Zinc plate for Bolts and nuts exposed
Hello, everybody.
There is inside Nace MR0175/ISO15156(2):2009; A2.1.5 a mention about the metalic coatings. That is a not acceptable for preventing SSC. For standard we offer the bolts and nuts to attend NAce with Zinc plated. The material is correct with Nace (B7M-2HM). Our intention is not preventing SSC. Could we provide plated or nude bolts and nuts ?
RE: Zinc plate for Bolts and nuts exposed
If it is not, why you are referring NACE MR0175. (Off-shore).
It is not recommended for Nude Bolts and Nuts. It should be coated/plated by Zinc-Ni plated or according to
your specs.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Have a look at BS 7371 and Shell ES/313 to have a better idea.
Their informations are all that I need to decide to do. Thanks a lot.
