convert NX file to JT using an external nx application
I have a bunch of NX part files which needs to be converted to jt format. I an unable to find any api in NX that will help me achieve this through an external NX application.
IS there some way I can use the translator present in NX dll's and automate this process?
Thanks in advance.
Thanks in advance.
RE: convert NX file to JT using an external nx application
You can use this utility.... ugtopv
I am furnishing the excerpts from NX documentation (NX9) below.
"Write JT files either individually or in batch mode without running NX.
To do this, use the command line application ugtopv. This application is located in the $UGII_BASE_DIR\pvtrans folder in the NX installation."
Best Regards
Kapil
