 9.03528, -12.6114, 9.0392, -12.8888
9.04312, -13.3341, 9.04704, -13.9438, 9.05096, -14.7132, 9.05488, -15.6363
9.0588, -16.706, 9.06271, -17.914, 9.06663, -19.2512, 9.07054, -20.7073
9.07445, -22.2711, 9.07836, -23.9307, 9.08227, -25.6734, 9.08618, -27.4859
9.09009, -29.3544, 9.09399, -31.2646, 9.0979, -33.2021, 9.1018, -35.152
9.1057, -37.0995, 9.1096, -39.0299, 9.1135, -40.9285, 9.1174, -42.7808
9.1213, -44.5728, 9.12519, -46.291, 9.12909, -47.9222, 9.13298, -49.4543
9.13687, -50.8755, 9.14077, -52.1751, 9.14466, -53.3434, 9.14854, -54.3716
9.15243, -55.2519, 9.15632, -55.9777, 9.1602, -56.5436, 9.16409, -56.9454
9.16797, -57.1802, 9.17185, -57.2462, 9.17573, -57.1431, 9.17961, -56.8718
9.18349, -56.4343, 9.18736, -55.8343, 9.19124, -55.0763, 9.19511, -54.1661
9.19899, -53.1108, 9.20286, -51.9186, 9.20673, -50.5985, 9.2106, -49.1606
9.21447, -47.6161, 9.21833, -45.9766, 9.2222, -44.2547, 9.22606, -42.4635
9.22993, -40.6167, 9.23379, -38.7284, 9.23765, -36.813, 9.24151, -34.885
9.24537, -32.959, 9.24923, -31.0498, 9.25308, -29.1718, 9.25694, -27.3393
9.26079, -25.5661, 9.26464, -23.8658, 9.26849, -22.2511, 9.27234, -20.7344
9.27619, -19.3271, 9.28004, -18.0398, 9.28389, -16.8822, 9.28773, -15.863
9.29157, -14.9899, 9.29542, -14.2695, 9.29926, -13.7071, 9.3031, -13.3069
9.30694, -13.0718, 9.31078, -13.0036, 9.31461, -13.1025, 9.31845, -13.3679
9.32228, -13.7975, 9.32612, -14.3879, 9.32995, -15.1347, 9.33378, -16.032
9.33761, -17.0729, 9.34144, -18.2494, 9.34526, -19.5525, 9.34909, -20.9721
9.35291, -22.4975, 9.35674, -24.1169, 9.36056, -25.818, 9.36438, -27.5879
9.3682, -29.4129, 9.37202, -31.2793, 9.37583, -33.1728, 9.37965, -35.0789
9.38347, -36.9832, 9.38728, -38.8713, 9.39109, -40.7287, 9.3949, -42.5414
9.39871, -44.2957, 9.40252, -45.9781, 9.40633, -47.5761, 9.41014, -49.0775
9.41394, -50.4709, 9.41774, -51.7458, 9.42155, -52.8926, 9.42535, -53.9027
9.42915, -54.7685, 9.43295, -55.4835, 9.43675, -56.0423, 9.44054, -56.4409
9.44434, -56.6762, 9.44813, -56.7467, 9.45193, -56.6517, 9.45572, -56.3923
9.45951, -55.9705, 9.4633, -55.3895, 9.46709, -54.6539, 9.47087, -53.7695
9.47466, -52.7429, 9.47844, -51.5821, 9.48223, -50.296, 9.48601, -48.8945
9.48979, -47.3883, 9.49357, -45.7889, 9.49735, -44.1085, 9.50112, -42.36
9.5049, -40.5566, 9.50868, -38.7122, 9.51245, -36.8407, 9.51622, -34.9564
9.51999, -33.0737, 9.52376, -31.2068, 9.52753, -29.37, 9.5313, -27.5771
9.53507, -25.8418, 9.53883, -24.1773, 9.5426, -22.596, 9.54636, -21.1101
9.55012, -19.7307, 9.55388, -18.4682, 9.55764, -17.3322, 9.5614, -16.3312
9.56515, -15.4727, 9.56891, -14.7633, 9.57266, -14.2081, 9.57642, -13.8112
9.58017, -13.5757, 9.58392, -13.5032, 9.58767, -13.5941, 9.59142, -13.8477
9.59516, -14.2619, 9.59891, -14.8334, 9.60265, -15.5578, 9.6064, -16.4295
9.61014, -17.4418, 9.61388, -18.587, 9.61762, -19.8561, 9.62136, -21.2395
