FE Results Superposition
Hello Respectables,
I need clarification regarding superposition of the FEA results from different load cases. When the results are added, I am wondering, the reactions loads are not added each time. When the area of the concern is close to reactions/supports/boundary conditions, the reaction load would not be added twice and the FEA stresses won't be correct, when I will add the stresses from two different load cases. I am looking for the interference stresses, I will run FEA for interference fit of two contact surfaces first, then run the analysis under the other load cases,then, when I will add the stresses from press fit to other load case, i will not be adding the reaction load twice.
Thanks for the input.
RE: FE Results Superposition
Rick Fischer
Principal Engineer
Argonne National Laboratory
Please don't take this the wrong way, but it is absolutely critical you understand the implications of a nonlinear analysis if you're going to use it. You shouldn't be anywhere near a nonlinear solver until you grasp fundamental things like this, always be sure to thoroughly read your product manual as they're (usually) pretty well written.
