antialiasing NX7.5
antialiasing NX7.5
I am trying to get antialiazing on my screen:
Preference
visualization
visual
- line antialiazing is checked (but i do not see it happen in sketch or model)
- full scene antialiazing is grayed out. I think it is the one that can make my screen appear with antialiazing in model, sketch and drawing. BUT HOW I MAKE IT WORK.
Or someone knows another way to get antialiazing works.
Preference
visualization
visual
RE: antialiasing NX7.5
Check in visualization performance settings to see if it has been disabled there (Preferences -> Visualization performance -> general graphics).
www.nxjournaling.com
What you should look for are lines which are almost horizontal or almost vertical. ( Rotate the view)
See the attached image of a single line with and without anti aliasing.
Tomas
Disable Full Scene Antialiazing - there is a check mark on it, but it is grayed out completely
This indicates that your hardware does not support this feature.
Is NX different on that matter?
Thanks Cowski
