SW 2014 Sketch inference points
In Sketch mode, when I place the cursor along a line, why would the midpoint relation inference not pop up?
Also, how do I place <x> number sketch points evenly spaced along a curve? or just at the midpoint?
Also, why is it that the intersection of two lines on seperate sketches can not be picked witht he cursor to make a curve/line?
RE: SW 2014 Sketch inference points
Make sure the Selection Filter is not set to exclude midpoints.
Check the Help files for Reference Points
http://help.solidworks.com/2014/English/solidworks...
Quote:
Also, why is it that the intersection of two lines on seperate sketches can not be picked with the cursor to make a curve/line?
The intersection of two lines can be selected. Make note of the cursor icon. It is not as obvious as other selected points which are highlighted orange.
Two seperate 3D sketches on the same surface....why can't I go Ref POints, Intersection, pick both 3D sketch lines, create point????
It says Rebuild errors, failed to create point
