Temperature dependent Yield on Nonlinear Static Analysis
Hi all,
I have a problem when I try to make a nonlinear static analysis on Femap using a temperature-dependent function to represent the yield of the material.
I'm using the yield criterion from Von Mises, selecting in extended material model the function "Yield vs Temperature" which I defined previously.
I get, among others, the error no. 4676. I don't know how to do in order to introduce the "Yield vs Temperature" function properly in the Von Mises Yield Criterion in the "Non Linear Options" of the material. It seems as if the Nastran doesn't recognize this temperature dependence of the Yield.
I've searched in femap's help file and I've found this note:
"The "Initial Yield Stress" in the Define Nonlinear Material dialog box must be set to "1.0" for this to work properly when using this to define temperature dependent materials with a "5..Function vs. Temp" function. "
I've tried to do this point but I still doesn't work. I don't know what is going wrong.
I upload the model file and the *.f06 file.
Lots of thanks,
Alberto Souto
Lots of thanks,
Alberto Souto
RE: Temperature dependent Yield on Nonlinear Static Analysis
Thanks in advance,
Alberto Souto
INIT MASTER(S)
NASTRAN SYSTEM(442)=-1, PARALLEL=4, SYSTEM(319)=1
ID Prueba,Femap
SOL NLSTATIC
TIME 10000
CEND
TITLE = NonLinear
ECHO = NONE
DISPLACEMENT(PLOT) = ALL
SPCFORCE(PLOT) = ALL
FORCE(PLOT,CORNER) = ALL
NLSTRESS(PLOT) = ALL
STRESS(PLOT,CORNER) = ALL
SPC = 1
NLPARM = 1
TEMP(LOAD) = 1
TEMP(INIT) = 2
BEGIN BULK
$ Written by : Femap with NX Nastran
$ Version : 10.3.1
$ Translator : NX Nastran
$ From Model : C:\Users\Alberto\Desktop\Faldones\Horno Completo\NuevoDiseno\Prueba.modfem
$ Date : Mon May 19 22:51:25 2014
NLPARM 1 4 5 25 PW ALL+
+ .001 .001 1.-7 3 25 4 .2 .5+
+ 5 20. 20.
PARAM,LGDISP,1
PARAM,POST,-1
PARAM,OGEOM,NO
PARAM,AUTOSPC,YES
PARAM,K6ROT,100.
PARAM,GRDPNT,0
CORD2C 1 0 0. 0. 0. 0. 0. 1.+FEMAPC1
+FEMAPC1 1. 0. 1.
CORD2S 2 0 0. 0. 0. 0. 0. 1.+FEMAPC2
+FEMAPC2 1. 0. 1.
$ Femap with NX Nastran Load Set 1 : Temperature
TEMPD 1 294.25
TEMPP1 1 1 600.
TEMPP1 1 2 600.
TEMPP1 1 3 600.
TEMPP1 1 4 600.
TEMPP1 1 5 600.
TEMPP1 1 6 600.
TEMPP1 1 7 600.
TEMPP1 1 8 600.
TEMPP1 1 9 600.
TEMPP1 1 10 600.
TEMPP1 1 11 600.
TEMPP1 1 12 600.
TEMPP1 1 13 600.
TEMPP1 1 14 600.
TEMPP1 1 15 600.
TEMPP1 1 16 600.
TEMPP1 1 17 600.
TEMPP1 1 18 600.
TEMPP1 1 19 600.
TEMPP1 1 20 600.
TEMPP1 1 21 600.
TEMPP1 1 22 600.
TEMPP1 1 23 600.
TEMPP1 1 24 600.
TEMPP1 1 25 600.
TEMPP1 1 26 600.
TEMPP1 1 27 600.
TEMPP1 1 28 600.
TEMPP1 1 29 600.
TEMPP1 1 30 600.
TEMPP1 1 31 600.
TEMPP1 1 32 600.
TEMPP1 1 33 600.
TEMPP1 1 34 600.
TEMPP1 1 35 600.
TEMPP1 1 36 600.
TEMPP1 1 37 600.
TEMPP1 1 38 600.
TEMPP1 1 39 600.
TEMPP1 1 40 600.
TEMPP1 1 41 600.
TEMPP1 1 42 600.
TEMPP1 1 43 600.
TEMPP1 1 44 600.
TEMPP1 1 45 600.
TEMPP1 1 46 600.
TEMPP1 1 47 600.
TEMPP1 1 48 600.
TEMPP1 1 49 600.
TEMPP1 1 50 600.
TEMPP1 1 51 600.
TEMPP1 1 52 600.
TEMPP1 1 53 600.
TEMPP1 1 54 600.
TEMPP1 1 55 600.
TEMPP1 1 56 600.
TEMPP1 1 57 600.
TEMPP1 1 58 600.
TEMPP1 1 59 600.
TEMPP1 1 60 600.
TEMPP1 1 61 600.
TEMPP1 1 62 600.
TEMPP1 1 63 600.
TEMPP1 1 64 600.
TEMPP1 1 65 600.
TEMPP1 1 66 600.
TEMPP1 1 67 600.
TEMPP1 1 68 600.
TEMPP1 1 69 600.
TEMPP1 1 70 600.
TEMPP1 1 71 600.
TEMPP1 1 72 600.
TEMPP1 1 73 600.
TEMPP1 1 74 600.
TEMPP1 1 75 600.
TEMPP1 1 76 600.
TEMPP1 1 77 600.
TEMPP1 1 78 600.
TEMPP1 1 79 600.
TEMPP1 1 80 600.
TEMPP1 1 81 600.
TEMPP1 1 82 600.
TEMPP1 1 83 600.
TEMPP1 1 84 600.
TEMPP1 1 85 600.
TEMPP1 1 86 600.
TEMPP1 1 87 600.
TEMPP1 1 88 600.
TEMPP1 1 89 600.
TEMPP1 1 90 600.
TEMPP1 1 91 600.
TEMPP1 1 92 600.
TEMPP1 1 93 600.
TEMPP1 1 94 600.
TEMPP1 1 95 600.
TEMPP1 1 96 600.
TEMPP1 1 97 600.
TEMPP1 1 98 600.
TEMPP1 1 99 600.
TEMPP1 1 100 600.
TEMPP1 1 101 600.
TEMPP1 1 102 600.
TEMPP1 1 103 600.
TEMPP1 1 104 600.
TEMPP1 1 105 600.
TEMPP1 1 106 600.
TEMPP1 1 107 600.
TEMPP1 1 108 600.
TEMPP1 1 109 600.
TEMPP1 1 110 600.
TEMPP1 1 111 600.
TEMPP1 1 112 600.
TEMPP1 1 113 600.
TEMPP1 1 114 600.
TEMPP1 1 115 600.
TEMPP1 1 116 600.
TEMPP1 1 117 600.
TEMPP1 1 118 600.
TEMPP1 1 119 600.
TEMPP1 1 120 600.
TEMPP1 1 121 600.
TEMPP1 1 122 600.
TEMPP1 1 123 600.
TEMPP1 1 124 600.
TEMPP1 1 125 600.
TEMPP1 1 126 600.
TEMPP1 1 127 600.
TEMPP1 1 128 600.
TEMPP1 1 129 600.
TEMPP1 1 130 600.
