Medium and High Voltage Short Circuit Calculations Book request
Hey all,
I'm currently working on a project where I have to design a 33/11kV Substation. I will need to carry out fault calculations probably using Amtech Powernet HV. But I'd like to refresh my knowledge of the basic principles to understand it better.
I remember having books at uni which covered the different type of short circuit calculations and the power systems from the basics. I'm looking for a book like that in english language which it not too expensive and also quite easy to use.
Also a book which covers the basics of the transformers and generators/motors would be great.
Any recommendations ?
Csaba
RE: Medium and High Voltage Short Circuit Calculations Book request
Conrad St.Pierrie : A practical guide to short circuit calculations -Published in 2013
If you need a book on the basics of transformers / generators and motors, then you need to think carefully about whether you have the right skills and knowledge to design a 33/11kV sub! Also, Amtech Powernet HV is a very basic fault calculation package to use for a Primary sub installation such as this.
