CFT: Moment of Inertia?
I'm working on a design that includes a concrete-filled steel tube. Might anyone have equations handy for the moments of inertia when the neutral axis does not go through the center (see attached diagram)?
Referring to the diagram, I'm looking for the MoI of the concrete in compression (area Cc), steel in compression (partial arc Sc) and the steel in tension (partial arc St). I guess I could derive it by integration (gasp!), but before I reinvent the wheel, I'm hoping these equations might be tabulated somewhere. Thanks...
RE: CFT: Moment of Inertia?
Procedure is outlined in this pdf
Link
Be aware though this document is based on the previous 1990's revision of EN 1994: (Eurocode 4) Design of composite steel and concrete structures, but I think the stiffness part is the same in the latest revision. The procedure for working out the strength is slightly different in the most recent revision.
I guess the way you are wanting to calculate the moment of inertia would result in a lower value so it would possibly be conservative if you are simply looking at deflections of an isolated member. But if the distribution of loads in your structure are affected by the stiffness of various elements in say a moment frame for example, then you might be missing out on some load in the tube as the member would be stiffer than your calculated value (which possibly be unconservative, can't say for sure as don't know what you are designing).
As long as you know the geometric properties about one axis/edge you can transform it back to the center of the pipe via the parallel axis theorem if required. Don't forget to transform the properties to one material if you are wanting to work with one modulus of elasticity.