TEMPP1 1 131 600.
TEMPP1 1 132 600.
TEMPP1 1 133 600.
TEMPP1 1 134 600.
TEMPP1 1 135 600.
TEMPP1 1 136 600.
TEMPP1 1 137 600.
TEMPP1 1 138 600.
TEMPP1 1 139 600.
TEMPP1 1 140 600.
TEMPP1 1 141 600.
TEMPP1 1 142 600.
TEMPP1 1 143 600.
TEMPP1 1 144 600.
TEMPP1 1 145 600.
TEMPP1 1 146 600.
TEMPP1 1 147 600.
TEMPP1 1 148 600.
TEMPP1 1 149 600.
TEMPP1 1 150 600.
TEMPP1 1 151 600.
TEMPP1 1 152 600.
TEMPP1 1 153 600.
TEMPP1 1 154 600.
TEMPP1 1 155 600.
TEMPP1 1 156 600.
TEMPP1 1 157 600.
TEMPP1 1 158 600.
TEMPP1 1 159 600.
TEMPP1 1 160 600.
TEMPP1 1 161 600.
TEMPP1 1 162 600.
TEMPP1 1 163 600.
TEMPP1 1 164 600.
TEMPP1 1 165 600.
TEMPP1 1 166 600.
TEMPP1 1 167 600.
TEMPP1 1 168 600.
TEMPP1 1 169 600.
TEMPP1 1 170 600.
TEMPP1 1 171 600.
TEMPP1 1 172 600.
TEMPP1 1 173 600.
TEMPP1 1 174 600.
TEMPP1 1 175 600.
TEMPP1 1 176 600.
TEMPP1 1 177 600.
TEMPP1 1 178 600.
TEMPP1 1 179 600.
TEMPP1 1 180 600.
TEMPP1 1 181 600.
TEMPP1 1 182 600.
TEMPP1 1 183 600.
TEMPP1 1 184 600.
TEMPP1 1 185 600.
TEMPP1 1 186 600.
TEMPP1 1 187 600.
TEMPP1 1 188 600.
TEMPP1 1 189 600.
TEMPP1 1 190 600.
TEMPP1 1 191 600.
TEMPP1 1 192 600.
TEMPP1 1 193 600.
TEMPP1 1 194 600.
TEMPP1 1 195 600.
TEMPP1 1 196 600.
TEMPP1 1 197 600.
TEMPP1 1 198 600.
TEMPP1 1 199 600.
TEMPP1 1 200 600.
TEMPP1 1 201 600.
TEMPP1 1 202 600.
TEMPP1 1 203 600.
TEMPP1 1 204 600.
TEMPP1 1 205 600.
TEMPP1 1 206 600.
TEMPP1 1 207 600.
TEMPP1 1 208 600.
TEMPP1 1 209 600.
TEMPP1 1 210 600.
TEMPP1 1 211 600.
TEMPP1 1 212 600.
TEMPP1 1 213 600.
TEMPP1 1 214 600.
TEMPP1 1 215 600.
TEMPP1 1 216 600.
TEMPP1 1 217 600.
TEMPP1 1 218 600.
TEMPP1 1 219 600.
TEMPP1 1 220 600.
TEMPP1 1 221 600.
TEMPP1 1 222 600.
TEMPP1 1 223 600.
TEMPP1 1 224 600.
TEMPP1 1 225 600.
TEMPP1 1 226 600.
TEMPP1 1 227 600.
TEMPP1 1 228 600.
TEMPP1 1 229 600.
TEMPP1 1 230 600.
TEMPP1 1 231 600.
TEMPP1 1 232 600.
TEMPP1 1 233 600.
TEMPP1 1 234 600.
TEMPP1 1 235 600.
TEMPP1 1 236 600.
TEMPP1 1 237 600.
TEMPP1 1 238 600.
TEMPP1 1 239 600.
TEMPP1 1 240 600.
TEMPP1 1 241 600.
TEMPP1 1 242 600.
TEMPP1 1 243 600.
TEMPP1 1 244 600.
TEMPP1 1 245 600.
TEMPP1 1 246 600.
TEMPP1 1 247 600.
TEMPP1 1 248 600.
TEMPP1 1 249 600.
TEMPP1 1 250 600.
TEMPP1 1 251 600.
TEMPP1 1 252 600.
TEMPP1 1 253 600.
TEMPP1 1 254 600.
TEMPP1 1 255 600.
TEMPP1 1 256 600.
TEMPP1 1 257 600.
TEMPP1 1 258 600.
TEMPP1 1 259 600.
TEMPP1 1 260 600.
TEMPP1 1 261 600.
TEMPP1 1 262 600.
TEMPP1 1 263 600.
TEMPP1 1 264 600.
TEMPP1 1 265 600.
TEMPP1 1 266 600.
TEMPP1 1 267 600.
TEMPP1 1 268 600.
TEMPP1 1 269 600.
TEMPP1 1 270 600.
TEMPP1 1 271 600.
TEMPP1 1 272 600.
TEMPP1 1 273 600.
TEMPP1 1 274 600.
TEMPP1 1 275 600.
TEMPP1 1 276 600.
TEMPP1 1 277 600.
TEMPP1 1 278 600.
TEMPP1 1 279 600.
TEMPP1 1 280 600.
TEMPP1 1 281 600.
TEMPP1 1 282 600.
TEMPP1 1 283 600.
TEMPP1 1 284 600.
TEMPP1 1 285 600.
TEMPP1 1 286 600.
TEMPP1 1 287 600.
TEMPP1 1 288 600.
TEMPP1 1 289 600.
TEMPP1 1 290 600.
TEMPP1 1 291 600.
TEMPP1 1 292 600.
TEMPP1 1 293 600.
TEMPP1 1 294 600.
TEMPP1 1 295 600.
TEMPP1 1 296 600.
TEMPP1 1 297 600.
TEMPP1 1 298 600.
TEMPP1 1 299 600.
TEMPP1 1 300 600.
TEMPP1 1 301 600.
TEMPP1 1 302 600.
TEMPP1 1 303 600.
TEMPP1 1 304 600.
TEMPP1 1 305 600.
TEMPP1 1 306 600.
TEMPP1 1 307 600.
TEMPP1 1 308 600.
TEMPP1 1 309 600.
TEMPP1 1 310 600.
TEMPP1 1 311 600.
TEMPP1 1 312 600.
TEMPP1 1 313 600.
TEMPP1 1 314 600.
TEMPP1 1 315 600.
TEMPP1 1 316 600.
TEMPP1 1 317 600.
TEMPP1 1 318 600.
TEMPP1 1 319 600.
TEMPP1 1 320 600.
TEMPP1 1 321 600.
TEMPP1 1 322 600.
TEMPP1 1 323 600.
TEMPP1 1 324 600.
TEMPP1 1 325 600.
TEMPP1 1 326 600.
TEMPP1 1 327 600.
TEMPP1 1 328 600.
TEMPP1 1 329 600.
TEMPP1 1 330 600.
TEMPP1 1 331 600.
TEMPP1 1 332 600.
TEMPP1 1 333 600.
TEMPP1 1 334 600.
TEMPP1 1 335 600.
TEMPP1 1 336 600.
TEMPP1 1 337 600.