9.6251, -22.7266, 9.62883, -24.306, 9.63257, -25.9657, 9.6363, -27.693
9.64003, -29.4747, 9.64377, -31.2972, 9.6475, -33.1467, 9.65122, -35.009
9.65495, -36.8701, 9.65868, -38.7158, 9.6624, -40.532, 9.66613, -42.305
9.66985, -44.0213, 9.67357, -45.668, 9.67729, -47.2325, 9.68101, -48.703
9.68473, -50.0684, 9.68845, -51.3183, 9.69216, -52.4434, 9.69588, -53.4353
9.69959, -54.2863, 9.7033, -54.9902, 9.70701, -55.5417, 9.71072, -55.9367
9.71443, -56.1723, 9.71814, -56.2469, 9.72184, -56.1599, 9.72555, -55.9121
9.72925, -55.5056, 9.73295, -54.9434, 9.73665, -54.2301, 9.74035, -53.371
9.74405, -52.3729, 9.74775, -51.2434, 9.75145, -49.9912, 9.75514, -48.6258
9.75884, -47.1578, 9.76253, -45.5984, 9.76622, -43.9594, 9.76991, -42.2533
9.7736, -40.4933, 9.77729, -38.6927, 9.78097, -36.8652, 9.78466, -35.0247
9.78834, -33.1853, 9.79203, -31.3608, 9.79571, -29.5652, 9.79939, -27.8121
9.80307, -26.1148, 9.80674, -24.4861, 9.81042, -22.9384, 9.8141, -21.4834
9.81777, -20.1321, 9.82144, -18.8947, 9.82512, -17.7805, 9.82879, -16.798
9.83246, -15.9544, 9.83613, -15.2561, 9.83979, -14.7084, 9.84346, -14.3153
9.84712, -14.0796, 9.85079, -14.0031, 9.85445, -14.0862, 9.85811, -14.3283
9.86177, -14.7273, 9.86543, -15.2801, 9.86909, -15.9824, 9.87274, -16.8288
9.8764, -17.8128, 9.88005, -18.9268, 9.8837, -20.1621, 9.88736, -21.5095
9.89101, -22.9584, 9.89465, -24.498, 9.8983, -26.1163, 9.90195, -27.8011
9.90559, -29.5395, 9.90924, -31.3182, 9.91288, -33.1238, 9.91652, -34.9423
9.92016, -36.7602, 9.9238, -38.5634, 9.92744, -40.3383, 9.93108, -42.0715
9.93471, -43.7498, 9.93835, -45.3605, 9.94198, -46.8913, 9.94561, -48.3308
9.94924, -49.6679, 9.95287, -50.8927, 9.9565, -51.9959, 9.96013, -52.9692
9.96375, -53.8052, 9.96738, -54.4978, 9.971, -55.0417, 9.97463, -55.4329
9.97825, -55.6685, 9.98187, -55.7469, 9.98549, -55.6675, 9.9891, -55.4311
9.99272, -55.0396, 9.99633, -54.4961, 9.99995, -53.8047, 10.00356, -52.9708
10.00717, -52.001, 10.01078, -50.9025, 10.01439, -49.6839, 10.018, -48.3546
10.02161, -46.9246, 10.02521, -45.405, 10.02882, -43.8073, 10.03242, -42.1437
10.03602, -40.4269, 10.03962, -38.6701, 10.04322, -36.8865, 10.04682, -35.0898
10.05042, -33.2937, 10.05401, -31.5116, 10.05761, -29.7574, 10.0612, -28.0441
10.06479, -26.3849, 10.06838, -24.7923, 10.07197, -23.2783, 10.07556, -21.8544
10.07915, -20.5315, 10.08273, -19.3193, 10.08632, -18.2272, 10.0899, -17.2633
10.09348, -16.4349, 10.09706, -15.7481, 10.10064, -15.2081, 10.10422, -14.8189
10.1078, -14.5834, 10.11138, -14.5032, 10.11495, -14.5788, 10.11853, -14.8096
10.1221, -15.1937, 10.12567, -15.7281, 10.12924, -16.4086, 10.13281, -17.2299
10.13638, -18.1858, 10.13994, -19.2688, 10.14351, -20.4706, 10.14707, -21.782
10.15064, -23.193, 10.1542, -24.6928, 10.15776, -26.2699, 10.16132, -27.9123
