I get this error message when doing a "Save Precise Assembly"
Running NX8.0.3.4
I get this error message when doing a "Save Precise Assembly":
The following parts failed to save causing the overall save operation to fail:
While saving 12345678/001:
12345678/001 - There were errors importing assembly arrangement PLMXML document to Teamcenter.
File -> Save works okay.
But File -> Save Precise Assembly gives me the error. So does running Checkmate, which I assumes calls the Save Precise Assembly command.
Any ideas?
UGGUY
Any ideas?
UGGUY
RE: I get this error message when doing a "Save Precise Assembly"
I would assume that NX sends some extra information to Teamcenter when you save precise.
If this doesn't work, it might be the setup which is incorrect.
Have you tried to instead toggle precise/inprecise in the TC Structure Editor and see if that works ?
Tomas
