Diaphragm Gasket For High Pressure Heat Exchanger
Appreciate if someone can tell me what is the diaphragm type gasket for the high pressure heat exchanger. The gasket is to be used for flange connection between the end cover plate to the channel flange. My limited knowledge for this type of gasket is that it is simply made of a thin sheet of metal to be fillet welded to the channel flange. My question is after being seal welded, how can the gasket being compressed with the bolt tightening.
Regards.
Regards.
RE: Diaphragm Gasket For High Pressure Heat Exchanger
There is no actual gasket compression involved. You simply need to tighten the bolting for pressure containment (end forces), not gasket seating forces. There is also a large volume of information about diaphragm gaskets on the internet.
Cheers,
gr2vessels
