Centrifugal Vertical Pump Bearing housing Preservation oil leaks.
Dears,
First Post here, hello and thanks for reading, during rust preventive work at storage period, we are facing some oil leaks
( ISO VG 46 oil with CORTEC rust preventive ) on bearing housing for pump A identical to pump B without any leaks as soon as shaft is turning , following vendor procedure requires oil ring lubrication running out the shaft baffles with 2 ¼ handlly turn every week .
what could be the possible reason for the oil leak from API 610 identical pumps , is it a sealing problem ?? Mounting and assembly or mishandling issue chock or what else??
Capacity 15m3/h. HT light naphtha transfer pumps
Head 97 m.
BHP x RPM 6.3 KW x 2920.
Thanks .
Head 97 m.
Thanks .
RE: Centrifugal Vertical Pump Bearing housing Preservation oil leaks.
(probably a silly question... just double checking)
(2B)+(2B)' ?
(2B)+(2B)' ?
This not a concern. As soon as the oil level is below it, the leakage will stop.
