ASTM a 709 vs a 588 steel
thread330-305847: ASTM equivalent of S235JR?
I'd like to know the ASTM A 709 on comparison with ASTM A 588.
Thanks for your help.
RE: ASTM a 709 vs a 588 steel
but I need justify the use or A 588 instead of A 709 in bridge design. I only found the difference between these in the charpy V-notch impact test. I need know if there are another difference
If you are responsible for designing/engineering a bridge, then you MUST understand the requirements of the steel that will be used in its construction. You cannot justify the use of either of these steels without reviewing the details included in the standards.
