Exhaust valve for CNG
i have chemical composition on the valve material as follow:
C=10.06 ; Mn=2.12 ; Fe=50.91 ; Ni=5.27 ; Cu=1.37 ; Si=0.37; Cr=20.56.
How i can know this result is approximately to which std material?
RE: Exhaust valve for CNG
Unless your calibrations samples closely bracket this chemistry you could easily have more than 15% relative error on each element.
There are Cu bearing variants of 300 and 200 series stainless alloys, but given the obvious error in C the Cu could be surface as well.
Plymouth Tube
