NX8 Customer Symbols Annotation Preferences setup as customer default?
Is there a possibility to setup the customer symbol annotation as a customer default? Per standard this setting was setup to "Use Current", which causes mostly too large ore too small annotations - just like the current style settings. But we would like to have "Use Definition". I found no setting in the customer defaults settings. Do anyone knows a solution?
See also attached pictures.
Michael
RE: NX8 Customer Symbols Annotation Preferences setup as customer default?
There are , but in two different places... and you will not find them if you search...
1) File - utilities - Customer defaults- Site/ group / user
2) - Drafting - Other Symbols - Custom tab : Geometry Preferences=
3) - Drafting - General - Standard - xxx - Customize Standard - Drafting Standard - Custom - :Annotation Preferences=
Tomas
Thank You Toost,
this was very helpful!
best regards
Michael
