Ordinate dimensioning in NX 8 (probubly all versions)
is there a way to get UG to only give me either the X or Y dimension verses automaticly giving me both which if they are several dim with the same X or Y they all end up doggleged
I guess I mean I only want the x dimension for a set of holes and the Y dim is O.OOO
Cj Silver
Tooling Engineer BAE Systems
Working to remember all I forgotten
RE: Ordinate dimensioning in NX 8 (probubly all versions)
Here is the procedure:
1. place the view and then click the Ordinate Dimension command
2. click on the point, that has to be the origin for the ordinate dimensioning.
3. two dashed baselines will appear. One is for dimension in X direction, another for Y direction.
4. now click with right mouse button on the baseline (x or y), that you want to exclude from dimensioning. Select 'Set Baseline Inactive'.
5. now place the dimensions. The dimensions are placed in only one direction.
Hope, that this helps.
Cj Silver