10.16488, -29.6075, 10.16843, -31.3424, 10.17199, -33.104, 10.17554, -34.8788
10.1791, -36.6533, 10.18265, -38.4141, 10.1862, -40.1477, 10.18975, -41.8409
10.1933, -43.4811, 10.19685, -45.0556, 10.20039, -46.5527, 10.20394, -47.9609
10.20748, -49.2696, 10.21102, -50.4691, 10.21456, -51.5501, 10.2181, -52.5045
10.22164, -53.3253, 10.22518, -54.0062, 10.22872, -54.5423, 10.23225, -54.9294
10.23579, -55.1647, 10.23932, -55.2467, 10.24285, -55.1747, 10.24638, -54.9494
10.24991, -54.5727, 10.25344, -54.0474, 10.25696, -53.3777, 10.26049, -52.5689
10.26401, -51.627, 10.26754, -50.5594, 10.27106, -49.3743, 10.27458, -48.0807
10.2781, -46.6887, 10.28162, -45.2087, 10.28514, -43.6522, 10.28865, -42.0309
10.29217, -40.3574, 10.29568, -38.6443, 10.29919, -36.9046, 10.3027, -35.1517
10.30621, -33.3989, 10.30972, -31.6594, 10.31323, -29.9465, 10.31673, -28.2732
10.32024, -26.6522, 10.32374, -25.0958, 10.32724, -23.6157, 10.33075, -22.2232
10.33425, -20.9287, 10.33774, -19.7421, 10.34124, -18.6722, 10.34474, -17.7273
10.34823, -16.9142, 10.35173, -16.2392, 10.35522, -15.7072, 10.35871, -15.3222
10.3622, -15.0871, 10.36569, -15.0035, 10.36918, -15.0719, 10.37267, -15.2917
10.37615, -15.6612, 10.37964, -16.1774, 10.38312, -16.8363, 10.3866, -17.6328
10.39008, -18.5607, 10.39356, -19.613, 10.39704, -20.7814, 10.40052, -22.0571
10.40399, -23.4303, 10.40747, -24.8905, 10.41094, -26.4265, 10.41441, -28.0266
10.41788, -29.6786, 10.42135, -31.3698, 10.42482, -33.0875, 10.42829, -34.8185
10.43176, -36.5497, 10.43522, -38.2679, 10.43869, -39.96, 10.44215, -41.6133
10.44561, -43.2152, 10.44907, -44.7535, 10.45253, -46.2165, 10.45599, -47.5934
10.45944, -48.8735, 10.4629, -50.0473, 10.46635, -51.1059, 10.4698, -52.0413
10.47326, -52.8466, 10.47671, -53.5156, 10.48016, -54.0435, 10.4836, -54.4263
10.48705, -54.6611, 10.4905, -54.7463, 10.49394, -54.6814, 10.49738, -54.467
10.50083, -54.1047, 10.50427, -53.5975, 10.50771, -52.9493, 10.51114, -52.1651
10.51458, -51.2511, 10.51802, -50.2141, 10.52145, -49.0623, 10.52489, -47.8044
10.52832, -46.45, 10.53175, -45.0096, 10.53518, -43.4941, 10.53861, -41.9151
10.54203, -40.2847, 10.54546, -38.6153, 10.54889, -36.9196, 10.55231, -35.2105
10.55573, -33.501, 10.55915, -31.8041, 10.56257, -30.1327, 10.56599, -28.4994
10.56941, -26.9168, 10.57283, -25.3966, 10.57624, -23.9506, 10.57966, -22.5896
10.58307, -21.3238, 10.58648, -20.1629, 10.58989, -19.1156, 10.5933, -18.1898
10.59671, -17.3923, 10.60012, -16.7293, 10.60352, -16.2056, 10.60693, -15.8252
10.61033, -15.5907, 10.61373, -15.5039, 10.61713, -15.5654, 10.62053, -15.7745
10.62393, -16.1296, 10.62733, -16.6279, 10.63072, -17.2655, 10.63412, -18.0374
10.63751, -18.9376, 10.6409, -19.9593, 10.64429, -21.0946, 10.64768, -22.3348
10.65107, -23.6703, 10.65446, -25.091, 10.65785, -26.586, 10.66123, -28.1439
