Contractor responsibility for WPS/PQR ?
ASME Sec.9 states that the organization that has operational control over welding (manufacturer/contractor), is responsible for qualifying the WPS to be used in production welding. Is it permissible allow a contractor to use a clients' WPS/PQR to perform field welding for that client on an ASME code project?
RE: Contractor responsibility for WPS/PQR ?
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Hope this helps.
Stuart
