Connection types (FF, RF, RTJ, NPT)
What do you use to determine what type of end connection you will use on a fitting.
For instance when do you use ring joint instead of a raised face or flat face
What about NPT connections?
The reason I am asking is I have seen some use 600# RTJ and then use 600# RF later.
My initial thoughts are the smaller sizes use NPT because a flanged connection would be impractical
Future PE Engineer
Pet project I am working on to help other engineers, not much yet hoping to get it grow as I learn more
http://www.peexamquestions.com
RE: Connection types (FF, RF, RTJ, NPT)
Just search RF RTJ on this forum for plenty of ideas. This is a typical exchange http://www.eng-tips.com/viewthread.cfm?qid=343642
FF is only for cast iron, low pressure stuff #125, #150 or plastic flanges where low bending stress is allowed
RF goes from #150 upwards. Where you stop is more depenadnat on who you work for or what your plant piping spec says than anything else.
You don't often see #600 RTJ, but some companies love them so put them on #300 flanges. NPT is more common for instruments and items of 1" and below as flanges of that size get bulky and weigh a lot compared to the pipe size.
You will find as many ideas and thoughts as there are people commenting here....