TEMPP1 1 338 600.
TEMPP1 1 339 600.
TEMPP1 1 340 600.
TEMPP1 1 341 600.
TEMPP1 1 342 600.
TEMPP1 1 343 600.
TEMPP1 1 344 600.
TEMPP1 1 345 600.
TEMPP1 1 346 600.
TEMPP1 1 347 600.
TEMPP1 1 348 600.
TEMPP1 1 349 600.
TEMPP1 1 350 600.
TEMPP1 1 351 600.
TEMPP1 1 352 600.
TEMPP1 1 353 600.
TEMPP1 1 354 600.
TEMPP1 1 355 600.
TEMPP1 1 356 600.
TEMPP1 1 357 600.
TEMPP1 1 358 600.
TEMPP1 1 359 600.
TEMPP1 1 360 600.
TEMPP1 1 361 600.
TEMPP1 1 362 600.
TEMPP1 1 363 600.
TEMPP1 1 364 600.
TEMPP1 1 365 600.
TEMPP1 1 366 600.
TEMPP1 1 367 600.
TEMPP1 1 368 600.
TEMPP1 1 369 600.
TEMPP1 1 370 600.
TEMPP1 1 371 600.
TEMPP1 1 372 600.
TEMPP1 1 373 600.
TEMPP1 1 374 600.
TEMPP1 1 375 600.
TEMPP1 1 376 600.
TEMPP1 1 377 600.
TEMPP1 1 378 600.
TEMPP1 1 379 600.
TEMPP1 1 380 600.
TEMPP1 1 381 600.
TEMPP1 1 382 600.
TEMPP1 1 383 600.
TEMPP1 1 384 600.
TEMPP1 1 385 600.
TEMPP1 1 386 600.
TEMPP1 1 387 600.
TEMPP1 1 388 600.
TEMPP1 1 389 600.
TEMPP1 1 390 600.
TEMPP1 1 391 600.
TEMPP1 1 392 600.
TEMPP1 1 393 600.
TEMPP1 1 394 600.
TEMPP1 1 395 600.
TEMPP1 1 396 600.
TEMPP1 1 397 600.
TEMPP1 1 398 600.
TEMPP1 1 399 600.
TEMPP1 1 400 600.
$ Femap with NX Nastran Load Set 3 : Initial Conditions
TEMPD 2 294.25
$ Femap with NX Nastran Constraint Set 1 : Fixed
SPC1 1 123456 21
SPC1 1 123456 22
SPC1 1 123456 23
SPC1 1 123456 24
SPC1 1 123456 25
SPC1 1 123456 26
SPC1 1 123456 27
SPC1 1 123456 28
SPC1 1 123456 29
SPC1 1 123456 30
SPC1 1 123456 31
SPC1 1 123456 132
SPC1 1 123456 133
SPC1 1 123456 134
SPC1 1 123456 135
SPC1 1 123456 136
SPC1 1 123456 137
SPC1 1 123456 138
SPC1 1 123456 139
SPC1 1 123456 140
SPC1 1 123456 141
$ Femap with NX Nastran Property 1 : Chapa5
PSHELL 1 1 .005 1 1 0.
$ Femap with NX Nastran Property 5 : Faldon3
PSHELL 5 2 .003 2 2 0.
$ Femap with NX Nastran Material 1 : Acero_Carbono_S275JR
MATS1 1 PLASTIC2.0502+7 1 1 1.
MAT1 1 2.05+11 .3 7850. 1.15-5 294.25 +
+ 5.+8
$ Femap with NX Nastran Material 2 : AISI Carbon Steel 304
MATS1 2 PLASTIC1.9302+7 1 1 1.
MAT1 21.931+11 .278027.197 1.728-5 294.25 +
+ 5.79+8
MAT4 2 16.2 502416.8027.197
GRID 1 0 .5 .5 0. 0
GRID 2 0 .45 .5 0. 0
GRID 3 0 .4 .5 0. 0
GRID 4 0 .35 .5 0. 0
GRID 5 0 .3 .5 0. 0
GRID 6 0 .25 .5 0. 0
GRID 7 0 .2 .5 0. 0
GRID 8 0 .15 .5 0. 0
GRID 9 0 .1 .5 0. 0
GRID 10 0 .05 .5 0. 0
GRID 11 0 0. .5 0. 0
GRID 12 0 0. .55 0. 0
GRID 13 0 0. .6 0. 0
GRID 14 0 0. .65 0. 0
GRID 15 0 0. .7 0. 0
GRID 16 0 0. .75 0. 0
GRID 17 0 0. .8 0. 0
GRID 18 0 0. .85 0. 0
GRID 19 0 0. .9 0. 0
GRID 20 0 0. .95 0. 0
GRID 21 0 0. 1. 0. 0
GRID 22 0 .05 1. 0. 0
GRID 23 0 .1 1. 0. 0
GRID 24 0 .15 1. 0. 0
GRID 25 0 .2 1. 0. 0
GRID 26 0 .25 1. 0. 0
GRID 27 0 .3 1. 0. 0
GRID 28 0 .35 1. 0. 0
GRID 29 0 .4 1. 0. 0
GRID 30 0 .45 1. 0. 0
GRID 31 0 .5 1. 0. 0
GRID 32 0 .5 .95 0. 0
GRID 33 0 .5 .9 0. 0
GRID 34 0 .5 .85 0. 0
GRID 35 0 .5 .8 0. 0
GRID 36 0 .5 .75 0. 0
GRID 37 0 .5 .7 0. 0
GRID 38 0 .5 .65 0. 0
GRID 39 0 .5 .6 0. 0
GRID 40 0 .5 .55 0. 0
GRID 41 0 .45 .55 0. 0
GRID 42 0 .4 .55 0. 0
GRID 43 0 .35 .55 0. 0
GRID 44 0 .3 .55 0. 0
GRID 45 0 .25 .55 0. 0
GRID 46 0 .2 .55 0. 0
GRID 47 0 .15 .55 0. 0
GRID 48 0 .1 .55 0. 0
GRID 49 0 .05 .55 0. 0
GRID 50 0 .45 .6 0. 0
GRID 51 0 .4 .6 0. 0
GRID 52 0 .35 .6 0. 0
GRID 53 0 .3 .6 0. 0
GRID 54 0 .25 .6 0. 0
GRID 55 0 .2 .6 0. 0
GRID 56 0 .15 .6 0. 0
GRID 57 0 .1 .6 0. 0
GRID 58 0 .05 .6 0. 0
GRID 59 0 .45 .65 0. 0
GRID 60 0 .4 .65 0. 0
GRID 61 0 .35 .65 0. 0
GRID 62 0 .3 .65 0. 0
GRID 63 0 .25 .65 0. 0
GRID 64 0 .2 .65 0. 0
GRID 65 0 .15 .65 0. 0
GRID 66 0 .1 .65 0. 0
GRID 67 0 .05 .65 0. 0
GRID 68 0 .45 .7 0. 0
GRID 69 0 .4 .7 0. 0
GRID 70 0 .35 .7 0. 0
GRID 71 0 .3 .7 0. 0
GRID 72 0 .25 .7 0. 0
GRID 73 0 .2 .7 0. 0
GRID 74 0 .15 .7 0. 0
GRID 75 0 .1 .7 0. 0
GRID 76 0 .05 .7 0. 0
GRID 77 0 .45 .75 0. 0
GRID 78 0 .4 .75 0. 0
GRID 79 0 .35 .75 0. 0
GRID 80 0 .3 .75 0. 0
GRID 81 0 .25 .75 0. 0
GRID 82 0 .2 .75 0. 0
GRID 83 0 .15 .75 0. 0
