Getting error while using reuse library (NX8.5)
RE: Getting error while using reuse library (NX8.5)
Generally all files with the same name should exist in the same directory,
example:
angle_plate.prt
angle_plate.krx
angle_plate.xls
Then as this might be a part family you must set the part family save directory, as Kapil showed in the attached picture.
Note which tab is active in that image, the "Reusable component".
I.e you have received the part family template, but when you use this part family it will on the fly produce new parts, "family members" and these must be saved somewhere.
Tomas
Hi Tomas,
as you mentiontioned file extenions were all in single folder only. Even I created my own part family part in same folder and updated krx also. still i am getting same error. I can able to use standard reuse libraray which come from standard installation but I am unable to use my folder
Ganesh
