TEE LATERAL per ASME B16.9
I`m preparing content which includes standard elements per ASME B16.9 and sometimes manufacturer offers TEE LATERAL (Butt Welded) per ASME B16.9 but i could`t find any dimension in that ASME for it.
Are there any guidelines for calculation of dimensions? Is there any min/max length of that fitting? Because different manufacturer offer different dimension for those laterals.
RE: TEE LATERAL per ASME B16.9
Hence all vendors will offer something different based on wall thickness, material, pressure rating etc etc.
Manufacturer should not be stating that the lateral tee is in accordance with ASME B16.9 because as BigInch so rightly states it is not. Has the Manufacturer performed proof tests to demonstrate its pressure capability?
