1hp irigation pump hooked up wrong
I accidently hooked up a new motor to 110v supply and the motor was set to 220v.
I ran the motor for about 30 min or so then gave up. The next time I tried the motor cycled in and out a little. I then discovered my mistake and switched the motor to 110. Now it just makes an awful humming sound and smoke starts coming from it. I am wondering if there might be a way to save the motor????
Thanks for any help
Brian
RE: 1hp irigation pump hooked up wrong
If it is smoking when it is getting the proper voltage, you probably have developed turn to turn shorts. Too late, it's probably cooked.
Unless this is a very special and very expensive motor it will be cheaper to replace it than to rewind it.
Bill
"Why not the best?"
Jimmy Carter
I would say if there's smoke coming from it, it doesn't sound good. Smoke will usually be the varnish on the windings having overheated somewhat.
I'm surprised your upstream protection ( fuse or breaker) didn't provide any trip to the circuit.
Probably lost that motor: 200.00 dollars. 400.00 in labor and time already. Maybe 800.00 or more if you keep fighting the motor to try to save the 200.00
It could still operate for years after letting 'some' smoke out. My buddy's 5HP single phase compressor has let a little out over the years whenever it was started incorrectly (with head pressure) before a proper head-unloader was installed.
A much bigger problem is why it's not turning at all on proper voltage and then smoking. I believe your load is just too much for that motor. It actually ran on 240V but can not (ever) run on 120V (perhaps).
There are TWO possibilities.
1) The Start or Run or both capacitors (if it has them) where damaged by the 240V.
2) The motor does not have enough torque to get past the centrifugal switch and hence leaves the start winding engaged which will always start smoking in about 3 seconds and fry totally in about 10. Hence, your motor is undersized for the application.
Keith Cress
Does the motor have a nameplate? Post a picture of the nameplate, and one of the motor itself. It would reduce the guesswork if we have some idea what type of motor this is. smile
thanks for all the help already guys!!
I will try to get a picture. It is a 1hp a.o. Smith motor on a sta-right irrigation pump. It will work on either 220 or 110, comes from factory set to 220.... I hooked up to 110 supply and ran it for 30 min. it ran but I did not get any water up. Motor smelled a little hot but I blew it off to a new paint burning smell. Then next time I ran the pump trying to get the water up.. the motor ran but was cycling on and off a little like when a pressure switch is used. then it just started to hum and smoke.
I think I will try to put on a new capacitor and see if that works. If not then I'll replace the motor.
again
thanks for the help
Brian
Sounds like the motor was running at very high slip due to the voltage being low. Speed probably dropped below the kick-out for the starting winding which would explain the smoke. Sorry to say that I don't have a lot of hope for this one. neutral
The best hope is that in the race to failure between the capacitor and the winding insulation, the capacitor won, because that's easier to replace...
"Will work for (the memory of) salami"
It is my understanding that rewound motors are better than when they were new. In your case this motor can not be anything greater than 2 hp so buy another one because I suspect that the rewinding job will be costlier. Do a simple resistance test of the winding to find out if you have a shortcicuit.
Turned out to be an expensive lesson for me. I replaced the motor. Cost me $180.00. The upside was that I was able to get water back on to my customer. The grass can keep growing and I keep getting paid! Hopefully I can use the parts from blown motor to rebuild a pool motor that needs bearings. (Same motor)
Thanks with all the help
Brian
No Keith, I am in St. Pete, Fl. You go about 25 feet and hit water!
thanks again
c'ya next time I screw something
Hopefully a long long time. Lol
St Pete? Heck, you can go either sideways or down 25 feet and hit water.
Go 25 feet up and the water will come down and hit you most summer afternoons.