10.66462, -29.7528, 10.668, -31.4004, 10.67138, -33.0742, 10.67476, -34.7614
10.67814, -36.4492, 10.68152, -38.1248, 10.68489, -39.7754, 10.68827, -41.3886
10.69164, -42.9521, 10.69502, -44.4539, 10.69839, -45.8829, 10.70176, -47.2281
10.70513, -48.4794, 10.7085, -49.6274, 10.71186, -50.6634, 10.71523, -51.5795
10.71859, -52.369, 10.72196, -53.026, 10.72532, -53.5454, 10.72868, -53.9235
10.73204, -54.1575, 10.7354, -54.2458, 10.73875, -54.1877, 10.74211, -53.9838
10.74546, -53.6358, 10.74882, -53.1463, 10.75217, -52.5194, 10.75552, -51.7597
10.75887, -50.8732, 10.76222, -49.8667, 10.76557, -48.7479, 10.76891, -47.5254
10.77226, -46.2086, 10.7756, -44.8076, 10.77895, -43.3331, 10.78229, -41.7963
10.78563, -40.209, 10.78897, -38.5832, 10.7923, -36.9313, 10.79564, -35.266
10.79898, -33.5999, 10.80231, -31.9456, 10.80564, -30.3157, 10.80898, -28.7227
10.81231, -27.1785, 10.81564, -25.6948, 10.81896, -24.283, 10.82229, -22.9536
10.82562, -21.7168, 10.82894, -20.5818, 10.83226, -19.5573, 10.83559, -18.6508
10.83891, -17.8693, 10.84223, -17.2185, 10.84555, -16.7034, 10.84886, -16.3277
10.85218, -16.0942, 10.85549, -16.0045, 10.85881, -16.0593, 10.86212, -16.2581
10.86543, -16.5991, 10.86874, -17.0797, 10.87205, -17.6962, 10.87536, -18.4437
10.87866, -19.3165, 10.88197, -20.3079, 10.88527, -21.4102, 10.88857, -22.615
10.89188, -23.913, 10.89518, -25.2944, 10.89848, -26.7485, 10.90177, -28.2643
10.90507, -29.8301, 10.90837, -31.4341, 10.91166, -33.064, 10.91495, -34.7074
10.91824, -36.3518, 10.92154, -37.9848, 10.92483, -39.5939, 10.92811, -41.1668
10.9314, -42.6918, 10.93469, -44.1571, 10.93797, -45.5518, 10.94125, -46.8652
10.94454, -48.0875, 10.94782, -49.2095, 10.9511, -50.2226, 10.95438, -51.1192
10.95765, -51.8927, 10.96093, -52.5372, 10.9642, -53.048, 10.96748, -53.4212
10.97075, -53.6541, 10.97402, -53.7451, 10.97729, -53.6935, 10.98056, -53.4999
10.98383, -53.1658, 10.98709, -52.694, 10.99036, -52.0879, 10.99362, -51.3525
10.99689, -50.4933, 11.00015, -49.517, 11.00341, -48.4311, 11.00667, -47.2439
11.00992, -45.9646, 11.01318, -44.6028, 11.01644, -43.1691, 11.01969, -41.6744
11.02294, -40.13, 11.0262, -38.5479, 11.02945, -36.9399, 11.0327, -35.3184
11.03594, -33.6956, 11.03919, -32.084, 11.04244, -30.4958, 11.04568, -28.943
11.04893, -27.4373, 11.05217, -25.9903, 11.05541, -24.6128, 11.05865, -23.3153
11.06189, -22.1076, 11.06512, -20.9988, 11.06836, -19.9972, 11.0716, -19.1104
11.07483, -18.345, 11.07806, -17.7068, 11.08129, -17.2005, 11.08452, -16.8298
11.08775, -16.5975, 11.09098, -16.5053, 11.09421, -16.5537, 11.09743, -16.7423
11.10066, -17.0695, 11.10388, -17.5327, 11.1071, -18.1283, 11.11032, -18.8517
11.11354, -19.6973, 11.11676, -20.6586, 11.11997, -21.7281, 11.12319, -22.8977
11.1264, -24.1584, 11.12962, -25.5006, 11.13283, -26.914, 11.13604, -28.3877
