How set default Multiline text default settings?
How do I get my multiline text default settings to be 0.125 and centered in AutoCAD 2014 Electrical?
RE: How set default Multiline text default settings?
My be you can create your own command or a button with MTEXT:
CODE -->
(COMMAND "-MTEXT" pause "J" "TC" "H" 0.125 pause)
Hope it helps
Use Multi Leader Styles, use the MLeaderStyle command
