Maximum Allowable Heat of Hydration and Differential Temperatures in Mass Concrete
Dear All;
Can someone help me locating any International Standard (ACI, ASTM, BS EN, CIRIA) that specifies;
1. MAX ALLOWABLE TEMPERATURE AT THE CORE OF A MASS CONCRETE STRUCTURE (THICKNESS > 1.0 METER)
2. MAX ALLOWABLE DIFFERENTIAL TEMPERATURE BETWEEN THE CORE AND THE SURFACE OF THE MASS CONCRETE STRUCTURE
I tried searching all ACI documents relating to Mass Concrete but they are very general. I believe there is one CIRIA publication that specifies.... Please shed some light.
Thanks in advance
Thanks in advance
RE: Maximum Allowable Heat of Hydration and Differential Temperatures in Mass Concrete
I had researched item 2 earlier this year and found a recommendation that the temperature differential should not exceed 30 degrees F. Can't seem to find the reference for that number.
Ralph
Structures Consulting
Northeast USA
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Yes, I should have had a look at it. It was only the contents and the introduction.
Doug Jenkins
