NX8.5. How to add user pause into the journal file
Hi All,
I have created a journal file. I need to put a pause, so that user can select the options in the dialog box. Iam not able to do that..
Iam learning to create the journal files..
NX8.5
Please can someone help in fine tuning this journal file..
NX8.5
RE: NX8.5. How to add user pause into the journal file
Please help.. All help and support highly appreciated..
Any help on this please?
Thanks a lot in advance
How do you want your journal to be interactive with the user...eg pick the face, put the number of curves in etc etc???
If so, doesn't the "out of the box" NX command give you this already or are you just experimenting?
I was trying to have a toolbar with a button which will run the journal in the background.. yes.. I want to pause for user to select the face and number of curves etc.
Please can you help in fine tuning the journal?
Thanks in advance..
If you just want to replay NX UI steps with a pause, a macro may work for that.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