GRID 84 0 .1 .75 0. 0
GRID 85 0 .05 .75 0. 0
GRID 86 0 .45 .8 0. 0
GRID 87 0 .4 .8 0. 0
GRID 88 0 .35 .8 0. 0
GRID 89 0 .3 .8 0. 0
GRID 90 0 .25 .8 0. 0
GRID 91 0 .2 .8 0. 0
GRID 92 0 .15 .8 0. 0
GRID 93 0 .1 .8 0. 0
GRID 94 0 .05 .8 0. 0
GRID 95 0 .45 .85 0. 0
GRID 96 0 .4 .85 0. 0
GRID 97 0 .35 .85 0. 0
GRID 98 0 .3 .85 0. 0
GRID 99 0 .25 .85 0. 0
GRID 100 0 .2 .85 0. 0
GRID 101 0 .15 .85 0. 0
GRID 102 0 .1 .85 0. 0
GRID 103 0 .05 .85 0. 0
GRID 104 0 .45 .9 0. 0
GRID 105 0 .4 .9 0. 0
GRID 106 0 .35 .9 0. 0
GRID 107 0 .3 .9 0. 0
GRID 108 0 .25 .9 0. 0
GRID 109 0 .2 .9 0. 0
GRID 110 0 .15 .9 0. 0
GRID 111 0 .1 .9 0. 0
GRID 112 0 .05 .9 0. 0
GRID 113 0 .45 .95 0. 0
GRID 114 0 .4 .95 0. 0
GRID 115 0 .35 .95 0. 0
GRID 116 0 .3 .95 0. 0
GRID 117 0 .25 .95 0. 0
GRID 118 0 .2 .95 0. 0
GRID 119 0 .15 .95 0. 0
GRID 120 0 .1 .95 0. 0
GRID 121 0 .05 .95 0. 0
GRID 122 0 1. .5 0. 0
GRID 123 0 .95 .5 0. 0
GRID 124 0 .9 .5 0. 0
GRID 125 0 .85 .5 0. 0
GRID 126 0 .8 .5 0. 0
GRID 127 0 .75 .5 0. 0
GRID 128 0 .7 .5 0. 0
GRID 129 0 .65 .5 0. 0
GRID 130 0 .6 .5 0. 0
GRID 131 0 .55 .5 0. 0
GRID 132 0 .55 1. 0. 0
GRID 133 0 .6 1. 0. 0
GRID 134 0 .65 1. 0. 0
GRID 135 0 .7 1. 0. 0
GRID 136 0 .75 1. 0. 0
GRID 137 0 .8 1. 0. 0
GRID 138 0 .85 1. 0. 0
GRID 139 0 .9 1. 0. 0
GRID 140 0 .95 1. 0. 0
GRID 141 0 1. 1. 0. 0
GRID 142 0 1. .95 0. 0
GRID 143 0 1. .9 0. 0
GRID 144 0 1. .85 0. 0
GRID 145 0 1. .8 0. 0
GRID 146 0 1. .75 0. 0
GRID 147 0 1. .7 0. 0
GRID 148 0 1. .65 0. 0
GRID 149 0 1. .6 0. 0
GRID 150 0 1. .55 0. 0
GRID 151 0 .95 .55 0. 0
GRID 152 0 .9 .55 0. 0
GRID 153 0 .85 .55 0. 0
GRID 154 0 .8 .55 0. 0
GRID 155 0 .75 .55 0. 0
GRID 156 0 .7 .55 0. 0
GRID 157 0 .65 .55 0. 0
GRID 158 0 .6 .55 0. 0
GRID 159 0 .55 .55 0. 0
GRID 160 0 .95 .6 0. 0
GRID 161 0 .9 .6 0. 0
GRID 162 0 .85 .6 0. 0
GRID 163 0 .8 .6 0. 0
GRID 164 0 .75 .6 0. 0
GRID 165 0 .7 .6 0. 0
GRID 166 0 .65 .6 0. 0
GRID 167 0 .6 .6 0. 0
GRID 168 0 .55 .6 0. 0
GRID 169 0 .95 .65 0. 0
GRID 170 0 .9 .65 0. 0
GRID 171 0 .85 .65 0. 0
GRID 172 0 .8 .65 0. 0
GRID 173 0 .75 .65 0. 0
GRID 174 0 .7 .65 0. 0
GRID 175 0 .65 .65 0. 0
GRID 176 0 .6 .65 0. 0
GRID 177 0 .55 .65 0. 0
GRID 178 0 .95 .7 0. 0
GRID 179 0 .9 .7 0. 0
GRID 180 0 .85 .7 0. 0
GRID 181 0 .8 .7 0. 0
GRID 182 0 .75 .7 0. 0
GRID 183 0 .7 .7 0. 0
GRID 184 0 .65 .7 0. 0
GRID 185 0 .6 .7 0. 0
GRID 186 0 .55 .7 0. 0
GRID 187 0 .95 .75 0. 0
GRID 188 0 .9 .75 0. 0
GRID 189 0 .85 .75 0. 0
GRID 190 0 .8 .75 0. 0
GRID 191 0 .75 .75 0. 0
GRID 192 0 .7 .75 0. 0
GRID 193 0 .65 .75 0. 0
GRID 194 0 .6 .75 0. 0
GRID 195 0 .55 .75 0. 0
GRID 196 0 .95 .8 0. 0
GRID 197 0 .9 .8 0. 0
GRID 198 0 .85 .8 0. 0
GRID 199 0 .8 .8 0. 0
GRID 200 0 .75 .8 0. 0
GRID 201 0 .7 .8 0. 0
GRID 202 0 .65 .8 0. 0
GRID 203 0 .6 .8 0. 0
GRID 204 0 .55 .8 0. 0
GRID 205 0 .95 .85 0. 0
GRID 206 0 .9 .85 0. 0
GRID 207 0 .85 .85 0. 0
GRID 208 0 .8 .85 0. 0
GRID 209 0 .75 .85 0. 0
GRID 210 0 .7 .85 0. 0
GRID 211 0 .65 .85 0. 0
GRID 212 0 .6 .85 0. 0
GRID 213 0 .55 .85 0. 0
GRID 214 0 .95 .9 0. 0
GRID 215 0 .9 .9 0. 0
GRID 216 0 .85 .9 0. 0
GRID 217 0 .8 .9 0. 0
GRID 218 0 .75 .9 0. 0
GRID 219 0 .7 .9 0. 0
GRID 220 0 .65 .9 0. 0
GRID 221 0 .6 .9 0. 0
GRID 222 0 .55 .9 0. 0
GRID 223 0 .95 .95 0. 0
GRID 224 0 .9 .95 0. 0
GRID 225 0 .85 .95 0. 0
GRID 226 0 .8 .95 0. 0
GRID 227 0 .75 .95 0. 0
GRID 228 0 .7 .95 0. 0
GRID 229 0 .65 .95 0. 0
GRID 230 0 .6 .95 0. 0
GRID 231 0 .55 .95 0. 0
GRID 232 0 .5 0. 0. 0
GRID 233 0 .5 .05 0. 0
GRID 234 0 .5 .1 0. 0
GRID 235 0 .5 .15 0. 0
GRID 236 0 .5 .2 0. 0
GRID 237 0 .5 .25 0. 0
GRID 238 0 .5 .3 0. 0
GRID 239 0 .5 .35 0. 0
GRID 240 0 .5 .4 0. 0
GRID 241 0 .5 .45 0. 0
GRID 242 0 1. .45 0. 0
GRID 243 0 1. .4 0. 0
GRID 244 0 1. .35 0. 0
GRID 245 0 1. .3 0. 0
GRID 246 0 1. .25 0. 0
GRID 247 0 1. .2 0. 0
GRID 248 0 1. .15 0. 0
GRID 249 0 1. .1 0. 0
GRID 250 0 1. .05 0. 0
GRID 251 0 1. 0. 0. 0
GRID 252 0 .95 0. 0. 0
