Quick practical question about parrelel connected hydro motors
Hey guys
I have a quick practical question about connecting two hydromotors in a parellel circuit.
I need to power a winch-system with a hydraulic engine, but the torque needed to move the load is around : 8600 Nm.
Because of very limited space to instal the systeem and the goal to make the system weigh as few as possible, I`m trying to learn more about connecting two engines in a parralel circuit.
But I cannot find sufficient information about practically installing the two motors : Is it common to mechanically connect the two engines onto the same shaft? Or do you work with two not mechanically connected shafts?
And if its possible to connect the engines on the same shaft, do you place them behind each other on the same shaft next to the load or on each side of the shaft with the load in the middle?
Thanks in advance,
Information about usefull websites or books is also very welcome, I`m very happy to do the research myself but I`m kinda stuck at the moment.
RE: Quick practical question about parrelel connected hydro motors
Yes, it's possible to parallel hydraulic motors.
They >must< be mechanically connected.
Some designs of gear-type motors can be stacked on a common shaft.
Mike Halloran
Pembroke Pines, FL, USA
Yes commonly done.
The motors must be linked mechanically on one shaft, or the lightest loaded motor will over speed its load while the heavily loaded motor stalls.
Putting two motors on one belt conveyor shaft, one each end, is common.
Two motors may be more total space, weight and dollars than one larger motor, but it can divide up the space requirement into two locations. A smaller motor might fit into a tighter space, say inside the belt drum. Also, smaller motors typically are much more available, cheaper, and have higher rpm ratings than a single large motor. Putting two different motor sizes on the same drive shaft gives a total displacement that might not be available in a single larger motor.
There are ways to vary or two speed the circuit by bypassing one motor or the other, but that is more than what you asked.
try hydraulicspneumatics.com. There are some ebook sections there with basic hydraulic knowledge, and the magazine also.
kcj
