Cast CS & LTCS Gate Valves (ASTM A216 Grade WCB 600 Flange ASME B16.5 RF)
Hi experts,
Could some one confirm if the heat number/lot number is mentioned on the subjected valves disc ? Our clint has rejected the valves at site and commented that the valves are rejected because no heat/lot number was found on the disc of gate valves.
Best Cares,
Best Cares,
RE: Cast CS & LTCS Gate Valves (ASTM A216 Grade WCB 600 Flange ASME B16.5 RF)
Is this also applicable on seat?
