Bold View Label letter.
Is possible create custom view label (section, detail,...) with bold letter?
NX 8.5.3.3
RE: Bold View Label letter.
Yes
In the defaults file, there is a setting for the characters used for section views. Add the bold code <B> as a prefix and <b> as a suffix to turn bolding off. You can also set character size, we used 1-1/2 times the height for the section letters. Underline can be set, also.
Ben Loosli
If you wish to control the 'style' of the lettering as well as the Font itself for view labels, go to...
Preferences -> Annotation -> Lettering
...and change the font and font style used for the 'General' category of 'Lettering Types'.
This can also be set for new Drawings by making changes to the Drafting Standard in...
Customer Defaults -> Drafting -> General -> Standard -> Lettering
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
You only want the letters (A-A) bolded, not the whole thing (SECTION A-A)?
My method used to work, before Siemens redid the customer defaults back to being program controlled instead of a text file.
Ben Loosli
Letters A-A and description "Section A-A". Where is said setting?
NX 8.5.3.3
Go to...
Preferences -> View Label...
...and set the type to 'Section'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
OK, <D> is the density setting for text.
If there is no way to set it, then NX has a regression from what was possible in UG2 V18.
Ben Loosli
Did you try setting the box with the letter B in it to <D1>B<D>?
Ben Loosli
Letter B to <D1>B<D> - show window with "Invalid letter"
NX 8.5.3.3
You can set the label weight under Annotation Style, not Edit View Label (at least in 6.0.5.3).
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
Yes, but I want View label bold as default and other notes without bold.
NX 8.5.3.3
