NX RMB menu in assembly Navigator
Hi
We are developing a customization in NX which requires some command options in the RMB menu of Assembly Navigator. Is it possible through a Menuscript or API call?
Kindly advise.
Rajat Jain
Kindly advise.
Rajat Jain
RE: NX RMB menu in assembly Navigator
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Now as for NX 8.5 and NX 9.0, while the MB3 pop-up menu itself is not accessible to make changes/additions to, what we call the 'Shortcut Toolbar', which is available using Customization, can be modified. What you can do is add a 'User Command' which can then be set to show an icon of your choice and when selected can initiate any sort of action that you want, including the execution of a program, either written using NX Open, KF or any other language that you wish. You can also call a system command, launch a Journal/Macro or even a GRIP program, as well as any opening any existing NX dialog. All of this is done using the normal Customization function used to add items to toolbars and starting with NX 9.0 to the Ribbon Bar.
Anyway, that's about all that I can suggest at the moment. Note that if you do manage to create some sort of customized program for NX 7.5 and NX 8.0, that it should also work for NX 9.0, just that with NX 9.0 you can probably accomplish what you're looking for without having to write any custom programs, except perhaps the utility that you wish to execute, to add an additional action to MB3 when selecting a Component in the Assembly Navigator, or for that matter, when selecting a feature in the Part Navigator or an Assembly constraint in the Constraint Navigator.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
NX 8.5 added support for programmatically modifying the NX context menu (RMB/MB3) for objects including components.
The modifications include adding new options, suppressing options, setting an option to be the default action, and reordering the options.
Please see the example code in the "%UGII_BASE_DIR%/ugopen/SampleNXOpenApplications/C++/ConfigureContextMenu" directory.
HTH,
Joe
I could achieve it with API calls.
Thanks a lot for your help.
Rajat Jain
Rajat Jain
Technical Director
JeeneDo Auto-Configure Pvt. Ltd.
www.auto-configure.com
