limit of times for repair in a girth weld
Beyond the knowledge base of the thermal effects of welding on the base material, is there any known limitation on the times that may be repaired a girth weld, made under the requirements of the code B31, process piping?
RE: limit of times for repair in a girth weld
This is some general guidance, but you need to talk to a welding engineer as each situation is different. http://www.twi-global.com/technical-knowledge/faqs...
