Project Folder Rename
Our projects are stored in a primary project folder that has relevant works sub-folders (Docs, Worksheets, Catia etc etc). We would like to rename the primary (root) project folder. There are no links outside of the Catia folder and its sub-folders they are only in the Catia folder and it's sub-folder.
Will renaming the primary project folder affect the links in the Catia folder and it's sub-folders?.
RE: Project Folder Rename
As I see, only problem is to update the Search Order (for all users).
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
you will have to use the desk tool to relocate those files. hope it helps. All the best.