11.13925, -29.9106, 11.14246, -31.471, 11.14566, -33.057, 11.14887, -34.6566
11.15208, -36.2577, 11.15528, -37.8479, 11.15848, -39.4153, 11.16168, -40.948
11.16488, -42.4343, 11.16808, -43.863, 11.17128, -45.2232, 11.17447, -46.5047
11.17767, -47.6978, 11.18086, -48.7935, 11.18406, -49.7835, 11.18725, -50.6604
11.19044, -51.4176, 11.19363, -52.0495, 11.19681, -52.5513, 11.2, -52.9193
11.20318, -53.1508, 11.20637, -53.2442, 11.20955, -53.1989, 11.21273, -53.0153
11.21591, -52.695, 11.21909, -52.2403, 11.22227, -51.6551, 11.22545, -50.9436
11.22862, -50.1115, 11.2318, -49.1653, 11.23497, -48.112, 11.23814, -46.9599
11.24131, -45.7178, 11.24448, -44.3952, 11.24765, -43.0022, 11.25082, -41.5495
11.25398, -40.0481, 11.25715, -38.5094, 11.26031, -36.9453, 11.26348, -35.3675
11.26664, -33.7882, 11.2698, -32.2193, 11.27296, -30.6728, 11.27611, -29.1603
11.27927, -27.6934, 11.28242, -26.2831, 11.28558, -24.9401, 11.28873, -23.6747
11.29188, -22.4963, 11.29503, -21.4138, 11.29818, -20.4354, 11.30133, -19.5685
11.30447, -18.8195, 11.30762, -18.1941, 11.31076, -17.6969, 11.31391, -17.3315
11.31705, -17.1008, 11.32019, -17.0062, 11.32333, -17.0485, 11.32647, -17.2272
11.3296, -17.5408, 11.33274, -17.9869, 11.33587, -18.5619, 11.33901, -19.2615
11.34214, -20.0801, 11.34527, -21.0115, 11.3484, -22.0484, 11.35153, -23.183
11.35466, -24.4065, 11.35778, -25.7096, 11.36091, -27.0823, 11.36403, -28.5141
11.36715, -29.9941, 11.37027, -31.511, 11.37339, -33.0532, 11.37651, -34.6091
11.37963, -36.1667, 11.38275, -37.7142, 11.38586, -39.2399, 11.38897, -40.7321
11.39209, -42.1797, 11.3952, -43.5715, 11.39831, -44.8972, 11.40142, -46.1465
11.40453, -47.3102, 11.40763, -48.3794, 11.41074, -49.3461, 11.41384, -50.203
11.41694, -50.9437, 11.42005, -51.5626, 11.42315, -52.0552, 11.42625, -52.4178
11.42934, -52.6477, 11.43244, -52.7433, 11.43554, -52.704, 11.43863, -52.5301
11.44172, -52.2231, 11.44482, -51.7855, 11.44791, -51.2207, 11.451, -50.533
11.45409, -49.7278, 11.45717, -48.8113, 11.46026, -47.7906, 11.46334, -46.6734
11.46643, -45.4684, 11.46951, -44.1848, 11.47259, -42.8324, 11.47567, -41.4215
11.47875, -39.9629, 11.48183, -38.4678, 11.4849, -36.9475, 11.48798, -35.4135
11.49105, -33.8777, 11.49413, -32.3515, 11.4972, -30.8467, 11.50027, -29.3747
11.50334, -27.9466, 11.5064, -26.5732, 11.50947, -25.2649, 11.51254, -24.0317
11.5156, -22.8828, 11.51866, -21.8269, 11.52172, -20.8719, 11.52479, -20.0251
11.52784, -19.2928, 11.5309, -18.6804, 11.53396, -18.1925, 11.53702, -17.8328
11.54007, -17.6038, 11.54312, -17.5072, 11.54618, -17.5437, 11.54923, -17.7128
11.55228, -18.0131, 11.55532, -18.4423, 11.55837, -18.997, 11.56142, -19.6729
11.56446, -20.4647, 11.56751, -21.3664, 11.57055, -22.371, 11.57359, -23.4708
11.57663, -24.6573, 11.57967, -25.9215, 11.58271, -27.2536, 11.58574, -28.6436
