Min. Standard Thickness of Two Way Slab
In my area (Northeast US) I do not typically see two way elevated slabs less than 8". Do others see/use less than this and if so what is a lower bound? I would think that 6" is pretty thin once tolerances and unknowns are accounted for, i.e. the 'd' being off by 1/2" in the field is a much larger percentage at 6" slab compared to 8". 7"?
RE: Min. Standard Thickness of Two Way Slab
But I bet you'll get a response from womeone who does it all the time.
there are equations in that section for minimum thickness h between supports.
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
It was most ridiculous slab design I have ever seen - design was probably dated early 1970's. We were tasked with repairs to corroded PT anchorages, and destressing was undertaken by chipping concrete behind the live-end anchorages. Bastard of a project.
I have a distaste for VERY thin slabs, be it RC or PT.
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
These often have 4 1/2", sometimes even 4". Supported on beams/walls though, not columns.
I've also come across really thin one way ribbed slabs from that era. 2.5" spanning one way between the ribs with a central layer of mesh, 2.5" wide ribs with a single bar bottom, and no shear reinforcement.
We specify 150mm slabs all the time.
My approach to selection of flat plate thickness is to consider punching shear first. This of course involves spans and column sizes, but if a flat plate works in punching shear, it will usually work in bending strength and serviceability.
