voltage regulator in neplan
Hello togehter
I want to implemented a voltage regulator in Neplan for the low-voltage grid.
When I put the steps of the voltage regulator manually, the voltage regulator is working correctly. But if I set the autmomatische control, he no longer works correctly. The voltage controller controls the voltage of -6% to 6% in 1.5% increments. I myself can not explain it.
I would be glad if someone could help me because I already try for hours to solve the ploblem
The file's link is: http://files.engineering.com/getfile.aspx?folder=8...
regards and thank you