11.58878, -30.0808, 11.59181, -31.5542, 11.59484, -33.0527, 11.59788, -34.5647
11.60091, -36.0788, 11.60394, -37.5835, 11.60696, -39.0674, 11.60999, -40.5192
11.61302, -41.9279, 11.61604, -43.2828, 11.61906, -44.5737, 11.62209, -45.7907
11.62511, -46.9248, 11.62813, -47.9673, 11.63114, -48.9105, 11.63416, -49.7472
11.63718, -50.4711, 11.64019, -51.0768, 11.6432, -51.5599, 11.64622, -51.9168
11.64923, -52.1447, 11.65224, -52.2422, 11.65525, -52.2086, 11.65825, -52.0442
11.66126, -51.7504, 11.66426, -51.3295, 11.66727, -50.7849, 11.67027, -50.1207
11.67327, -49.3422, 11.67627, -48.4553, 11.67927, -47.4668, 11.68227, -46.3844
11.68526, -45.2163, 11.68826, -43.9716, 11.69125, -42.6596, 11.69425, -41.2905
11.69724, -39.8747, 11.70023, -38.423, 11.70322, -36.9465, 11.70621, -35.4563
11.70919, -33.9639, 11.71218, -32.4806, 11.71516, -31.0176, 11.71814, -29.5861
11.72113, -28.1969, 11.72411, -26.8606, 11.72709, -25.5871, 11.73007, -24.3863
11.73304, -23.2671, 11.73602, -22.238, 11.73899, -21.3067, 11.74197, -20.4802
11.74494, -19.7648, 11.74791, -19.1657, 11.75088, -18.6875, 11.75385, -18.3336
11.75682, -18.1067, 11.75978, -18.0084, 11.76275, -18.0392, 11.76571, -18.199
11.76867, -18.4863, 11.77163, -18.8989, 11.77459, -19.4335, 11.77755, -20.086
11.78051, -20.8513, 11.78347, -21.7235, 11.78642, -22.696, 11.78938, -23.7611
11.79233, -24.9107, 11.79528, -26.1361, 11.79823, -27.4279, 11.80118, -28.7761
11.80413, -30.1706, 11.80708, -31.6006, 11.81002, -33.0552, 11.81297, -34.5235
11.81591, -35.9941, 11.81885, -37.456, 11.82179, -38.8981, 11.82473, -40.3093
11.82767, -41.679, 11.83061, -42.9968, 11.83354, -44.2527, 11.83648, -45.4373
11.83941, -46.5416, 11.84234, -47.5572, 11.84527, -48.4766, 11.8482, -49.2928
11.85113, -49.9997, 11.85406, -50.592, 11.85699, -51.0654, 11.85991, -51.4162
11.86283, -51.642, 11.86576, -51.7411, 11.86868, -51.7129, 11.8716, -51.5577
11.87452, -51.2767, 11.87743, -50.8724, 11.88035, -50.3477, 11.88327, -49.7068
11.88618, -48.9547, 11.88909, -48.0971, 11.89201, -47.1407, 11.89492, -46.0928
11.89783, -44.9616, 11.90073, -43.7555, 11.90364, -42.4839, 11.90655, -41.1565
11.90945, -39.7834, 11.91235, -38.3751, 11.91526, -36.9423, 11.91816, -35.4959
11.92106, -34.047, 11.92395, -32.6065, 11.92685, -31.1855, 11.92975, -29.7946
11.93264, -28.4444, 11.93554, -27.1452, 11.93843, -25.9068, 11.94132, -24.7385
11.94421, -23.6492, 11.9471, -22.6471, 11.94998, -21.7397, 11.95287, -20.9338
11.95576, -20.2355, 11.95864, -19.65, 11.96152, -19.1817, 11.9644, -18.8339
11.96728, -18.6094, 11.97016, -18.5096, 11.97304, -18.5351, 11.97592, -18.6859
11.97879, -18.9604, 11.98167, -19.3567, 11.98454, -19.8715, 11.98741, -20.5008
11.99028, -21.2398, 11.99315, -22.0828, 11.99602, -23.0232, 11.99889, -24.0539
12.00175, -25.1668, 12.00462, -26.3536, 12.00748, -27.605, 12.01034, -28.9117
