Automatic Flat Pattern Annotation on Siemens NX
I am using Siemens NX8 and after creating a sheet metal part with a flat pattern feature, I have generated a drawing in draft mode.
Every time I drop in a drawing view of the flat pattern part, NX automatically generates notes that specify bend radius, bend angle and bend direction for each bend.
When I try to delete or hide these notes; then save and close, they are regenerated each time I re-open the part in NX.
Can anyone tell me how I can turn this automatic function off?
Cheers
Chris
Design Engineer
RE: Automatic Flat Pattern Annotation on Siemens NX
If you go to the style of the view there should be a flat pattern tab. Click on that and at the bottom you will see check boxes to turn of the automatic labels.
Steve
NX 8.5.3.3
Perfect! Thank you!
Chris
Design Engineer
