Duplex S31254 with Inconel 625 in seawater application
I've been searching to fine the galvanic reaction between these two materials used in a flowing seawater application. The Duplex will have a very small exposed area and the Inconel will have a rather large exposed area, they are both in close contact with each other.
I have also been trying to place the Duplex on the galvanic series, any insight into that would be helpful as well. "Alloy 625" is clearly listed on most charts I have seen. For example: http://www.rowantechnology.com/wp-content/uploads/...
Please shed some light on this for me.
Thank You!
Thank You!
RE: Duplex S31254 with Inconel 625 in seawater application
In a crevice corrosion situation the 625 may not be up to the task....
Plymouth Tube
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Of all of the various 6% Mo superaustenitic stainless grades S31254 is the least corrosion resistant.
N08367, N08925/26, and S32654 are all better alloys.
Steve, 22 has significantly better pitting resistance than 625. There have been many cases of 625 seals and flanges failing in seawater. I am not aware of any 22 (or 59 or 686) seawater failures.
Plymouth Tube
Please keep any comments coming.
Steve Jones
Thanks again