12.0132, -30.2634, 12.01606, -31.6501, 12.01892, -33.061, 12.02178, -34.4855
12.02463, -35.9126, 12.02749, -37.3317, 12.03034, -38.7317, 12.03319, -40.1023
12.03605, -41.4329, 12.0389, -42.7135, 12.04174, -43.9343, 12.04459, -45.0863
12.04744, -46.1606, 12.05028, -47.1491, 12.05313, -48.0445, 12.05597, -48.84
12.05881, -49.5296, 12.06165, -50.1082, 12.06449, -50.5715, 12.06733, -50.9161
12.07016, -51.1394, 12.073, -51.2398, 12.07583, -51.2168, 12.07867, -51.0705
12.0815, -50.8022, 12.08433, -50.414, 12.08716, -49.909, 12.08999, -49.2912
12.09281, -48.5652, 12.09564, -47.7368, 12.09846, -46.8123, 12.10129, -45.7988
12.10411, -44.7041, 12.10693, -43.5366, 12.10975, -42.3053, 12.11257, -41.0194
12.11539, -39.6889, 12.1182, -38.324, 12.12102, -36.9349, 12.12383, -35.5323
12.12664, -34.1269, 12.12945, -32.7294, 12.13226, -31.3503, 12.13507, -30.0001
12.13788, -28.6891, 12.14069, -27.4272, 12.14349, -26.2239, 12.1463, -25.0883
12.1491, -24.0291, 12.1519, -23.0542, 12.1547, -22.1709, 12.1575, -21.3858
12.1603, -20.7049, 12.16309, -20.1333, 12.16589, -19.6751, 12.16868, -19.3338
12.17148, -19.1118, 12.17427, -19.0108, 12.17706, -19.0314, 12.17985, -19.1733
12.18264, -19.4354, 12.18542, -19.8156, 12.18821, -20.3108, 12.19099, -20.9172
12.19378, -21.6302, 12.19656, -22.4441, 12.19934, -23.3528, 12.20212, -24.3491
12.2049, -25.4256, 12.20768, -26.5738, 12.21045, -27.7851, 12.21323, -29.0502
12.216, -30.3594, 12.21877, -31.7028, 12.22154, -33.07, 12.22431, -34.4506
12.22708, -35.8343, 12.22985, -37.2104, 12.23262, -38.5685, 12.23538, -39.8983
12.23815, -41.1897, 12.24091, -42.4329, 12.24367, -43.6185, 12.24643, -44.7376
12.24919, -45.7818, 12.25195, -46.743, 12.2547, -47.6142, 12.25746, -48.3887
12.26021, -49.0608, 12.26297, -49.6255, 12.26572, -50.0785, 12.26847, -50.4165
12.27122, -50.637, 12.27397, -50.7385, 12.27671, -50.7203, 12.27946, -50.5827
12.28221, -50.3267, 12.28495, -49.9545, 12.28769, -49.469, 12.29043, -48.8739
12.29317, -48.1739, 12.29591, -47.3744, 12.29865, -46.4816, 12.30138, -45.5023
12.30412, -44.4441, 12.30685, -43.315, 12.30958, -42.1237, 12.31232, -40.8794
12.31505, -39.5914, 12.31778, -38.2697, 12.3205, -36.9244, 12.32323, -35.5656
12.32595, -34.2037, 12.32868, -32.8491, 12.3314, -31.512, 12.33412, -30.2026
12.33684, -28.9309, 12.33956, -27.7064, 12.34228, -26.5384, 12.345, -25.4358
12.34771, -24.4068, 12.35043, -23.4593, 12.35314, -22.6003, 12.35585, -21.8363
12.35856, -21.1731, 12.36127, -20.6155, 12.36398, -20.1678, 12.36669, -19.8331
12.36939, -19.6141, 12.3721, -19.5121, 12.3748, -19.528, 12.3775, -19.6614
12.3802, -19.9113, 12.3829, -20.2756, 12.3856, -20.7516, 12.3883, -21.3353
12.391, -22.0224, 12.39369, -22.8075, 12.39639, -23.6846, 12.39908, -24.6469
12.40177, -25.6869, 12.40446, -26.7969, 12.40715, -27.9681, 12.40984, -29.1918
12.41252, -30.4585, 12.41521, -31.7586, 12.41789, -33.0821, 12.42057, -34.419
