how to calculate the torsional deflection of thin-walled beams considering buckling
Hi all
I need to calculate the torsional deflection of a thin-walled beam of arbitrary section. Thin-walled beams behave like shells, so buckling is an important factor. Is there any equation to calculate the torsional deflection of thin-walled beams taking in consideration the buckling effect? I need an expression with the polar inertia moment. I also would like to have the reference of a book or something with that equation, so I can study the matter by myself
thanks in advance,
regards,
Miguel Silva, MSc.
RE: how to calculate the torsional deflection of thin-walled beams considering buckling
You've asked this same question now 5 times in 4 different forums. You apparently do like any of the answers our readers have contributed.
Make the finite element model. Solve it yourself. Stop repeating the question.
There's a very simple method for solving it, but I'll have to come back to write it up later.
It's based on a method Fermat developed.
