Variation in stock flow to headbox
I'm seeing a fairly significant fluctuation in stock flow to a fourdrinier machine headbox. The frequency is about 4 minutes; hard to tell since the movement seems random. The magnitude of the fluctuation is about 200 L/min. Flow is about 3200 L/min normally. That makes the fluctuation a bit over 5 % of the normal flow. What may be causing this?
RE: Variation in stock flow to headbox
1. Does the stock enter the chest via a pipe system discharging above the chest level, if the stock is free falling into the chest it maybe entraining air putting the pump off-prime momentarily.
2. Does the chest include an agitator? If yes, check to see if it is beating air into the stock at reduced stock level, again putting the pump off-prime momentarily.
I assume you are maintain tight consistency control on the stock, ie., stock consistency is not fluctuating up and down although the normal low stock consistency to a head box probably wouldn't cause flow variations - more likely inconsistent / variable finished product weight.
Air is stock is also a cause since pumps will cavitate.
