NX 7.5 - Drafting - Underlined Text not clear enough to be read.
View Label Is there a way to increase the spacing between the underline and the Text? How? Currently underlining the view labels and notes the line bleeds into the text making it illegible. I need some space And help. Thank you, Susan.
RE: NX 7.5 - Drafting - Underlined Text not clear enough to be read.
I think the best you can try is to change fonts, and see how that helps.
Section View 1-5B
<U> <U>
Do you forego the underline? That is where I am headed.
I prob won't be back on here until tomorrow.
Does anyone know how can I cut a text (Drafting), with a simple line ? I am using NX 8.5.
EXAMPLEThank you
with a special font "blockfont_strike-thru.fnx" that I copied where NX is installed ( UGII/ugfonts folder )
It works just fine !
