I need to launch already existing command in UG NX 9, but need default load values to be changed .
Hi
I need a help from u guys
I want to launch a exsiting UG command in NX by using vb.net dll file but I have to set certain parameters inside the command as I intended
bcoz I need to change those parameters again and again each time when I launch that tool.
Lets say I want to launch extrude command with default my own default start value and end value
I recorded journals but the execution is doing the changes and does commit the command, dont know what to do pls help
Thanks & regards,
Inian
RE: I need to launch already existing command in UG NX 9, but need default load values to be changed .
You can provide a user interface (UI) for your program through the use of the block styler, winforms, some NX selection commands, or (to a limited extent) message and input boxes. There is no way (that I know of) to pull up a standard NX dialog box, wait for user input, and use the values as input for your journal.
The advantage of custom programs is to speed things up by calculating values and eliminating user input as much as possible. If you can calculate the values that you need based on other objects in the file, it would be to your advantage to do so. If you absolutely need user input, you will have to use one of the methods mentioned above.
www.nxjournaling.com
