Welding of a loose ring flange (Appendix "Y" Flange)
Referring to the attached diagram, I would like to be sure I have correctly sized the flange welds.
Is the back weld the thickness of the pipe or, per Fig. UW-21 of ASME VIII Div.1, it says the back weld leg distance must be the lesser of 1.4 x tmin or the "hub" but this flange doesn't have a hub.
RE: Welding of a loose ring flange (Appendix "Y" Flange)
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
prex