GRID 253 0 .9 0. 0. 0
GRID 254 0 .85 0. 0. 0
GRID 255 0 .8 0. 0. 0
GRID 256 0 .75 0. 0. 0
GRID 257 0 .7 0. 0. 0
GRID 258 0 .65 0. 0. 0
GRID 259 0 .6 0. 0. 0
GRID 260 0 .55 0. 0. 0
GRID 261 0 .55 .05 0. 0
GRID 262 0 .55 .1 0. 0
GRID 263 0 .55 .15 0. 0
GRID 264 0 .55 .2 0. 0
GRID 265 0 .55 .25 0. 0
GRID 266 0 .55 .3 0. 0
GRID 267 0 .55 .35 0. 0
GRID 268 0 .55 .4 0. 0
GRID 269 0 .55 .45 0. 0
GRID 270 0 .6 .05 0. 0
GRID 271 0 .6 .1 0. 0
GRID 272 0 .6 .15 0. 0
GRID 273 0 .6 .2 0. 0
GRID 274 0 .6 .25 0. 0
GRID 275 0 .6 .3 0. 0
GRID 276 0 .6 .35 0. 0
GRID 277 0 .6 .4 0. 0
GRID 278 0 .6 .45 0. 0
GRID 279 0 .65 .05 0. 0
GRID 280 0 .65 .1 0. 0
GRID 281 0 .65 .15 0. 0
GRID 282 0 .65 .2 0. 0
GRID 283 0 .65 .25 0. 0
GRID 284 0 .65 .3 0. 0
GRID 285 0 .65 .35 0. 0
GRID 286 0 .65 .4 0. 0
GRID 287 0 .65 .45 0. 0
GRID 288 0 .7 .05 0. 0
GRID 289 0 .7 .1 0. 0
GRID 290 0 .7 .15 0. 0
GRID 291 0 .7 .2 0. 0
GRID 292 0 .7 .25 0. 0
GRID 293 0 .7 .3 0. 0
GRID 294 0 .7 .35 0. 0
GRID 295 0 .7 .4 0. 0
GRID 296 0 .7 .45 0. 0
GRID 297 0 .75 .05 0. 0
GRID 298 0 .75 .1 0. 0
GRID 299 0 .75 .15 0. 0
GRID 300 0 .75 .2 0. 0
GRID 301 0 .75 .25 0. 0
GRID 302 0 .75 .3 0. 0
GRID 303 0 .75 .35 0. 0
GRID 304 0 .75 .4 0. 0
GRID 305 0 .75 .45 0. 0
GRID 306 0 .8 .05 0. 0
GRID 307 0 .8 .1 0. 0
GRID 308 0 .8 .15 0. 0
GRID 309 0 .8 .2 0. 0
GRID 310 0 .8 .25 0. 0
GRID 311 0 .8 .3 0. 0
GRID 312 0 .8 .35 0. 0
GRID 313 0 .8 .4 0. 0
GRID 314 0 .8 .45 0. 0
GRID 315 0 .85 .05 0. 0
GRID 316 0 .85 .1 0. 0
GRID 317 0 .85 .15 0. 0
GRID 318 0 .85 .2 0. 0
GRID 319 0 .85 .25 0. 0
GRID 320 0 .85 .3 0. 0
GRID 321 0 .85 .35 0. 0
GRID 322 0 .85 .4 0. 0
GRID 323 0 .85 .45 0. 0
GRID 324 0 .9 .05 0. 0
GRID 325 0 .9 .1 0. 0
GRID 326 0 .9 .15 0. 0
GRID 327 0 .9 .2 0. 0
GRID 328 0 .9 .25 0. 0
GRID 329 0 .9 .3 0. 0
GRID 330 0 .9 .35 0. 0
GRID 331 0 .9 .4 0. 0
GRID 332 0 .9 .45 0. 0
GRID 333 0 .95 .05 0. 0
GRID 334 0 .95 .1 0. 0
GRID 335 0 .95 .15 0. 0
GRID 336 0 .95 .2 0. 0
GRID 337 0 .95 .25 0. 0
GRID 338 0 .95 .3 0. 0
GRID 339 0 .95 .35 0. 0
GRID 340 0 .95 .4 0. 0
GRID 341 0 .95 .45 0. 0
GRID 342 0 0. 0. 0. 0
GRID 343 0 0. .05 0. 0
GRID 344 0 0. .1 0. 0
GRID 345 0 0. .15 0. 0
GRID 346 0 0. .2 0. 0
GRID 347 0 0. .25 0. 0
GRID 348 0 0. .3 0. 0
GRID 349 0 0. .35 0. 0
GRID 350 0 0. .4 0. 0
GRID 351 0 0. .45 0. 0
GRID 352 0 .45 0. 0. 0
GRID 353 0 .4 0. 0. 0
GRID 354 0 .35 0. 0. 0
GRID 355 0 .3 0. 0. 0
GRID 356 0 .25 0. 0. 0
GRID 357 0 .2 0. 0. 0
GRID 358 0 .15 0. 0. 0
GRID 359 0 .1 0. 0. 0
GRID 360 0 .05 0. 0. 0
GRID 361 0 .05 .05 0. 0
GRID 362 0 .05 .1 0. 0
GRID 363 0 .05 .15 0. 0
GRID 364 0 .05 .2 0. 0
GRID 365 0 .05 .25 0. 0
GRID 366 0 .05 .3 0. 0
GRID 367 0 .05 .35 0. 0
GRID 368 0 .05 .4 0. 0
GRID 369 0 .05 .45 0. 0
GRID 370 0 .1 .05 0. 0
GRID 371 0 .1 .1 0. 0
GRID 372 0 .1 .15 0. 0
GRID 373 0 .1 .2 0. 0
GRID 374 0 .1 .25 0. 0
GRID 375 0 .1 .3 0. 0
GRID 376 0 .1 .35 0. 0
GRID 377 0 .1 .4 0. 0
GRID 378 0 .1 .45 0. 0
GRID 379 0 .15 .05 0. 0
GRID 380 0 .15 .1 0. 0
GRID 381 0 .15 .15 0. 0
GRID 382 0 .15 .2 0. 0
GRID 383 0 .15 .25 0. 0
GRID 384 0 .15 .3 0. 0
GRID 385 0 .15 .35 0. 0
GRID 386 0 .15 .4 0. 0
GRID 387 0 .15 .45 0. 0
GRID 388 0 .2 .05 0. 0
GRID 389 0 .2 .1 0. 0
GRID 390 0 .2 .15 0. 0
GRID 391 0 .2 .2 0. 0
GRID 392 0 .2 .25 0. 0
GRID 393 0 .2 .3 0. 0
GRID 394 0 .2 .35 0. 0
GRID 395 0 .2 .4 0. 0
GRID 396 0 .2 .45 0. 0
GRID 397 0 .25 .05 0. 0
GRID 398 0 .25 .1 0. 0
GRID 399 0 .25 .15 0. 0
GRID 400 0 .25 .2 0. 0
GRID 401 0 .25 .25 0. 0
GRID 402 0 .25 .3 0. 0
GRID 403 0 .25 .35 0. 0
GRID 404 0 .25 .4 0. 0
GRID 405 0 .25 .45 0. 0
GRID 406 0 .3 .05 0. 0
GRID 407 0 .3 .1 0. 0
GRID 408 0 .3 .15 0. 0
GRID 409 0 .3 .2 0. 0
GRID 410 0 .3 .25 0. 0
GRID 411 0 .3 .3 0. 0
GRID 412 0 .3 .35 0. 0
GRID 413 0 .3 .4 0. 0
GRID 414 0 .3 .45 0. 0
GRID 415 0 .35 .05 0. 0
GRID 416 0 .35 .1 0. 0
GRID 417 0 .35 .15 0. 0
GRID 418 0 .35 .2 0. 0
GRID 419 0 .35 .25 0. 0
GRID 420 0 .35 .3 0. 0
