Dimensioning a Paint Scheme with Hatch Marks
I have a part that will need to be painted with a pattern of hatchmarks. There will be 1/8" black stripes followed by 3/8" yellow stripes. In order to dimension this properly according to ANSI standards, would I need to count up all the stripes and say "28X .125 BLACK" or is this a situation where using the typical callout still applies ".125 BLACK TYP"?
RE: Dimensioning a Paint Scheme with Hatch Marks
Check out forum1103: Drafting Standards, GD&T & Tolerance Analysis, use of typ not being explicitly supported by the standards has been discussed many times - including in the last week or so.
http://www.eng-tips.com/search.cfm?pid=1103&ac...
Might be a case where you can get away with a note something like "ALTERNATING STRIPES .125+-.03 BLACK AND .375+-.03 WIDE YELLOW ON SURFACE INDICATED PAINT SHALL COMPLY WITH ...<insert color spec>
By the way, unless you're working to very old version of the standards they aren't direct ANSI and haven't been for a while so not many drafting folk hang out in this forum.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Thanks, KENAT!
very true
