Parts visual cutted while turning, how to switch of
Hi Members,
after an unlucky combination of keys I pressed are menus away and another problem shows up.
I designed a wall (2733x873mm)after I left the sketcher I rotated the Wall and suddenly a half was cut by an invisible plane, like in CATIA with the tea can.
Where is the switch to turn off this behavior?
Thanks Bogdan
RE: Parts visual cutted while turning, how to switch of
try ctrl+f (fit view)
kukelyk
Yes it works. But it makes me wonder, why it not worked before with the "Fit" Button.
Thank you very much!! Bogdan