GRID 421 0 .35 .35 0. 0
GRID 422 0 .35 .4 0. 0
GRID 423 0 .35 .45 0. 0
GRID 424 0 .4 .05 0. 0
GRID 425 0 .4 .1 0. 0
GRID 426 0 .4 .15 0. 0
GRID 427 0 .4 .2 0. 0
GRID 428 0 .4 .25 0. 0
GRID 429 0 .4 .3 0. 0
GRID 430 0 .4 .35 0. 0
GRID 431 0 .4 .4 0. 0
GRID 432 0 .4 .45 0. 0
GRID 433 0 .45 .05 0. 0
GRID 434 0 .45 .1 0. 0
GRID 435 0 .45 .15 0. 0
GRID 436 0 .45 .2 0. 0
GRID 437 0 .45 .25 0. 0
GRID 438 0 .45 .3 0. 0
GRID 439 0 .45 .35 0. 0
GRID 440 0 .45 .4 0. 0
GRID 441 0 .45 .45 0. 0
CQUAD4 1 1 1 2 41 40
CQUAD4 2 1 2 3 42 41
CQUAD4 3 1 3 4 43 42
CQUAD4 4 1 4 5 44 43
CQUAD4 5 1 5 6 45 44
CQUAD4 6 1 6 7 46 45
CQUAD4 7 1 7 8 47 46
CQUAD4 8 1 8 9 48 47
CQUAD4 9 1 9 10 49 48
CQUAD4 10 1 10 11 12 49
CQUAD4 11 1 40 41 50 39
CQUAD4 12 1 41 42 51 50
CQUAD4 13 1 42 43 52 51
CQUAD4 14 1 43 44 53 52
CQUAD4 15 1 44 45 54 53
CQUAD4 16 1 45 46 55 54
CQUAD4 17 1 46 47 56 55
CQUAD4 18 1 47 48 57 56
CQUAD4 19 1 48 49 58 57
CQUAD4 20 1 49 12 13 58
CQUAD4 21 1 39 50 59 38
CQUAD4 22 1 50 51 60 59
CQUAD4 23 1 51 52 61 60
CQUAD4 24 1 52 53 62 61
CQUAD4 25 1 53 54 63 62
CQUAD4 26 1 54 55 64 63
CQUAD4 27 1 55 56 65 64
CQUAD4 28 1 56 57 66 65
CQUAD4 29 1 57 58 67 66
CQUAD4 30 1 58 13 14 67
CQUAD4 31 1 38 59 68 37
CQUAD4 32 1 59 60 69 68
CQUAD4 33 1 60 61 70 69
CQUAD4 34 1 61 62 71 70
CQUAD4 35 1 62 63 72 71
CQUAD4 36 1 63 64 73 72
CQUAD4 37 1 64 65 74 73
CQUAD4 38 1 65 66 75 74
CQUAD4 39 1 66 67 76 75
CQUAD4 40 1 67 14 15 76
CQUAD4 41 1 37 68 77 36
CQUAD4 42 1 68 69 78 77
CQUAD4 43 1 69 70 79 78
CQUAD4 44 1 70 71 80 79
CQUAD4 45 1 71 72 81 80
CQUAD4 46 1 72 73 82 81
CQUAD4 47 1 73 74 83 82
CQUAD4 48 1 74 75 84 83
CQUAD4 49 1 75 76 85 84
CQUAD4 50 1 76 15 16 85
CQUAD4 51 1 36 77 86 35
CQUAD4 52 1 77 78 87 86
CQUAD4 53 1 78 79 88 87
CQUAD4 54 1 79 80 89 88
CQUAD4 55 1 80 81 90 89
CQUAD4 56 1 81 82 91 90
CQUAD4 57 1 82 83 92 91
CQUAD4 58 1 83 84 93 92
CQUAD4 59 1 84 85 94 93
CQUAD4 60 1 85 16 17 94
CQUAD4 61 1 35 86 95 34
CQUAD4 62 1 86 87 96 95
CQUAD4 63 1 87 88 97 96
CQUAD4 64 1 88 89 98 97
CQUAD4 65 1 89 90 99 98
CQUAD4 66 1 90 91 100 99
CQUAD4 67 1 91 92 101 100
CQUAD4 68 1 92 93 102 101
CQUAD4 69 1 93 94 103 102
CQUAD4 70 1 94 17 18 103
CQUAD4 71 1 34 95 104 33
CQUAD4 72 1 95 96 105 104
CQUAD4 73 1 96 97 106 105
CQUAD4 74 1 97 98 107 106
CQUAD4 75 1 98 99 108 107
CQUAD4 76 1 99 100 109 108
CQUAD4 77 1 100 101 110 109
CQUAD4 78 1 101 102 111 110
CQUAD4 79 1 102 103 112 111
CQUAD4 80 1 103 18 19 112
CQUAD4 81 1 33 104 113 32
CQUAD4 82 1 104 105 114 113
CQUAD4 83 1 105 106 115 114
CQUAD4 84 1 106 107 116 115
CQUAD4 85 1 107 108 117 116
CQUAD4 86 1 108 109 118 117
CQUAD4 87 1 109 110 119 118
CQUAD4 88 1 110 111 120 119
CQUAD4 89 1 111 112 121 120
CQUAD4 90 1 112 19 20 121
CQUAD4 91 1 32 113 30 31
CQUAD4 92 1 113 114 29 30
CQUAD4 93 1 114 115 28 29
CQUAD4 94 1 115 116 27 28
CQUAD4 95 1 116 117 26 27
CQUAD4 96 1 117 118 25 26
CQUAD4 97 1 118 119 24 25
CQUAD4 98 1 119 120 23 24
CQUAD4 99 1 120 121 22 23
CQUAD4 100 1 121 20 21 22
CQUAD4 101 5 122 123 151 150
CQUAD4 102 5 123 124 152 151
CQUAD4 103 5 124 125 153 152
CQUAD4 104 5 125 126 154 153
CQUAD4 105 5 126 127 155 154
CQUAD4 106 5 127 128 156 155
CQUAD4 107 5 128 129 157 156
CQUAD4 108 5 129 130 158 157
CQUAD4 109 5 130 131 159 158
CQUAD4 110 5 131 1 40 159
CQUAD4 111 5 150 151 160 149
CQUAD4 112 5 151 152 161 160
CQUAD4 113 5 152 153 162 161
CQUAD4 114 5 153 154 163 162
CQUAD4 115 5 154 155 164 163
CQUAD4 116 5 155 156 165 164
CQUAD4 117 5 156 157 166 165
CQUAD4 118 5 157 158 167 166
CQUAD4 119 5 158 159 168 167
CQUAD4 120 5 159 40 39 168
CQUAD4 121 5 149 160 169 148
CQUAD4 122 5 160 161 170 169
CQUAD4 123 5 161 162 171 170
CQUAD4 124 5 162 163 172 171
CQUAD4 125 5 163 164 173 172
CQUAD4 126 5 164 165 174 173
CQUAD4 127 5 165 166 175 174
CQUAD4 128 5 166 167 176 175
CQUAD4 129 5 167 168 177 176
CQUAD4 130 5 168 39 38 177
CQUAD4 131 5 148 169 178 147
CQUAD4 132 5 169 170 179 178
