O-Ring vs Square Ring vs Quad Ring vs Flat Gasket
I would like to know why you would pick one over the other.
Here is what I've found out so far:
Square is better than O-ring in static applications. (Good high pressure seal)
Quad is better than O-ring in dynamic applications. (Less pressure required, anti rolling)
Each ring seems to be better than a flat gasket (Less pressure required)
Now aside from cost, is there really a reason to use the traditional O-ring or gasket still?
Given same material/hardness/seal application/etc unless there is a valid difference on selection between one ring or the other.
Perhaps a description and example applications would be useful.
If enough people respond I will start adding their input to this post to keep as much information as possible at the top of the thread.
Wait, what? They have the internet on computers now?!?
RE: O-Ring vs Square Ring vs Quad Ring vs Flat Gasket
If there's a fair number of responses I'll just write a new thread with the useful info and flag this one to be removed.
Anyway here have been a few helpful websites, manuals and calculators:
http://www.parker.com/literature/ORD%205700%20Park...
http://www.newdealseals.com/catalogues/O-Rings.pdf
http://www.mnrubber.com/Design_Guide/PDF/Design_Gu...
http://www.sealseastern.com/PDF/LowPsiSeals.pdf
Quad
http://www.allsealsinc.com/quadrings.html
Square
http://www.alliedseals.com/square.htm
Calculators
http://www.parker.com/portal/site/PARKER/menuitem....# (haven't gotten this one to work)
http://o-ring.info/en/tools/o-ring-calculator/
http://www.marcorubber.com/gd-directory.htm
http://www.tss.trelleborg.com/global/en/service/or... (includes phone app calculators)
I think you need to describe your application. You cannot generalise like that. Can you send a drawing for people to make an informed decision in putting together a response?
Cheers
