Any way to remove the "NC" from above members when viewing "Unity (bending)"
I've got a lot of members I'm not running code checks on, and all the "NC" really clutter up the viewspace.
RE: Any way to remove the "NC" from above members when viewing "Unity (bending)"
Can you de-select those members? They turn half-tone and I think the labels go away.
That's the only way I've figured out so far. Thanks JAE.
Once you get only the members selected that you can/want to see results for, you can use the saved selection states feature to save that view. The save feature will also save the locked/unlocked view state (unlocked keeps the ghosted members, whereas locked they are turned completely off)