CQUAD4 133 5 170 171 180 179
CQUAD4 134 5 171 172 181 180
CQUAD4 135 5 172 173 182 181
CQUAD4 136 5 173 174 183 182
CQUAD4 137 5 174 175 184 183
CQUAD4 138 5 175 176 185 184
CQUAD4 139 5 176 177 186 185
CQUAD4 140 5 177 38 37 186
CQUAD4 141 5 147 178 187 146
CQUAD4 142 5 178 179 188 187
CQUAD4 143 5 179 180 189 188
CQUAD4 144 5 180 181 190 189
CQUAD4 145 5 181 182 191 190
CQUAD4 146 5 182 183 192 191
CQUAD4 147 5 183 184 193 192
CQUAD4 148 5 184 185 194 193
CQUAD4 149 5 185 186 195 194
CQUAD4 150 5 186 37 36 195
CQUAD4 151 5 146 187 196 145
CQUAD4 152 5 187 188 197 196
CQUAD4 153 5 188 189 198 197
CQUAD4 154 5 189 190 199 198
CQUAD4 155 5 190 191 200 199
CQUAD4 156 5 191 192 201 200
CQUAD4 157 5 192 193 202 201
CQUAD4 158 5 193 194 203 202
CQUAD4 159 5 194 195 204 203
CQUAD4 160 5 195 36 35 204
CQUAD4 161 5 145 196 205 144
CQUAD4 162 5 196 197 206 205
CQUAD4 163 5 197 198 207 206
CQUAD4 164 5 198 199 208 207
CQUAD4 165 5 199 200 209 208
CQUAD4 166 5 200 201 210 209
CQUAD4 167 5 201 202 211 210
CQUAD4 168 5 202 203 212 211
CQUAD4 169 5 203 204 213 212
CQUAD4 170 5 204 35 34 213
CQUAD4 171 5 144 205 214 143
CQUAD4 172 5 205 206 215 214
CQUAD4 173 5 206 207 216 215
CQUAD4 174 5 207 208 217 216
CQUAD4 175 5 208 209 218 217
CQUAD4 176 5 209 210 219 218
CQUAD4 177 5 210 211 220 219
CQUAD4 178 5 211 212 221 220
CQUAD4 179 5 212 213 222 221
CQUAD4 180 5 213 34 33 222
CQUAD4 181 5 143 214 223 142
CQUAD4 182 5 214 215 224 223
CQUAD4 183 5 215 216 225 224
CQUAD4 184 5 216 217 226 225
CQUAD4 185 5 217 218 227 226
CQUAD4 186 5 218 219 228 227
CQUAD4 187 5 219 220 229 228
CQUAD4 188 5 220 221 230 229
CQUAD4 189 5 221 222 231 230
CQUAD4 190 5 222 33 32 231
CQUAD4 191 5 142 223 140 141
CQUAD4 192 5 223 224 139 140
CQUAD4 193 5 224 225 138 139
CQUAD4 194 5 225 226 137 138
CQUAD4 195 5 226 227 136 137
CQUAD4 196 5 227 228 135 136
CQUAD4 197 5 228 229 134 135
CQUAD4 198 5 229 230 133 134
CQUAD4 199 5 230 231 132 133
CQUAD4 200 5 231 32 31 132
CQUAD4 201 5 232 233 261 260
CQUAD4 202 5 233 234 262 261
CQUAD4 203 5 234 235 263 262
CQUAD4 204 5 235 236 264 263
CQUAD4 205 5 236 237 265 264
CQUAD4 206 5 237 238 266 265
CQUAD4 207 5 238 239 267 266
CQUAD4 208 5 239 240 268 267
CQUAD4 209 5 240 241 269 268
CQUAD4 210 5 241 1 131 269
CQUAD4 211 5 260 261 270 259
CQUAD4 212 5 261 262 271 270
CQUAD4 213 5 262 263 272 271
CQUAD4 214 5 263 264 273 272
CQUAD4 215 5 264 265 274 273
CQUAD4 216 5 265 266 275 274
CQUAD4 217 5 266 267 276 275
CQUAD4 218 5 267 268 277 276
CQUAD4 219 5 268 269 278 277
CQUAD4 220 5 269 131 130 278
CQUAD4 221 5 259 270 279 258
CQUAD4 222 5 270 271 280 279
CQUAD4 223 5 271 272 281 280
CQUAD4 224 5 272 273 282 281
CQUAD4 225 5 273 274 283 282
CQUAD4 226 5 274 275 284 283
CQUAD4 227 5 275 276 285 284
CQUAD4 228 5 276 277 286 285
CQUAD4 229 5 277 278 287 286
CQUAD4 230 5 278 130 129 287
CQUAD4 231 5 258 279 288 257
CQUAD4 232 5 279 280 289 288
CQUAD4 233 5 280 281 290 289
CQUAD4 234 5 281 282 291 290
CQUAD4 235 5 282 283 292 291
CQUAD4 236 5 283 284 293 292
CQUAD4 237 5 284 285 294 293
CQUAD4 238 5 285 286 295 294
CQUAD4 239 5 286 287 296 295
CQUAD4 240 5 287 129 128 296
CQUAD4 241 5 257 288 297 256
CQUAD4 242 5 288 289 298 297
CQUAD4 243 5 289 290 299 298
CQUAD4 244 5 290 291 300 299
CQUAD4 245 5 291 292 301 300
CQUAD4 246 5 292 293 302 301
CQUAD4 247 5 293 294 303 302
CQUAD4 248 5 294 295 304 303
CQUAD4 249 5 295 296 305 304
CQUAD4 250 5 296 128 127 305
CQUAD4 251 5 256 297 306 255
CQUAD4 252 5 297 298 307 306
CQUAD4 253 5 298 299 308 307
CQUAD4 254 5 299 300 309 308
CQUAD4 255 5 300 301 310 309
CQUAD4 256 5 301 302 311 310
CQUAD4 257 5 302 303 312 311
CQUAD4 258 5 303 304 313 312
CQUAD4 259 5 304 305 314 313
CQUAD4 260 5 305 127 126 314
CQUAD4 261 5 255 306 315 254
CQUAD4 262 5 306 307 316 315
CQUAD4 263 5 307 308 317 316
CQUAD4 264 5 308 309 318 317
CQUAD4 265 5 309 310 319 318
CQUAD4 266 5 310 311 320 319
