Extruding Projected Curve 1
I have a cylinder body in which I projected a sketch profile onto it. How can I get the projected curve to extrude (subtract) into the cylinder body and maintain the projected profile?
There is already a thread concerning this problem; however, I would like to know how to extrude the projected sketch in a way such that the newly created face of the extrusion is on a cylindrical path.
For further clarification: The extrusion would create a curved path which has an area that is the same as the area of the original projected sketch.
I have attached a very rough illustration, so please take a look if anything above is unclear.
Thank You.
Thank You.
RE: Extruding Projected Curve 1
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I cannot select the area inside of the projected sketch by itself. I can only select the entire face of the cylinder.
Also, in the Offset Region dialog box, in the Face tab, under the Reference tab, I cannot change the Reference to Fixed, as is selected in the attached file.
As for the 'Reference' tab, that plays no role here whatsoever so just ignore it (the system sets that to 'Fixed', NOT the user).
Try deleting/suppressing the 'Offset Region' feature and then follow the exact workflow I described in my post above making sure that you've set both the 'Face Rule' and the 'Overflow Behavior' option as I've indicated.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you for your help.
