Difference between Galvanizing and HOT DIP Galvanizing
Dears,
In the current project I am working , I came across the term "Hot dip galvanizing".
Is there any difference between galvanizing and hot dip galvanizing?
Is HOT DIP galvanizing any special process?
RE: Difference between Galvanizing and HOT DIP Galvanizing
http://en.wikipedia.org/wiki/Galvanization
In common use "Galvanizing" most typically refers to hot dip galvanizing. But for a spec writer, you cannot rely on that. You should also be calling out an ASTM.
For example, in ASTM A325: When zinc-coated fasteners are required, the purchaser shall specify the zinc coating process, for example, hot dip, mechanically deposited, Zinc/Aluminum Corrosion Protective Coating, or no preference.
ASTM B695 Specification for Coatings of Zinc Mechanically Deposited on Iron and Steel
ASTM F2329 Specification for Zinc Coating, Hot-Dip, Requirements for Application to Carbon and Alloy Steel Bolts, Screws, Washers, Nuts, and Special Threaded Fasteners
ASTM F1136 Specification for Zinc/Aluminum Corrosion Protective Coatings for Fasteners