12.42326, -35.7591, 12.42594, -37.0923, 12.42862, -38.4083, 12.43129, -39.6972
12.43397, -40.9493, 12.43665, -42.1551, 12.43932, -43.3053, 12.44199, -44.3914
12.44467, -45.4052, 12.44734, -46.3389, 12.45001, -47.1856, 12.45267, -47.939
12.45534, -48.5933, 12.45801, -49.1437, 12.46067, -49.5862, 12.46334, -49.9174
12.466, -50.1349, 12.46866, -50.2372, 12.47132, -50.2236, 12.47398, -50.0943
12.47664, -49.8504, 12.47929, -49.4939, 12.48195, -49.0275, 12.4846, -48.455
12.48725, -47.7808, 12.4899, -47.01, 12.49255, -46.1486, 12.4952, -45.2034
12.49785, -44.1814, 12.5005, -43.0906, 12.50314, -41.9393, 12.50579, -40.7363
12.50843, -39.4908, 12.51107, -38.2124, 12.51371, -36.9106, 12.51635, -35.5956
12.51899, -34.2773, 12.52163, -32.9656, 12.52426, -31.6706, 12.5269, -30.4021
12.52953, -29.1698, 12.53216, -27.9828, 12.53479, -26.8503, 12.53742, -25.7808
12.54005, -24.7823, 12.54268, -23.8624, 12.5453, -23.028, 12.54793, -22.2853
12.55055, -21.6399, 12.55317, -21.0967, 12.5558, -20.6596, 12.55842, -20.332
12.56103, -20.1161, 12.56365, -20.0135, 12.56627, -20.0249, 12.56888, -20.1501
12.5715, -20.3881, 12.57411, -20.7368, 12.57672, -21.1937, 12.57933, -21.755
12.58194, -22.4165, 12.58455, -23.173, 12.58715, -24.0187, 12.58976, -24.9471
12.59236, -25.9509, 12.59497, -27.0227, 12.59757, -28.154, 12.60017, -29.3364
12.60277, -30.5606, 12.60537, -31.8175, 12.60796, -33.0974, 12.61056, -34.3905
12.61315, -35.6871, 12.61575, -36.9773, 12.61834, -38.2512, 12.62093, -39.4992
12.62352, -40.7118, 12.62611, -41.88, 12.6287, -42.9947, 12.63128, -44.0476
12.63387, -45.0308, 12.63645, -45.9368, 12.63903, -46.7589, 12.64161, -47.4908
12.64419, -48.1271, 12.64677, -48.6631, 12.64935, -49.0947, 12.65193, -49.4188
12.6545, -49.633, 12.65707, -49.7358, 12.65965, -49.7265, 12.66222, -49.6053
12.66479, -49.3732, 12.66736, -49.0322, 12.66993, -48.5847, 12.67249, -48.0345
12.67506, -47.3857, 12.67762, -46.6435, 12.68019, -45.8134, 12.68275, -44.9019
12.68531, -43.916, 12.68787, -42.8634, 12.69043, -41.7519, 12.69298, -40.5902
12.69554, -39.3871, 12.69809, -38.1518, 12.70065, -36.8937, 12.7032, -35.6225
12.70575, -34.3477, 12.7083, -33.0791, 12.71085, -31.8262, 12.71339, -30.5987
12.71594, -29.4058, 12.71849, -28.2566, 12.72103, -27.1596, 12.72357, -26.1234
12.72611, -25.1555, 12.72865, -24.2634, 12.73119, -23.4538, 12.73373, -22.7327
12.73627, -22.1055, 12.7388, -21.5768, 12.74133, -21.1507, 12.74387, -20.8303
12.7464, -20.6178, 12.74893, -20.5149, 12.75146, -20.5221, 12.75399, -20.6394
12.75651, -20.8656, 12.75904, -21.1991, 12.76156, -21.6372, 12.76409, -22.1763
12.76661, -22.8125, 12.76913, -23.5406, 12.77165, -24.3551, 12
RE: Displacement
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
RE: Displacement
thank you for your time
please see attached my amplitude
thanks