CQUAD4 267 5 311 312 321 320
CQUAD4 268 5 312 313 322 321
CQUAD4 269 5 313 314 323 322
CQUAD4 270 5 314 126 125 323
CQUAD4 271 5 254 315 324 253
CQUAD4 272 5 315 316 325 324
CQUAD4 273 5 316 317 326 325
CQUAD4 274 5 317 318 327 326
CQUAD4 275 5 318 319 328 327
CQUAD4 276 5 319 320 329 328
CQUAD4 277 5 320 321 330 329
CQUAD4 278 5 321 322 331 330
CQUAD4 279 5 322 323 332 331
CQUAD4 280 5 323 125 124 332
CQUAD4 281 5 253 324 333 252
CQUAD4 282 5 324 325 334 333
CQUAD4 283 5 325 326 335 334
CQUAD4 284 5 326 327 336 335
CQUAD4 285 5 327 328 337 336
CQUAD4 286 5 328 329 338 337
CQUAD4 287 5 329 330 339 338
CQUAD4 288 5 330 331 340 339
CQUAD4 289 5 331 332 341 340
CQUAD4 290 5 332 124 123 341
CQUAD4 291 5 252 333 250 251
CQUAD4 292 5 333 334 249 250
CQUAD4 293 5 334 335 248 249
CQUAD4 294 5 335 336 247 248
CQUAD4 295 5 336 337 246 247
CQUAD4 296 5 337 338 245 246
CQUAD4 297 5 338 339 244 245
CQUAD4 298 5 339 340 243 244
CQUAD4 299 5 340 341 242 243
CQUAD4 300 5 341 123 122 242
CQUAD4 301 1 342 343 361 360
CQUAD4 302 1 343 344 362 361
CQUAD4 303 1 344 345 363 362
CQUAD4 304 1 345 346 364 363
CQUAD4 305 1 346 347 365 364
CQUAD4 306 1 347 348 366 365
CQUAD4 307 1 348 349 367 366
CQUAD4 308 1 349 350 368 367
CQUAD4 309 1 350 351 369 368
CQUAD4 310 1 351 11 10 369
CQUAD4 311 1 360 361 370 359
CQUAD4 312 1 361 362 371 370
CQUAD4 313 1 362 363 372 371
CQUAD4 314 1 363 364 373 372
CQUAD4 315 1 364 365 374 373
CQUAD4 316 1 365 366 375 374
CQUAD4 317 1 366 367 376 375
CQUAD4 318 1 367 368 377 376
CQUAD4 319 1 368 369 378 377
CQUAD4 320 1 369 10 9 378
CQUAD4 321 1 359 370 379 358
CQUAD4 322 1 370 371 380 379
CQUAD4 323 1 371 372 381 380
CQUAD4 324 1 372 373 382 381
CQUAD4 325 1 373 374 383 382
CQUAD4 326 1 374 375 384 383
CQUAD4 327 1 375 376 385 384
CQUAD4 328 1 376 377 386 385
CQUAD4 329 1 377 378 387 386
CQUAD4 330 1 378 9 8 387
CQUAD4 331 1 358 379 388 357
CQUAD4 332 1 379 380 389 388
CQUAD4 333 1 380 381 390 389
CQUAD4 334 1 381 382 391 390
CQUAD4 335 1 382 383 392 391
CQUAD4 336 1 383 384 393 392
CQUAD4 337 1 384 385 394 393
CQUAD4 338 1 385 386 395 394
CQUAD4 339 1 386 387 396 395
CQUAD4 340 1 387 8 7 396
CQUAD4 341 1 357 388 397 356
CQUAD4 342 1 388 389 398 397
CQUAD4 343 1 389 390 399 398
CQUAD4 344 1 390 391 400 399
CQUAD4 345 1 391 392 401 400
CQUAD4 346 1 392 393 402 401
CQUAD4 347 1 393 394 403 402
CQUAD4 348 1 394 395 404 403
CQUAD4 349 1 395 396 405 404
CQUAD4 350 1 396 7 6 405
CQUAD4 351 1 356 397 406 355
CQUAD4 352 1 397 398 407 406
CQUAD4 353 1 398 399 408 407
CQUAD4 354 1 399 400 409 408
CQUAD4 355 1 400 401 410 409
CQUAD4 356 1 401 402 411 410
CQUAD4 357 1 402 403 412 411
CQUAD4 358 1 403 404 413 412
CQUAD4 359 1 404 405 414 413
CQUAD4 360 1 405 6 5 414
CQUAD4 361 1 355 406 415 354
CQUAD4 362 1 406 407 416 415
CQUAD4 363 1 407 408 417 416
CQUAD4 364 1 408 409 418 417
CQUAD4 365 1 409 410 419 418
CQUAD4 366 1 410 411 420 419
CQUAD4 367 1 411 412 421 420
CQUAD4 368 1 412 413 422 421
CQUAD4 369 1 413 414 423 422
CQUAD4 370 1 414 5 4 423
CQUAD4 371 1 354 415 424 353
CQUAD4 372 1 415 416 425 424
CQUAD4 373 1 416 417 426 425
CQUAD4 374 1 417 418 427 426
CQUAD4 375 1 418 419 428 427
CQUAD4 376 1 419 420 429 428
CQUAD4 377 1 420 421 430 429
CQUAD4 378 1 421 422 431 430
CQUAD4 379 1 422 423 432 431
CQUAD4 380 1 423 4 3 432
CQUAD4 381 1 353 424 433 352
CQUAD4 382 1 424 425 434 433
CQUAD4 383 1 425 426 435 434
CQUAD4 384 1 426 427 436 435
CQUAD4 385 1 427 428 437 436
CQUAD4 386 1 428 429 438 437
CQUAD4 387 1 429 430 439 438
CQUAD4 388 1 430 431 440 439
CQUAD4 389 1 431 432 441 440
CQUAD4 390 1 432 3 2 441
CQUAD4 391 1 352 433 233 232
CQUAD4 392 1 433 434 234 233
CQUAD4 393 1 434 435 235 234
CQUAD4 394 1 435 436 236 235
CQUAD4 395 1 436 437 237 236
CQUAD4 396 1 437 438 238 237
CQUAD4 397 1 438 439 239 238
CQUAD4 398 1 439 440 240 239
CQUAD4 399 1 440 441 241 240
CQUAD4 400 1 441 2 1 241
ENDDATA
